Question about Sony Playstation 3 (PS3) Console
Ive got a yellow light - Sony Playstation 3 (PS3) Console
Ive just moved into a flat with a servis 7kg 1500AA washing machine and i have no instructions for it. when i press the on button the yellow light above another symbol flashes and nothing happens. ive...
Hi. Set the dial to reset (12 o-clock position) then push button second from right. Now set to program required and press button again. Should work now. Needs resetting every time, this is normal. Hope it works for you.
Sep 10, 2010 | Washing Machines
No lights come on and nothing happens when i press the starter
the yellow or yellow and white wires have come apart under tank simply remove tank follow the wires from right hand switch block should be a black connection block and yellow and yellow and white wires are the old type bullet connectors check for corrosion green deposits reconnect wires yellow to yellow and yellow/white to yellow/white id use some electrical tape to insulate further also helps to stop them working loose again when handle bars are turned switch on the ignition b4 putting tank back on press start button it will start trust me lol
May 19, 2010 | 1997 Suzuki GSX 600 F (Katana)
Sendai CD789 radio preset stations
At the back you should have a red, black and yellow (maybe blue). swap the red and yellow over. Yellow = memory [constant voltage] red = live with ignition. Hope this helps. Wayne. Tech Rehab. http://techrehab.t35.com
Apr 20, 2010 | Car Audio & Video
also known as the yellow light of death google it and hopefully u will find a solution
Mar 19, 2010 | Sony Playstation 3 (PS3) Console
My 1999 golf 1.4 wont start. ive changed the spark plugs, ive changed the crank shaft sensor and previously i was told it was because my key werent programmed so i found the original. when i try and turn...
THE KEY U ARE USING THAT TURNS THAT LIGHT ON IS NO GOOD OR NOT PROGRAMMED, THE LIGHT IS THE SECURITY SYSTEM WARNING LIGHT, IF THE OHTER KEY DOESN'T FLASH THE LIGHT THEN THAT KEY IS OK, SOUNDS LIKE YOU MAY HAVE A FUEL PRESSURE PROBLEM, HAVE U VERIFIED THE FUEL PUMP WORKS AND YOU HAVE INJECTORS DELIVERING FUEL? DO YOU HAVE SPARK?.
Aug 27, 2009 | Volkswagen Golf Cars & Trucks
Lan
you need to install the driver of your lan coming from your motherboard cd in order to repair this. after installation you must reboot
Dec 19, 2007 | EliteGroup GeForce 6100SM-M Motherboard
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
