Question about Pride Celebrity X 4-Wheel Electric Scooter
How to test a wheelchair battery - Pride Celebrity X 4-Wheel Electric Scooter
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 346 Answers
Check batteries with load tester.If either battery dropsmore than 1 volt under a load,the battery(s)are bad.Replace "both" batteries.
Posted on Jun 12, 2010
How do i recharge a dead battery for my quantum motorized wheelchair?
First ensure the battery is completely discharged by using a voltmeter or other suitable method.
If the battery really is dead it should be charged with a suitable known good battery charger for the required time, allowed to stand a few hours and then tested by putting it into use or employing a suitable method of testing.
All disability scooters and electric wheelchairs arrive with a dedicated battery charger which should be used if possible, though these sometimes fail and need replacing. In that case other methods of charging can be employed but purely on a temporary basis as there are safety concerns with battery charging.
If charging the battery does not work, it might need replacing and/or there might be a fault with the wheelchair.
Feb 25, 2017 | Quantum Health & Beauty
Why had the chair not charged it had been charging for 24 hours After i replaced thr batteries
It is possible that the new batteries are bad. This happened to me once. The charger though is probably the culprit for your problems. Have the charger tested first, or ask a scooter or power wheelchair store test or charge your batteries.
Mar 08, 2015 | NRS Hoveround MPV 4 - Hovaround Used...
Pronto M51 Wheelchair doesn't have as much power as it used to. Batteries are good.
Have you had the batteries load tested? How do you know the batteries are good?
Apr 21, 2013 | Invacare Pronto M51 Power Wheelchair
Batteries wont hold charge
Check battery harness, circuit breaker, all connections. Load test each battery. If any one of the batteries fails the load test, replace both of them. Also ensure that charger is actually charging
Mar 01, 2013 | Electric Jazzy 1115 Power Wheelchair
Charger does not seem to charge battery. Red light comes on, fan and yellow light start up then shutdown within 3 seconds. Red light stays light. What might be wrong with the charger?
How old are your batteries? Have they been charged regularly? (ie: every night) I have a hunch it may be a battery problem rather than the charger. The batteries should be load tested with an automotive load tester, or you could take the batteries to a local service station to have them tested. If they test poorly, both batteries need to be replaced.
Sep 05, 2011 | Pride Jazzy Select 6 Indoor Power...
The only time the chair worked [approx. 1/2 hour] was when the repairman cleaned the cables. Since that, the chair charges, turns green for full charge, and only flashes red as soon as the joystick is...
hi.
the link below is for the owners manual for the quickie aspire power wheelchair, free download in pdf format.
http://www.wheelchair-review.co.uk/wheelchair-files/wheelchair-manuals/sunrise-medical-wheelchairs/quickie-aspire-power-wheelchair.pdf
the "cane crutch holder" is an acessory part that you can get, fitted to the back of the seat, to hold a crutch or cane. it does not affect the chair itself at all.
there are two most likely reasons for your problem, neither of which actually involve the arm and controller.
1. if the battery light is flashing 9 times when you try to move, then you need to check the motor locks are engaged properly. see page 27 of the manual for photos and location. these are also known as "freewheel levers" and allow you to disconnect the motors to push the chair manually. if the levers are engaged properly, it is quite possible that the switch, or switch wires have broken and the chair thinks that they are off. these are very cheap and easy to replace and are located where the lever connects inside the chair.
2. if the battery light comes on and stays on, then you may need to have the batteries checked. if the batteries have not been charged for a while then sulphur may have built up on the lead plates inside the battery. this can mean that the batteries will show fully charged, but as soon as you try to draw power, they cannot function due to the sulphur, and instantly show as flat.
any auto shop should be able to perform a battery load test for you to test this. a 100amp load test for about 6 seconds will test the battery performance and let you know if they need replacing. most places will do this test for free but the batteries need to be fully charged first.
hopefully, one of these solutions will work as these are the most common fault for the symptoms you are describing. you should find the manual quite useful as well.
please feel free to ask if you need more information.
hope this helps
Jul 12, 2011 | Quickie Wheelchairs Quickie Aspire Power...
How do you do a load test on the batteries o f my jazzy 1115 power wheel chair?
You don't do load tests on deep-cycle batteries, unlike car batteries. Car batt's are measured in cold cranking amps, deep cycle are in amp-hours. The best way to test is to drive the chair (which loads it), and see how long it runs. It should take you a good five miles and still be in the green. If not, time for new batts.
Dec 26, 2009 | Electric Jazzy 1115 Power Wheelchair
Jazzy 1113 batteries go dead quickly even new batteries
it is not uncommon for some of the new batteries available today to be defective...load test them
Apr 20, 2009 | Pride Jazzy 1113 ATS Indoor Power...
Battery won't charge
First make sure that all the connections are tight. Then have the batteries load tested.
Mar 19, 2009 | Electric Jazzy 1115 Power Wheelchair
Elctric wheelchair, flashing rapidly the error display
Have the batteries load tested and be sure that the chair is in gear.
Feb 03, 2009 | Select Jazzy Used Electric Wheelchair
Pride Celebrity X 4-Wheel Electric Scooter  Logo
408 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
