Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
I have a kenmore electric stove. The top burner
I have a kenmore electric stove. The top burner work fine. The bake and the broil elements will not come on. Both elements were checked with a olhm meter and they are fine. Can you help me?
I have the same problem, it turns out that the clock has a sensor in it to turn on the oven. If that sensor is not working, which is found in the clock, the oven does not work. I had a repair guy come out and it will cost 350.00 to repair. My stove is only six years old. It is only two months to the day off warranty. Apparently a power outage can cause the sensor to go. Hope this helps.
Posted on Aug 20, 2010
Kenmore electric oven will not bake
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
Apr 04, 2014 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore electric range oven baking element does not go on eveything else works
The bake element
Jan 30, 2014 | Kenmore Ovens
Bake, broil & clean buttons do not function, all others (timer, cook time,end time, clock) work fine. Therefore I cannot light the oven. The stove burners work fine.
check the main power terminal block and make sure the power is correct.if the power is correct then you will need to change the main control board.how ever unplug the unit and check all the wiring to the control board and the bake and broil elements.if the unit is gas then you may need to replace the ignitor unit if it does not draw enough power during the light up it will not open the gas valve.replace the main main control board still applies if the other items check out fine.
Nov 03, 2010 | Kenmore Ovens
My oven is burning my baked goods, but shows the right temp with a thermometer. Do I have to turn the dial to broil and then back to the desired temp? Even if the rack is in the middle, everything burns....
If it is convection bake you have to turn the temp down (25 degrees or so) that is listed in the recipe.
The broil setting is not used to bake because it operates differently from the bake setting. So, don't go to the broil setting at all.
The element for bake is under the floor of the oven. You have not indicated whether it is gas or electric, but both of these can have issues with the burner or element.
If you are baking on the correct setting and the oven is heating from the bottom, not the top, this can be caused by hot spots that are created by elements/burners.
to check, look under the floor of the oven. Turn the bake heat up to high and see if the flame is uneven. For an electric oven, the color of the element should be evenly red, no brown spots.
If you are using an oven thermometer, move the thermometer to the spot in the oven that seems to be burning things the most.
Nov 27, 2009 | Kenmore Ovens
Stove works fine, only the oven will not turn on.
If it's electric, it is possible that you are only getting 110 volts to the range. It runs on a 220v line, so if one leg of the circuit kicks off, you could still operate the top burners. If this isnt the problem, you may have burned out your bake element. Try your broil element.
Nov 18, 2009 | Whirlpool Ovens
Bottom filament on bake not working but broil and
FAULTY ELEMENT OR THERMAL SWITCH. HAVE IT CHECKED OUT BY AN ELECTRICIAN.
Sep 07, 2009 | Stoves 720EF Electric Double Oven
I can't bake. The bottom burner in my stove is not working. The broiler works fine. Could the burner be bad?
yeah, it's definitely the burner. most people use bake more than broil and that's the reason why bake goes out first, almost all the time. you can check by getting a reading of 240v where the element connects to, assuming this is electric. If it's gas, then the ignitor needs to be changed and you should get 120v reading. Good luck.
Jul 08, 2009 | Kenmore Ovens
Bake and Broil not working
After you hit the function you want...bake or broil...click the up arrow.  That should give you the default temp of 350 and the unit should light.  Now adjust to the temp you want.
Nov 28, 2008 | Ovens
TOP BURNERS WORK BUT OVEN DOES NOT WORK AT ALL.
Sounds like a heating element. Same thing happend to my oven. You can find them around 50-60 dollars. Veryy easy to install, just remove a couple of screws and remove old element and put in new one. Make sure you shut off power to oven firstg of course.
Oct 08, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
335 people viewed this question
Top Kenmore Ovens Experts
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
