Question about StarTech.com StarView SV211K 2-port KVM Switch
How do you put the codes in as all station which we cannot view have the $ symbol
  • loftys0504 May 14, 2010
    please tell what box you have and if your cable or terrestrial
    Sergeant:
  • 142 Answers
Press menu, on installation press 1570, this takes you to nagrivision, make sure emu or key code is showing on"" press O.K. This takes you to the providers, scroll right till you get to the one is yours, do one line at a time using your remote to change numbers & letters using the colour buttons then press store after each line.exit back to start when finished.
Posted on May 14, 2010
I have a 2006 Mercury Mountaineer I recently had my transmission rebuilt Now my radio's touch screen does not work Only shows Mercury Symbol. hear it but can't change station. Now no sound .Help
You need to input the radio security code because the battery was disconnected. If you don't have it see the Ford dealer (about $100.00 charge) or go here www.radio-code.com
Dec 31, 2016 | 2006 Mercury Mountaineer
Schematic?
A schematic, or schematic diagram, is a representation of the elements of a system using abstract, graphic symbols rather than realistic pictures. A schematic usually omits all details that are not relevant to the information the schematic is intended to convey, and may add unrealistic elements that aid comprehension. For example, a subway map intended for riders may represent a subway station with a dot; the dot doesn't resemble the actual station at all but gives the viewer information without unnecessary visual clutter. A schematic diagram of a chemical process uses symbols to represent the vessels, piping, valves, pumps, and other equipment of the system, emphasizing their interconnection paths and suppressing physical details. In an electronic circuit diagram, the layout of the symbols may not resemble the layout in the circuit. In the schematic diagram, the symbolic elements are arranged to be more easily interpreted by the viewer.
Schematics and other types of diagrams, e.g.,
Transit map, a schematic map (i.e. not drawn to scale, stations are equidistant, lines are drawn at 45 and 90-degree angles)
Schematic of a drive train
Chemical engineering schematic
exploded view of a 3D-engineering drawing
Jan 22, 2016 | Computers & Internet
It says I need code to get some stationd
This could be caused by your channel receiver picking up a new channel, like a scrambled sky channel.
Do you have a standalone receiver like, MYSky or Free-view, Dish TV or similar.
These usually scan for new channels occasionally and find channels that need codes or are scrambled.
Maybe you have a content lock on the TV to prevent the viewer from accessing some channels.
Feb 11, 2014 | Toshiba 65HM167 65" Projection Television
My bose docking station is making a loud knocking sound when I put the ipod in it.
You have it plugged in, incorrectly! You need to look and find the symbol that is on the plug end and match it with the symbol on the back of sound dock. As time goes by the plug can get a little worn down allowing it to be plugged in, in any orientation, thus causing the knocking sound that you hear, that should fix the problem, enjoy!
Sep 29, 2012 | Bose SoundDock® (Black) Docking Station...
Red symbol (!) lit up on panel on ford fiesta flight 2001. What does this mean?
The red symbol means lubricant/oil is less than normal level.
Better check the level of your oil and add some until it reaches the maximum level.
Next time you put on some petrol/gasoline, ask the station attendant to check your oil level and ask him to add some oil.
Hope that helps!
Oct 01, 2011 | Cars & Trucks
How do i put the code in on my blaunpunkt freiburg cd34
Blaupunkt Freiburg Code Entry
Turn on the radio, the display will show 'CODE'
Press preset [ 1 ] repeatedly for the first digit followed by [ station + ] Press preset [ 2 ] repeatedly for the second digit followed by [ station + ] Press preset [ 3 ] repeatedly for the third digit followed by [ station + ] Press preset [ 4 ] repeatedly for the fourth digit followed by [ station + ]
Finally press the [ station + ] button to save.
Jun 28, 2011 | Car Audio & Video
I cannot put in tv stations manually the auto search doesn't pick
cant help you there, Most TV's have a little flap you lift up to access a little wheel and switch that has 4 regions you start at 1 and roll the wheel till a station is found and is cleasr to view. then move on to the next set of switch and wheel to rotate that to get a different channel. If your TV does not have this manual input then you can only do it from either the remote or some buttons on the TV itself
Jul 30, 2009 | Televison & Video
Toshiba tv 2151tb how do i tune in stations
Toshiba TV 2151TB Tuning
Press remote button adjacent to the picture brightness button.
The symbol of a clock appears.
Press the button again and the >>> symbol appears, this is for course tuning.
Touch the Increase Volume button and auto tuning starts.
When a station is found two green underlines appear.
Type the station number i.e.for 2 type 02, this stores the station.
Touch the Increase volume button again to find the nexr station.
Upto 39 stations can be stored.
Fine tuning of any station is achieved by pressing the tuning button until three blocks sysbol is displayed.
Use the Increase/Decrease Volume buttos to fine tune the station.
Feb 24, 2009 | Toshiba 19A26 19" TV
Codes
you problbly put the machine in "keyboard 2" mode, just put it back into "keybrd 1"
Nov 19, 2008 | Brother EM-530 Typewriter
StarTech.com StarView SV211K 2-port KVM Switch Logo
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
