Question about Uniden Cordless Phone
My 29115 cordless phones- all 3 make loud squealing noise when turned on- unable to use them they are all amplified and used away from the base unit. I've used them for months now successfully. The answering system on base unit still works fine. Other phones in my home on same line are working fine. If I need new batteries in the cordless phones why would all 3 have the same problem at the same time?
  • 1564 Answers
See if in the menu choices there is an option to reset all factory defauts. It seems someone has mistakenly locked out the other to units. Can you still use them as intercoms?
Posted on Aug 13, 2009
SOURCE: Uniden cordless model DC7758-4
Does the Uniden cordless phone model DC7758 have an answering machine?
Posted on Aug 23, 2009
  • 20 Answers
SOURCE: I have a Guardian home security system and comcast
Guardian has the system programmed to answer so the can program it from their office when the bill isn't paid or to disconnect the monitoring..Usally it will answer after 9 rings,it has an answer machine bypass that works like this: someone calls the house and it rings a couple times then someone else calls right back it will give the data tones..Try it call your number and let it ring a couple times then hang up and call back and you will hear the data..Call and tell them you want the remote programming disabled..
Posted on Sep 13, 2009
  • 7993 Answers
SOURCE: Have a uniden DECT 6.0 with a corded main base and
You might have missed some relevant information while troubleshooting. Here is a link to the manual.
Select model and download manual.
Hope it helps.
Posted on Sep 14, 2009
  • 19396 Answers
SOURCE: We have a 3+1 Uniden
Try using the procedure below to reset the phone:
  • Disconnect all power adapter cables from wall sockets.
  • Remove all handsets from cradles.
  • Remove all battery from cradles.
  • Fit back the batteries in their handsets.
  • Place back handsets in their cradles.
  • Connect power cables.
The procedure above will reset the system and will re-sync handset (or handsets) to cradle. I wrote at plural because the phone system may have more than one cradle/handset.
If that does not work, then the phone is defective.In that case you will need to replace/repair the faulty handset or the whole system.
If there is no communication with base, then either in cradle or handset can be defective. In that case contact Uniden.
Contact - Uniden ' A World Without Wires
customer service phone numbers and support
First try the reset procedure described above.
Posted on May 18, 2011
I have a KX-TG6700 base station and 4 Handsets. When I have been calling on the handsets I have recently found that there is static on the line. Later I realized that there is problem with the DTMF being...
The KX-TG6700 manual at:
For best performance
Base unit location/avoiding noise
The base unit and other compatible
Panasonic units use radio waves to
communicate with each other.
For maximum distance and noise-free
operation, we recommend the following:
LPlacing the product away from electrical
LPlacing the base unit in a HIGH and
CENTRAL location with no obstructions
such as walls.
LRaising the antennas vertically.
LIf you use the handset near a microwave
oven which is being used, noise may be
heard. Move away from the microwave
oven and closer to the base unit.
LIf you use the handset near another
cordless phone’s base unit, noise may
be heard. Move away from the other
cordless phone’s base unit and closer to
your base unit.
Have you considered all these points?
Is there a way you can move the base station to another location in your house to see if the problem get better? I don't beleive your base station is faulty, I suspect interference from something.
I don't think the 2.4GHz set is causing any issues, but you never know, try unplugged it for a while to investigate.
If you do determine that the base station is faulty there probably isn't many options to get it repair other than sending it to Panasonic. May be cheaper to buy a new base station to go with your extra handsets.
Good Luck!
Mar 14, 2008 | Lands Phones
Loud buzzing while other phone is on base. Switching phones on base has no effect on issue. Taking phone off base hitting 'talk' helps with issue, but buzzing returns upon placement on base..
did you have "buzzing" Before these phones? Anything electrical fan etc on the same circut breaker of your house?. Or buzzing start recently with these already running. It sounds like your describing "electrical noise" and not really a issue with the phoned them selves. Try relocating the base if you have another open wall jack and on another circut. If you notice it goes away check whats all on that circut (wall outlet) that you unplugged the base from. depending on the noise or lack of at the new location it would probly be something running on there. ..
Hope this gives ya a solid start on a fix :)
Nov 13, 2009 | Uniden 5.8GHz Cordless Phone
Base unit cuts out and resets by unpluging and pluging in.
It sounds like your handset's battery is failing on you. How old is it? If it is more than a year or 2 old, you might want to replace it.
Nov 07, 2017 | Panasonic Cordless Phone Headset Headset
When i dial and press the talk butto, i still hear a dial tone...please help
Please follow these troubleshooting steps;
Tip 1 of 9
Move the handset closer to the base. The operating range may vary with environmental conditions and time of use. There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, you can conclude that there is nothing wrong with the phone. Consider trying a phone that operates on a different wireless frequency.
Tip 2 of 9
If you subscribe to DSL service for this telephone line, DSL filters must be plugged into EVERY phone jack that has a phone. The DSL signal can cause static/noise, squealing (similar to fax tones), caller ID disruption and other issues on your line. DSL filters block the high frequency DSL signals from being transmitted to the telephone. If you are not using the DSL filters provided by the telephone company, this will cause static/noise and possibly caller id issues on your phones.
In most cases, we recommend you connect the plug end of the DSL filter into the telephone jack, then connect a telephone cord between the filter and your phone.
Please contact your service provider to obtain DSL filters and installation information.
Tip 3 of 9
Other electronic products (i.e., 802.11 wireless networking products, radios, radio towers, pager towers, cell phones, intercoms, room monitors, televisions, personal computers, kitchen appliances and other cordless phones) can cause interference with your cordless phone. Try installing your phone as far away as possible from these types of electronic devices.
Tip 4 of 9
To get better reception, try moving the telephone base to higher location. Relocate telephone base near a window if using telephone outside.
Tip 5 of 9
Excessive background noise will cause a speakerphone to fade in and out. Try controlling the background noise by turning off any audio devices near the speakerphone. Also, try to avoid interrupting the person at the other end of the conversation while they are speaking. If background noise cannot be controlled, you should terminate speakerphone operation and return to normal handset mode.
Tip 6 of 9
Disconnect any other equipment that is connected in series with your phone. If you phone begins to perform normally, there is a compatability issue with your other equipment.
Tip 7 of 9
If your phone shares a power outlet with a modem, or if it is plugged in to a shared surge protector, try plugging the phone (or modem/surge protector) in at a different location. If this solves the problem, re-locate your phone or modem farther apart from one another, or use separate surge protectors.
Tip 8 of 9
There may be places within your environment that a cordless phone will not work well. If the problem only occurs in certain areas of your environment, there is nothing wrong with the phone. This is normal radio operation.
Tip 9 of 9
You may have a line problem. To test for a line problem, test your unit at another location such as your neighbor’s or relative’s house. If your unit works at another location, contact your local telephone company
May 01, 2008 | Vtech Cordless 6041 Phone
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
it sounds like it has to being interfered with by some other appliance maybe cell phone radio wireless network maybe. check and see if everything you have wireless isnt running on the same frequency or being interfered with while around the phone.
Jan 14, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Uniden powermax x 2.4 ghz lost call
If it's in warranty, I would send it back. It sounds like a problem with the built-in amplifier and possibly other components.
The squealing and echo is down to gain being too high, if you cannot set this on the phone, then it's a fixed value in the hardware. If you can, lower the gain. As for not being able to end the call, what about pressing the "c" button or the green button again?
Dec 29, 2007 | Uniden Cordless Phone
Unable to Play Messages on Base Unit
I called Panasonic on this problem....ended up sending the unit back for a free replacement. Guess thats the solution for this problem.
Dec 07, 2007 | Panasonic KX-TG6700 Cordless Phone
Uniden Cordless Phone Logo
103 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
