Question about Avaya Partner ACS T1 Card (700241813)
Problem with DID numbers not reaching the intended
Avaya Partner acs. Problem with did numbers not reaching the intended extension. T-1 circuit is voip programmed as T-1 cas. Did tables are built and active in system but all did calls go to extension 10. Any suggestions?
Double check the DID mapping. The default of the system is to send the calls to unmapped extensions to ext 10.
Verify the correct digits are being sent, and that is programmed in your T1 programming..
Posted on May 14, 2010
2 Suggested Answers
SOURCE: Problem with DID numbers not reaching the intended
Because they are routing to extension 10, that means there are not valid routes for them. How many digits is the LEC sending? MAKE SURE that they are sending what you have programmed.
Posted on Mar 20, 2010
Tip
Change time/date on Partner ACS processors
<i><b>Partner ACS, any release</b></i><br><b>Changing the time on a Partner system must be done from extension # <b>10 </b>or <b>11</b>.</b><br><b>1. At station(Ext.10 or 11) press feature, 0, 0<br> 2. Press the left intercom 2 times<br> 3. Enter # 103<br> 4. Enter the correct time in 24 hr. format, for example:<br> * to set the time for 09:00 A.M., enter 0900<br> * to set the time for 04:45 P.M., enter 1645<br> 5. Press feature, 0, 0</b><br><a href="http://www.Telemanuals.com"></a>
on Jul 17, 2008 | Avaya Partner Control Units and Cards:...
How do you change the time on the Avaya phone 700340193
Changing the time on a Partner system must be done from extension # 10 or 11. 1. At station(Ext.10 or 11) press feature, 0, 0
3. Enter # 103
http://dstech1.com/changing-time-on-a-partner/
Nov 11, 2011 | Avaya 700340193 Corded Phone
My customer has a Partner Mail VS 4.0. At times
Never heard that one before, you might try # 306 and see if the return extension is itsself.
Apr 16, 2010 | Comdial Avaya Partner ACS Phone
Mar 19, 2010 | Avaya Partner ACS T1 Card (700241813)
I bought a used avaya partner phone system online. It came with Partner mail vs module... I cannot access the menu for voice mail to set it up... Avaya directions say pressing (intercom) 777 but all I get...
Did you really think it was going to be that easy?
You have to program the VS in the proper hunt group (7) to make it work. For example, if you put it in the 2nd slot, because it was only a 2-slot carrier, it would become extensions 22 and 23 on a 2-port license and 20-23 on a 4-port. The Partner Mail is installed to the right of any 206 or 400 cards, so that you don't have any holes in the extension numbering plan.
Here's a manual for the VS R4. It should work for your system for the basic installation. http://public.carl.airpost.net/Avaya/Partner%20Mail%20VS%20R4%20Installation%20and%20Programming.pdf
Page 35 is your installation information and page 50 tells you how to program the ACS.
Good luck.
Carl
Nov 05, 2009 | Comdial Avaya Partner ACS with Voice Mail...
AVAYA PARTNER ACS PHONE SYSTEM - Separate Greeting
Changing the time on a Partner system is done on either ext 10 or 11. At one of those ext's press the feature key and "00"
next press the left hand intercom twice
the display should say system programming
enter in "#206"
the display should say Group Call Distrib Group:
Press 7 It will then ask for a line number
enter in 05
the display will say 1 assigned
press 3 VMS Line Cover
Do the same procedure (from #206 on) for line 6
Then enter #208
The display will say Line Coverage Ext Line:
Enter 05 The display will then say Data --
Enter in the extension you want the voice mail to pick up the lines on
Lastly if its not done allready, enter #301
The display will say Automatic VMS Cover Extension:
Enter in the extension number of the phone thats getting the voice mails
The display should say 1 Assigned
press feature "00" to logout
Oct 06, 2009 | Lands Phones
I can't set up the intercom system on my Avaya Partner ACS R7
To program a page button for other extensions.
At the phone, press Feature 00
press the LIGHTED button you want to program.
press the LEFT intercom button, followed by * (star) and the 2 digit extension number.
Repeat for more buttons.
Feature 00 when done.
Now you can just press the button, and it dials intercom *10 (example)
it will activate the speakerphone and you can talk.
Jul 09, 2009 | Avaya Corded Phone avaparp18d
I have a partner vs voicemail system release 5. When the auto att
You have a selector code that is disabling transfer operations. Login with administrative account find selector code assignment (under Auto Attendants (3)) find a selector code 1 or 2 and see what it does. Change it to direct extension transfer . In a partner selector code 1 and 2 shouldnot be used.
Cheers
Apr 06, 2009 | Comdial Avaya Partner ACS Phone
Avaya Partner ACS T1 Card (700241813) Logo
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
