Replacing drives on Vinpower CD Duplicator
The top drive is no good on my old VP-2100 Duplicator.
There's no warranty or service contract.
It will not read or burn discs, and is noisy.
Can I swap in a replacement compatible drives ?
    Genius:
  • 1,019 Answers
Can,t see why not.
any ide drive should be compatable, i,d reccomend a Pioneer 112D. great drive reads and writes virtually Anything.
Mike @ compurepair.
Posted on Apr 04, 2008
SOURCE:
I am trying to replace the optical drives, but cannot figure how they slide out. Cannot get the front cover off, and it appears they do not have clearance to be removed from the rear. Mehod for this?
Most PC's are the same. The front cover is removable. Most have taps and some swing once the tabs are released. See photos.
The dvd in almost all cases removes from the front. Start the removal by either removing the screws or releasing the tab Slid the DVD out s little to facilitate the cable removal.
Hope this helps?
26214332-hbkptpu4rouqiogb1anremyp-5-9.gif 26214332-hbkptpu4rouqiogb1anremyp-5-0.gif
Jun 07, 2016 | Vinpower Digital 1 to 7 LightScribe Dvd /...
Job Error Code:68 (VinPower DIgital Unit)
Error Code 68
System error code 68 means "The name limit for the local computer network adapter card was exceeded." This error code may also display as "ERROR_TOO_MANY_NAMES" or as the value 0x44.
I don't know what this has to do with using lightscribe and burning the CD's but perhaps your running this over a network?
Good information here and his solution near the end of the article:
Fix Windows error The name limit for the local computer network adapter...
Hope this helps good luck!
Mar 11, 2014 | Vinpower Digital SharkCopier 1 to 12...
Target drive not ready
The burning drives are not recognizing the blank media.Try using all of the duplicator bays by burning to another drive bay. If all other drives burn fine then the one drive may need to be replaced.Try a different blank CD or using a different brand. The most common fault for this message is a bad blank disk.Finally clean the drive bays by using compressed air to blow any dust out of the system.
Dec 18, 2013 | ProDuplicator Computers & Internet
My produplicator will not display the lcd screen
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electric extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket
hope this helps
Apr 30, 2011 | Tower Produplicator 5 SATA Burner DVD CD...
I have a Pioneer CD/DVD Duplicator 8 drives. Recently no matter what disc I put in as the master. It tells me I have a mad Master Disc. Obviously all the media can't be bad. When this messgae pops...
The 3rd drive is the master now. If you want to change back to top drive, go to #8 "select source" and use up/down key change to " drive 1 " and save. for more detail, please read the user manual page 21 and 22.
For VPD system,if the top drive defected, the system should auto assign 2nd drive as source, but your system pick up 3rd drive as source drive, I suggest you check drive 1 and 2 before make copy.
Jan 04, 2011 | Pioneer 1 to 7 DVD Duplicator: SharkCopier...
The controller only burns to 4 out of 5 drives and 1 of the 4 working frive keeps making burn errors. Is it time to install new firmware to fix this? or do i have to install new drives? Can i install...
Hi I have this problem with my systor 0-3 target duplicator, the one tray works fine, the middle one keeps making burn errors and the bottom one won't burn at all I can't seem to find a solution
Sep 20, 2010 | Vinpower 16x CD / DVD Duplicator with NEC...
Manual Needed
hello i would like to know how do i duplicat a cd
Jun 30, 2008 | Vinpower 16x CD / DVD Duplicator with...
Accutower duplicator
accutower won't burn cd it says "no clear cd'
Apr 08, 2008 | Tower ACCUTOWER CD "Music" 5 Writer...
Vinpower 1 to 4 not seeing 4th drive
I would make sure all the cables are secure and possibly reconnect them to ensure a good fit. Do all the drives show up in the BIOS or Disk Manager? If not and they are all connected, it may be defective. Also check power connections, does the light on the drive work at all?
Mar 28, 2007 | Vinpower SharkCopier 1 to 3 (VP4690PIO103)...
Computers & Internet Logo
375 people viewed this question
Ekse
Alun Cox
