Re: lg tower xp install
thanks for your reply. ive gone into the bios and boot device priority but it was not on HDD neither is there CD/DVD. all there is, is removable device,
hard drive, intel (r) boot agent ve, disabled and atapi cd-rom which ive tryed but all it says then is - no boot file name recieved, boot failure - system halted, media test failure check cable. any ideas?
    Genius:
  • 1,019 Answers
the boot device setup in the bios, if you set atapi-cd rom as first boot device. then hdd second. and fdd last.
it appears that you have a faulty connection from the IDE ( 40-80 wire cable ) that runs from the motherboard Primary/secondary slot. check the cable goes from motherboard to hard-drive and is connected firmly, also check the jumper blocks ( small white plastic block ) is set to master or slave on both devices ( cd-hard-drive ) if both on same cable set hard-drive to slave and CD rom to master. if they are both set as master or slave, they will conflict with each other.
if you need further help, please mail back.
mike @ compurepair.
Posted on Mar 29, 2008
Gigabyte G41MT-S2P can't boot on cd/dvd rom (installing win7)
If both the HDD and the CD/DVD drive contain bootable devices, the BIOS will usually ask just before starting the HDD boot, while still on the black screen, "Press any key to boot from CD". If you don't watch for this (it's usually at the very bottom or top of the screen), then the system will boot to the HDD.
Jan 18, 2012 | Computers & Internet
I have hp compaq nx 9020 and I installed linux as my only os, but now I want to change my os to xp but bios says "no boot file name recived" how to fix this?
It seems as if you have some of your boot priorities out of skew, specifically having booting through your network connection as a higher priority. In order to fix this, you need to go into your bios settings and rearrange the boot settings so that booting from LAN is either disabled or not the top priority and making booting from CD or HDD the top priority.
May 23, 2011 | HP Computers & Internet
Hi i have a compaq evo can start can boot..do not star
1.FIRST YOU DO ONE THING IF YOU USING XP OS MEANS CHANGE THE SATA MODE TO IDE OTHER WISE CHANGE THE SATA MODE TO AICH.
2.IF BOOT WITH CD MEANS CHANGE BOOT PRIORITY CD/DVD ROM
2.IF YOU BOOT WITH HDD MEANS CHOOSE HDD.
BIOS OPTION----CONTINUOSLY PRESS F2 KEY.
or
insert the os dvd and then perform the repair
Nov 18, 2010 | Compaq Evo N610C Notebook
Hi i have a portege s100-s1133, i try to install new os but the hdd cant not detected, but if i tried to boot into windows the hdd are detected. and im tried to go to bios settings because i want to change...
Nov 17, 2010 | Toshiba Portege S100-S1133 Notebook
A default profile could not be created because your Mobile Broadband (WWAN) device was not found for xp
Nov 17, 2010 | Acer Aspire One AOA110-1113 Netbook
No bootable device for acer aspire 4730zg
BIOS OPTION----RESTART YOUR SYSTEM AND THEN CONTINUOSLY PRESS F2 KEY.
Nov 17, 2010 | Acer Aspire 4730-4947 Notebook
Need to reconfigure start up on IBM computer. Windows xp at present, want to put Ubuntu on instead. When I press F8, I get safe mode options etc. Need to get to page before this, re: make cd drive the...
to make cd/dvd drive the primary one..all u gotta do is to configure the bios(press DEL/F1/F2/F10 briskly, as applicable while at the system boot, this'll enter u in the CMOS utility, search for boot Device Priority)..make cd/dvd drive the primary or 1st boot device n 2nd device @ HDD 0..
download n install any boot manager (various are available)..eg. Power quest Boot Magic..it'll b quite useful when u wanna selective startup using Multiple OS like win xp pro sp2+ubuntu..
the best is to install ubuntu first in raw/undefined hdd space next go for xp..
always better to seek professional supervision of ur System admin/vendor....
Nov 04, 2009 | IBM NetVista PC Desktop
Reboot windows XP
This problem might occur because "USB 4" might be a bootable device. To prevent "USB 4" from booting, Enter your BIOS and go to the 'boot priority' section.
Set it in this order: 1. CD/DVD Drive 2. Removable Devices 3. HDD.
IF that does not work, place HDD as the second priority and Removable Devices as the third.
To enter your bios, Hit F2, F12, or Delete repeatedly. I am not sure which key it is for your motherboard, but hitting all those buttons should do the trick.
Dec 29, 2008 | Dell Dimension 4600 PC Desktop
Lg tower pc
you need to go into bios at startup, press F2 Or Delete Or Esc on bootup. When you get into the System Bios. Change the boot device priority from HDD To CD/DVD To boot first.
Save/exit And when you reboot ( with windows XP in the Drive ) you,ll get options to format or re-install.
Mike @ Compurepair.
Mar 29, 2008 | LG GMA-4082N DVD±RW Burner
System is no boot neither with cd-rom nor hard disk
Hi, Based of your post/description and assuming not hardware problem, you may have to set up the priority boot device in the BIOS to CD. This will tell your mb to look for a boot medium from the cd first. This is normally in the Advance Setup/1st Boot Device. Of course soon as installed, you have to boot from the HD next time. Good luck and kind regards.
Aug 14, 2007 | Intel Motherboard
Computers & Internet Logo
113 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
