Question about Lexmark Z640 InkJet Printer
I have z645 printer
The printer was working fine, printed a 20 page document and ten minutes later tried to print something else and it won't budge. Got a msg on the control panel under faxes and printers that it was ready and 5 jobs are in que. I tried turning the printer off for 15 seconds and that did nothing as well as rebooted the computer.
I need Laxmark Z645 Printer Driver & Software
Posted on Mar 30, 2008
SOURCE:
Mg5500 prints everything twice
Usually it is easyer to unplug the printer uninstall everything restart the computer and reinstall the printer ad driver rather than trying to find what the problem is ,
Make sure you read and follow Every Step provcedure of the installation process
Apr 10, 2014 | Canon Office Equipment & Supplies
I set something up to print and it only prints a half a page
Can you save your document to PDF and try to print it again? Sometimes there is 'corrupt' postscript information in your file, and when you make a PDF first, it will be solved. If you do not want to make a PDF first, try to print your document page by page. It also could be a memory problem. That sometimes will be solved by shutting down your printer, wait a minute than switch it on again. So, you can try these three things:
1: Shut down your printer, wait a minute switch it on again, than try to print your document
2: Print your document page by page
3: Make a pdf of your document first, than print the pdf
Succes!
Nov 30, 2011 | Canon PIXMA MP495 InkJet Printer
I have installed a new ink cartridge and the z645 printer. It sounds and acts like it is printing, but the page is blank. After I first installed the new cartridge, I printed a test page, but only about 2...
Doing the "clean printhead/cartridge nozzles" multiple times would have cleared clogged nozzles. You can also try to manually wipe the cartridge nozzles with a slightly moistened soft cloth. If that still won't help, try to replace your cartridge with a different known working cartridge to determine if your other cartridge is faulty.
May 08, 2011 | Lexmark Z645 InkJet Photo Printer
HOW LONG DOES THE INK CARTRIDGES LAST CAUSE, I ONLY PRINT AROUND 20 BLACK COPIES AND MAYBE 7 COLOR AND NOW IT DOES NOT PRINT, I ORDERED THIS PRINTER LAST 8/31/2010
Hi!
I know that if you switch your machine on and off often it uses a lot of ink as it needs to do checks and make sure that the ink is okay and that the purge unit sucks ink okay!I am sure that you should get much more pages out of your cartridges for sure!!Try and keep your printer on and not print one page now and then ten minutes later another one,print as much pages as you can at a time!!Hope it helps!!!!
Cheers!!
Jan 21, 2011 | Dell V313w AllInOne InkJet Printer
Lexmark Z645 can print locally, but will not print off of citrix
Lexmark X and Z series printers do not function in a Citrix environment, see page 4 on the following document.
ftp://ftp.lexmark-europe.com/brochures/de/solutions/citrix_basic.pdf
Apr 13, 2009 | Lexmark Z645 InkJet Photo Printer
Hi! I'm getting the following message on my computer screen: Error Number : 306 A communication error has occurred. Make sure that the printer is plugged in, powered-on, and properly connected to your...
Do the following:
Try a different usb cable.
Plug the cable into a different USB port.
Try disconnecting printer power cable for ten minutes.
Unplug computer power cord for ten minutes and restart.
Reinstall printer drivers.
If that all did not work, test the printer on a different computer, to find out if it is faulty or not.
Sep 19, 2008 | Canon Office Equipment & Supplies
Prints only one page
what does the page que show?
so if you print 10 pages, it prints 1 but does the que show anything or does it show 9?
Jan 01, 2008 | Lexmark Z640 InkJet Printer
After changing cartridge, printer will not print, z645?
First... check to make sure you removed the yellow tab from the new print cartridge
put the ink cartridge back into the printer
click Start
click Control Panel
open Printers and Faxes
click (or double click to open) your printer icon
click on Printer menu
click on cancel all documents
Then try printing again.
If this does not work, look in the manual that came with the printer and check out the troubleshooting section.
Dec 18, 2007 | Lexmark Z645 InkJet Photo Printer
Printer
Have you defragged and scandisked lately?
Are you doing anything while printing.
printing takes a lot of resources. you may also want to buy more ram.
Nov 16, 2007 | HP DeskJet 940c InkJet Printer
My printer(hp laser jet 1320) dosen't print correctly in more then 30 pages.
sounds like a memory issues or a windows swap file problem. when printing large docs u need to have some free memory in the computer. Also some printers 2 day used windows memory to print so if your pc only has small amount of free memory it can effect printing out large docs. also with a laptop it shares it memory with the video GPU. so you may need to upgrade your memory in your laptop .
Sep 25, 2007 | HP LaserJet 1320 Printer
Lexmark Z640 InkJet Printer Logo
53 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
