Question about Health & Beauty
Shaver Stopped. May need power unit series 569 class 2 for series 1 150
2 Suggested Answers
brector3
  • 1624 Answers
SOURCE: Shaver Stopped. May need power unit series 569
By 'power unit', it appears that you are referring to the power/charging cord. If this is the item you require, you will find this item for model 150 (series 1) at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/braun-charger-cord-for-select-models.html
Posted on Mar 20, 2010
Testimonial: "Razor stopped. Wouldn't charge. Needs battery??"
Braun Problems: Cutters
Try removing the foil and cutter head. Wait a few minutes and then refit them. It may be on some sort of electronic timer that after so many hours of shaving, the unit automatically comes up with a "change foil" icon and then wont let you use it until its replaced.
Jan 28, 2018 | Braun Series 7 790 Pulsonic Shaver System...
The screen on my braun shaver has holes and needs replacement can i get new ones for it? its the one that says caution for use only with braun series 549 class 2 power unit www.braun.com it has a trimmer...
Braun 8985 replacement foil and blades is braun series 5 combi 51S foil and cutter replacement pack.
But costomer reviews in amazon.com who take braun series 3 combi 30B foil and cutter replacement pack is fits to Braun 8985 perfectly, very smooth and close shave. Shaves much better than the Braun 51S screens foil.
You consideration
http://www.amazon.com/gp/community-content-search/results/?ie=UTF8&search-alias=community-reviews&tag=best-electric-razors-20&Go.x=0&linkCode=ur2&query=braun%208985&camp=1789&Go.y=0&creative=9325&idx.asin=B001VH6F9G
Sep 16, 2011 | Braun 360° Complete 8985 Electric Shaver
Charger arm will not stay locked in place to charge the razor
This is a common problem for older cleaning bases. The part is worn out. You will need to replace the upper housing of the cleaning base. You will find this item available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
If repairing the unit is not your thing, you can replace the entire unit instead. See item linked below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Jul 08, 2011 | Braun Syncro 7526 Electric Shaver
When I power on to the first setting(shave head pivots) it makes a very loud noise like the insides are loose. On the second setting(pivoting head locked) it gets quite a bit quieter. and if I hold my...
You will find a video for disassembly of the shaver at shaveroutlet.com. See link below
http://www.shaveroutlet.com/braun_syncro_shaver_disassembly
However, I seriously doubt that tightening anything is the problem. More that likely, the oscillator inside the swivel frame is cracked and causing the sound. You will probably need to replace the drive unit. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-motor-drive-unit-p-110.html
May 24, 2011 | Braun Syncro 7526 Electric Shaver
My Braun series shaver recently stopped working. I have tried to charge it, thinking thats the problem, but thats not it. It started again, but stopped a couple days later. Its 1 year old. What are...
If it is intermittent, that sounds like there is a bad connection inside. Braun has a 2 year warranty. If it is only one year old, call Braun at 800-272-8611
Oct 21, 2017 | Braun 360° Complete 8985 Electric Shaver
Mar 19, 2010 | Braun Health & Beauty
Won't turn on unless we pop the top foil up..then we have to push it back in place.
this is an odd problem. i have two thoughts of what the problem may be.
1. the thin trimmer blade between the foils may be dented causing extra friction that is sufficient enough to keep the shaver from starting from a stopped position. If this is the case, you will need to buy a new foil and cutter set. These are available at shaveroutlet.com. to check this, remove the foil from the shaver. look on the underside and you will see where this center cutters fits to the drive arm on the shaver. move this back and forth with your fingers. if it has a dent or imperfection, you should be able to feel it snag as you move it back and forth
2. your shaver motor brushes may be worn. if this is the case, i would expect that when you do get the shaver running, it is not running at full speed. the part needed to repair this problem is linked below
http://shaveroutlet.com/braun-7000-series-syncro-motor-drive-unit-p-110.html
Jan 17, 2010 | Braun Syncro 7526 Electric Shaver
Braun 7526 not charging the + light wont turn on? how can i fix this?
In your case, it's hard to know exactly what might be wrong without more information. Was the shaver perfectly fine and then all of the sudden won't turn on? Or was the shaver working for shorter and shorter periods over time and then just quit? Was it exposed to undue heat, such as left in a car or in a place that wasn't air conditioned in the hot summer?
Although the batteries in these shavers are fairly robust, if fully discharged and not used for a long while, it might be that they've got a "low level memory" and will need replacing. If you are handy, you could disassemble the shaver and replace the batteries. They are NiMh AA flat top batteries that you can buy on websites like onlybatteries.com. If you're handing with soldering, you can replace them yourself. If you're unsure about that, you can buy the batteries along with the circuit board as a complete unit that drops right into place. Shaveroutlet.com sells these.
Another thing is that if the shaver was dropped, there's a chance that a metal connector part has come loose and so the shaver won't function. Taking it apart, you can see if this is the case.
The Braun 7000 series are rather old at this point, so sending it off for repair is kind of out of the question, as the costs involved would be more than if you bought another shaver. If you're not wanting to spend the big $$ on the new 9000 series shavers, find a new old stock 8000 series shaver (they are better made than the 7000 series). You can search on "that auction site" and you'll find quite a few Braun 8000 (or 360) series shavers available for sale.
Sep 25, 2009 | Braun Syncro 7526 Electric Shaver
Health & Beauty Logo
107 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
