NAD 302 AMP FAULT
My NAD 302 amp cuts out after running for about 1 hour. Switch off leave for a while and it comes back on again. Any ideas please.
    Genius:
  • 1,550 Answers
Checa si las bocinas estan bien ,despues checa si no hay componentes recalentados en el si no los hay ,los ICs amplificadores de audio estan a punto de tronar
Posted on Apr 04, 2008
I have a NAD 275BEE amp and a NAD375BEE pre-amp running into a Omage 6 Zone speaker switch. I have been running at 3/4's volume or 3:00 o'clock and after a couple of hours it is now kicking out and th
Turn the volume down a tad and you should be ok. I would suggest getting a larger amp, bridging can cause some interesting problems and has an impact on the dampning.
Dec 11, 2014 | NAD C 275BEE 2Channel Amplifier
NAD 272 Channel drop out
well..this is one for the books. Can you tell me what the ratings are between the 252 and the 752 impedance matching wise? even though it might work sometimes, impedance matching can wreak havoc between mismatched amps.
what are you driving from the 752 into the 252?
Mar 10, 2008 | Audio Players & Recorders
Nad c320bee keep over heating
Hello
Disconnect all speakers and switch ON the set without any input connected, and see whether it heats up. A moderate heat is permissable, but should not over heat. If it overheats without any load or input connected, the set need service. OK.
Jan 19, 2012 | NAD Audio Players & Recorders
Hi, I have a NAD C162 Pre-Amp which I am using with a NAD C270 Poer Amp. Th problem is that the Pre-Amp doesn't seem to be driving the Power-Amp efficiently. By this I mean i need to turn the gain up...
Hello, I have an idea:
at the rear side of the NAD preamp there is a switch, it can be in mode MM or MC . Please check it whether it is in right position or not.
Good luck,
gylacz
Feb 15, 2011 | NAD C162 Amplifier
NAD 302 PHONO STAGE
Reverse your RCA input around and see if the problem follows, this will determine if the problem is in the turntable output signal or the preampsection of your amp. If it stays on the same channel, slightly move the RCA that's dropping out signal around. If the signal cuts in and out, you know it's just a weak solder joint on the input rca of the amp. If it does not change, your problem is deeper. Chances are it's a "cold solder joint" on the input section of the amp and would only be a labor type repair and no parts involved. That can be a double edged sword as well depending on how long it takes to find it. If you have to have it serviced, find a local shop that's been around a while, they are likely to be a little more insightful as to the exact problem quicker. Hope this helps
Jun 26, 2009 | NAD C372 Amplifier
Need manual for ra 840bx4 & wattage output when remote speakers?
Lets try the simple stuff first. This whole problem could be caused by a dirty switch contact. Pick up some electronics cleaner from a local electronics shop and spray the switch (from the inside of the unit). Work the switch on/off a number of times then respray one more time. That should clean out any dirt that is there. Try the unit again and hopefully the problem is resolved. If not, then the switch itself may need to be replaced. When you get the cleaner, get one that contains a lubricant as well. This will help to prevent the problem from coming back again.
Dan
Jun 20, 2009 | Rotel Audio Players & Recorders
Crackling power switch on NAD 3220PE
Hi, i would try flooding trhe switch with CRC 2-26 for a start. Itr may recover some contact integrity. A jerry rig solution would be to bridge the switch contacts and leave it on all the time(i leave my amps running all the time) or if as in Australia you have a switch on the wall socket use that,
OR purchase a new switch from here. Not sure how you would go through NAD, probably dont have any in stock as a spare these days.
or if that does not work out, I could get one to you through ebay. Used to be quite a common TV switch, but I also remember replacing then in Nad amps, many moons ago ;) I think I still have a one in stock myself, packed away from when I was a NAD service agent:)
regards
robotek
Nov 04, 2008 | Audio Players & Recorders
Sound cuts off
OK,  That means there's some kind of crazy fault in the temperature sensing circuits. I'm afraid you'll have to take it someplace and have it looked at for a more thorough diagnosis.
Aug 31, 2008 | NAD C325BEE Amplifier
Nad 302 amplifier
sounds to me that the vol control has lost its earth end connection So yes its a problem with the dial control You couls try some contact cleaner But better still lift of the lid and base if possible while the amplifier is not plugged into the power socket and see if you have a dry joints around the vol control pot regards Trev
Mar 14, 2007 | NAD CI9060 Amplifier
138 people viewed this question
 Grubhead
Grubhead
