Question about Honeywell Programmable Thermostat Heater
Honeywell Chronotherm iv fan keeps running even when heat and cool turned off. How do I turn it off?
  • Glenn Howe
    Glenn Howe Oct 29, 2016
    I see you can change the program to "auto" but the fan still turns on every few days? How do I set it to permanent off - short of pulling the poorly designed controller out by the wires...
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
To turn the fan off, press the "fan key" until it says "auto". This will turn the fan off. When the programs scheduled, changes, the fan will go on again. You have to repeat the fan to "auto" each time the schedule changes.
Posted on Apr 23, 2013
I can't turn my Chronotherm IV plus off! Can anyone help me. It is going to cost a fortune
Depends what model number you have. The older models had problems. So Honeywell upgraded the model several times. When you say, cant turn it off. If that means the heat will not shut off then you have no choice to replace it, also if the heat,cool, off,switch will not work it is not repairable. Go to Home depot or menards and pick up a thermostat. Find somebody with some handy man skills and they can replace it for you.
Nov 28, 2011 | Honeywell Programmable Thermostat Heater
I have a honeywell chronotherm iv plus thermostat and lost the manual. trying to turn it on, but not sure how to program it. any ideas? its getting hot out!
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
May 08, 2010 | Honeywell Electronic Programmable...
Assuming you have the fan switch of your thermostat in AUTO, it sounds like a stuck Fan Relay. If the fan relay is stuck, your fan will continue to run as long as there is line voltage being fed to your unit. This relay could be an independent component or it could be an integral part of your control board. Have an experienced, qualified service technician check it out.
Mar 19, 2010 | Honeywell Programmable Thermostat Heater
I have a very old manual Chronotherm thermostat.
No. The clock is just the set back timer. Pull the battery and use the stat manually.
Jan 26, 2010 | Honeywell Electronic Programmable...
My Honeywell chronotherm IV Plus thermostat intermittent problem
The Chrono Therm 3 and 4's were some of the worst products that honeywell has EVER put out. I would suggest switching to the Vision Pro 8000, please consult your local HVAC company for more information regarding the change over.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cody_17f08cf8e340c06c
May 11, 2009 | Honeywell Programmable Thermostat Heater
Fan Honeywell Chronotherm IV T8600
sounds like the fan has been programmed to come on during that time. run through your programming settings and make sure the fan is set to auto for all the times.
Nov 11, 2008 | Honeywell Programmable Thermostat Heater
I have a Honeywell Chronotherm IV Plus a/c unit and I can't get my air condt. to turn on. The room temp. says it's 17 degrees in the house so it won't turn on. I need to know how to reset the room tempt....
Not only are the Chronotherm IV's less than user friendly, they have a terrible failure rate. It sounds like one of the typical failures of the chronotherm IV. I suggest starting with a new thermostat.
Jun 12, 2008 | Honeywell Heating & Cooling
There are no batteries on an 8600-8601-8602 series
Feb 17, 2008 | Heating & Cooling
Heating & Cooling Logo
1,217 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
