Question about Refrigerators
Refrigerator collects water at bottom, under the vegetable/crisper drawers, needing to be sponged out daily This fridge is a 17.7 cubic ft. no frost TBX18BG
  • 3 more comments
  • PhilippeGo Feb 02, 2009
    Hello
    I have the same problem too, but how do you fix it permanently?
    I have to defrost the tube every 3 months. Thanks
  • Anonymous Mar 16, 2014
    PSCf5RGxafbb.
  • Anonymous Mar 18, 2014
    water collects under the crisper drawer
  • Anonymous Mar 22, 2014
    water is collecting under the crisper drawers. how do I fix this
  • Anonymous Mar 30, 2014
    would like to know the cubic in of my existing fridge
  • 109 Answers
At the top of the fridge section at the center back there is a drain assy/ tube for defrost water to exit the unit and go to the bottom of the outside, this is most likely clogged up. disassemble and clear drain line, hook back up and call me in the morning.
Posted on Mar 30, 2008
There is water collecting continuously at the bottom of my fridge under the crispers. Do you know how I can fix?
Most frost free refrigerators take water from the freezer so you do not have to defrost the freezer. That being said there should be a drain under the crisper. Check to see if it is clogged.
you may need to put something under the refrigerator to collect the water..
Jan 03, 2015 | Refrigerators
Water in bottom vegetable drawer and bottom of refrigerator ge profile side by side
This model has two evaporators, so Do you have an ice ball in behind the crisper (should be on the left)? Is there brown looking water going down the back and collecting under the crispers? I need two things, a complete model number (there is 8 different model with this number you gave) also where is the ice and water located? Thanks
Jul 25, 2014 | GE Profile PSW26P Stainless Steel Side by...
RF261BEAESP
Check the pipe that drains the water from the avaperator (the thing that gets cold inside on the fridge)
periodically your fridge will defrost and the water should drip through a tube and collect at the rear of the fridge
If the pipe is blocked the water collects inside at the bottom ( under the crisper)
Apr 15, 2014 | Samsung RF261BEAESP 25.5 cu. ft. French...
Model CTX18GAZBRWW - (Hotpoint) no-frost - freezer on top Water collects under the vegetable drawers and must be removed every day.
Something to try....on the back wall of the fridge nearer to the top is a little cup like part sticking out. There is water in it but it usually runs down an attached tube inside back wall and ends up under the fridge and gets evaporated. If that tube or the little cup thing is plugged then it will drip in the fridge and collect on the inside bottom of the fridge. So the trick is to clean them out. Check it out ...may solve the problem.
Sep 07, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
Water appearing in the refrigerator and collecting on the back of the shelves as well at the bottom under the vegetable and fruit containers.
could just be condensation,which is normall,have you put any uncovered/warm/food or salad/fresh fruit in lately,these all add to the"problem"there is no "fix "other than kitchen tissue under the salad /fruit drawers,and throw away once a week.fridges are not frost free.(condensation in freezer is frost)
Apr 01, 2010 | Refrigerators
There is water building up in the bottom of the fridge ( under the crisper drawers). If I leave it there it will freeze. What is causing the water? The fridge is 18 years old.
drain hose is plugged... the freezer it need to drain water when if goes into defrost .the drain from the bottom freezer down to the bottom of the fridge... there is a pan under the fridge that holds the water until it evaporates
Sep 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
I have a roper RT21AKXGW00 refrigerator and water settles in the bottom of it and in the crisper draws, is this some sort of blockage?
I have the same model refrigerator and don't have a solution but I think I have more information on the problem. In mine, water will leak periodically from the condenser leading up to the freezer (inside the refrigerator, at the top, center, back of the main compartment). I have seen it leak and it isn't a constant leak but when it leaks it can pour out at a pretty high rate.
In mine, the water will collect in the deli drawer (near the top), the crisper drawers at the bottom, and under the crisper drawers. When it happens, I use a sponge to soak it up and wring into a bowl.
To minimize the impact, I have set up a cup or dish near the back of the fridge to catch the leak. I empty this every couple weeks or whenever it fills up, but I'm looking for more information on a fix (I think the problem has to do with the condenser - that's the lead I got when I found this post).
Aug 01, 2009 | Refrigerators
GE Refrigerator, Model TBX22ZA
the drain hole is blocked in the bottom of the fridge. if the water is not able to drain down the hole it will overflow into the fridge base. check any holes at the inside back of the fridge.
Jun 11, 2007 | Kenmore 26.0 cu. ft. Side-By-Side...
Refrigerators Logo
639 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
