Question about NAD T760
NAD T760 I can't get my turntable to work through my NAD T760 amp. I believe you can't plug it in direct so I bought a NAD preamp but I don't know how that wires up and into which number video channel. I can get sound, but either very trebley or bassy. Any help appreciated. Thanks, Andy
You should connect the RCA connectors from your turntable into the phono input of the preamp. Also, make sure you have the grounding wire from the TT connected to the grounding on the preamp (if you do not have a grounding point, then just connect it to one of the screws on the preamp). Then connect the output from the preamp to either the Tape or the CD points on the T760. On the front panel press tape monitor and you're done.
Check and let me know how it goes. My set up's working fine except for clarity, which still needs to be perfected. I'm using a normal step-up phono stage.
Regs/ Avinash
Posted on May 26, 2008
Sorry, new at this and finding the manual hard to understand, how do I connect my nad C-340 amp to my C-162 preamp. Trying to add a turntable and have a few other questions
You must connect the turntable to the plugs on the left side of your amplifier when you are behind the pre amp. You have to know if you are using a MC or a MM element in your turntable and connect to the right plugs. Don't forget to put the switch in the right position (also MC or MM) The moving coil element is giving a very low voltage accordingly to the Moving magnet element. So it needs some extra amplification.
Nov 28, 2012 | NAD C162 Amplifier
Cant get no sound from my Nad C162 pre amp connected to my C272 power amp , and ideas please?
First prove if it's a preamp problem or an amp problem. Plug one of your sources directly into the amp for a moment and play something VERY LOW in volume. If the amp is ok it will play VERY LOUDLY.
If so, look at the preamp and make sure it's not muted or a tape is selected.
Apr 03, 2011 | NAD C162 Amplifier
How do I connect a Mirage Omni s-10 Sub Woofer and a Parasound Model 2100 Pre Amp to the NAD C372 Amplifier?
You DO realize the preamp is duplicating stuff in the Nad C372, right? This Preamps adds nothing but PHONO connectivity and control. That's why they're called "preamps".
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-C372-Amps-manual/id/8043dj592/t/2/
http://www.retrevo.com/support/Mirage-OMNI-S10-Subwoofers-manual/id/14438ag918/t/2/
Model 2100 Picture and article:
Use the Sub Out pair on the Preamp (joined by an RCA Y-cable) for the Sub Input on the sub (duh):
http://www.hometheaterhifi.com/preamplifiers/362-a-secrets-preamplifier-and-power-amplifier-review.html?showall=1
Run RCA from the Preamp Main Out to the C372 Aux In to hear any sources attached to the preamp.
Or, if you don't NEED the preamp because you don't have a turntable,ditch the preamp and connect the sub using the speaker outputs on the NADS, according to the manual.
Mar 08, 2011 | NAD C372 Amplifier
After about 15 minutes of gentle use my nad T760 makes a horrible & extremely loud roaring noise and has to be turned off immediately
This is caused by the breakdown of a transistor early in the amplication stages. If it can not be controlled at all by the volume control, that helps to narrow down the suspect transistor(s). This unit will require internal measurements with an oscilloscope to determine the exact source of hte noise. Unless you have access to this type of test equipment, this unit will need to see a servicer. I can try to locate the more probable parts, but I will need to know the exact model and serial number. There are differences in the circuitry depending upon the run/serial number.
Dan
Nov 01, 2010 | NAD C272 Amplifier
Filter capacitors in the amplifier are breaking down when they warm-up. Thus the low frequency noise are passing through the circuit which the capacitors are suppose to filter. Open the unit and inspect for capacitors which are bulging from the top - fattening. Replace these capacitors. Or send it to a repair shop - the problem is permanent unless you replace the parts.
Nov 01, 2010 | NAD Audio Players & Recorders
Connecting NAD 2600a amp.
Never connect incompatible connections. Speaker outputs are for speaker inputs. Period.
The various inputs on this or most any amp are for Line Level signal with the exception of anything explicitly labeled "PHONO" as that would be for a non-preamplified turntable ONLY.
From what I have found online, Lab-In was a NAD feature that restored the frequencies that were rolled off when turntables were being used in the (assumed) preamplifier that fed this amp.
http://web.295.ca/~peak//audio.html
"NAD belleived at the time that practical PHONO stages and the preamp and power amplifier stages be rolled off at subsonic frequencies to prevent subsonic wow and flutter from Turntables and supersonic frequencies (EMI/RF/Radio) signals from getting into the system in the first place. Their notion was that if your ears cannot physically hear it, then why amplify it. For the PURIST, there were a set of LAB IN amplifier inputs with more extended response called "LAB IN" inputs"
Use the Lab In's UNLESS you have a turntable source.
Aug 22, 2009 | NAD Audio Players & Recorders
No signal from sub connected to NAD T760 in test mode.
Try using front pre out to the sub from the receiver. the crossover is in the sub anyway. If this works change your settings on the receiver and test again. If sub is still inop, could be an internal issue with the sub amp. Does your sub amp have an on/auto/off switch or light? check that as well. Hope this helps, if you need further assistance, send a reply and I'll help some more
May 24, 2009 | NAD T760
NAD T760 remote control
You could buy a universal remote control and try the following NAD audio remote codes to program it with:
NAD
575 773 975
I read somewhere else that the 'Supplied Code for NAD receivers' was 033, but cannot confirm this. Try the first 3 first.
Universal remotes tend to be pretty cheap, certainly cheaper than buying one from NAD.
Good Luck
Chris (ziraffa)
Dec 20, 2008 | NAD T760
Sound through one channel
Only the right channel had a sound,the left channel is mute, whatever adjustment you did and whatever balancing you done nothigs happen,even you interchange the speakers. The problem is in the power amp. The STK IC there is busted already, it's better to change it with a new one so the performance become normal again.
Jun 14, 2008 | NAD C372 Amplifier
Connect turntable to NAD S300
Yes you will need a pre-amp for your turntable, there is no phono input on this amplifier. Please update the question & let us know if the information given was useful to you - Good Luck!
Sep 08, 2007 | NAD S300 Amplifier
NAD T760 Logo
344 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
