Question about Epson Stylus R290 InkJet Printer
Trying to print dye sublimation and colours have just started coming out paler
  • 32 Answers
Hi, have you checked or changed the pint quality and paper type in printer propertys? have you changed paper brand or type? Are you printing now from other program ? I've this problem printing in Corel but not in Photoshop, I don't know why, its probably the color managment system (ICC)
Posted on Mar 04, 2011
Ribbon not available
if this message appears only when you are trying to print, then most likely you have in the printer drivers a different ribbon set compared to what is in the printer.
Aug 13, 2014 | Fargo DTC 4000 Color DYE Sublimation...
Heat transfer mug without coating
Hi!
Sublimation Printing is the most common printing method on mugs. By theory, sublimation is offset printing from a transfer paper to your substrate (which is your mug). Mug Coating is important since the coat is composed of Polyurethane paint which is where the Sub-Inks adhere into. Without a Polyurethane coat, the Sub-Inks will not stick to the surface of the mugs. What you can do in order to print on non-coated mugs is to coat those mugs yourself using Polyurethane paints that you can buy at hardware stores. These are usually used in automotive painting and may cause you a bit for each can.
You have to remember though that Polyurethane paints dries longer than enamels and prolonged exposure to these types of paints is hazardous to your health.
It would still be best for you to look for pre-coated mugs to save on production time and, well, efforts.
And yes, I have tried the above tricks personally as I am also engaged in crafts business...
Mar 25, 2014 | Canon Selphy Cp-800 Dye Sublimation...
Blank print come
Tienes qcambiar a RGB al momento de imprimir oye yo nesecito el cd de instalacion no crees ayudarme?
Feb 18, 2013 | Hi-Touch Imaging HiTi Photo Printer S420 -...
Hi, we have an oki C5650 and use sublimation paper through the printer. We have had no troubles up until recently when we purchased a generic magenta cartridge. The red on pictures was bleeding off and...
I cannot understand why you are using sublimation paper on an LED printer which uses toner. I always thought that sublimation printing is used with dye and not toner. Why it worked in the first place is odd. Anyway I reckon you have worn out the fuser and or the fuser is not reaching temperature which is why its not fusing correctly.
Jun 13, 2017 | OKI C5650n LED Laser Printer
I want to use photo paper to print photos and the printer tells me I do not have the correct paper
When you give a print command (ctrl + P) You have the possibility to select the Print Properties. If you press that button, there has to be somewhere a possibility to select the right kind of paper. I don't know which kind of printer you have. This works well with inkjet printers. The settings in your driver has to match the paper you use.
If you have a dye sublimation printer (there is no ink, but a ribbon with coloured dye) you need the right brand of paper, because otherwise your printer doesn't detect the paper.
Jul 03, 2011 | Office Equipment & Supplies
Power Outage
Unfort don't have a solution but curious as to the ink you were using. Were you using OEM inks or dye sublimation ink from like Sawgrass ?
Jul 27, 2010 | Ricoh A3 Gel GX7000 InkJet Printer
My system is setup for dye sublimation printing. it has been perfect for 2 years, but yesterday, I noticed banding in the dark, heavy ink areas. I first checked the nozzles (clean) but I noticed the...
Hi, I recommend getting a set of Epson ink, run through a few head cleans and repeat the head alignment a few times if required.
Sublimation ink is a lot thicker than normal ink, this means a typical dye based printer may struggle over time. Genuine ink contains anti coagulants which prevent the ink from drying and a cleaning solution within the ink. If this doesn't work you can try removing and soaking the print head in distilled water but I would only recommend this as a last resort and only if your confident in doing this.
Jan 28, 2010 | Epson Stylus 1400 InkJet Photo Printer
I'm using an Epson 1400 for dye sublimation and have installed a bag feed system. The 1400 is alerting that the cartrages are not the correct cartrages for this printer and will not let me print. Is there...
Hi I know if you go into Start, Control Panel, printers & Faxes, epson 1400, right click printing preferences, maintenance, speed & progress, and click on Disable Epson Status Monitor - this stops the printer 'thinking' the cartridges are running out... Joy
Jul 01, 2009 | Epson Office Equipment & Supplies
No true colours in Epson Stylus Photo 1400
Given that you are using a dye-sublimation ink I have to ask if you're basing the colours you're getting on the results on your substrate or on the finished product (after you've done the heat transfer).
Beyond that you should probably ask the supplier if they have a colour profile for their inks. If not you can look for one of the services available. I can't make any recommendations but communication with this company has been quite positive
Sep 01, 2008 | Epson Stylus Photo 1400 Printer
Epson Stylus Photo R265 icc problems
Do you mean you are using OEM lookalike cartriges or are bulk refilling cartridges with non-Epson ink?
Thats your answer!!!
Feb 12, 2008 | Epson Stylus R265 InkJet Photo Printer
Epson Stylus R290 InkJet Printer Logo
46 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
