Question about LG Vu CU920 Cellular Phone
My phone will not charge any longer. It is not the phone charger as this has been determined by ATT.
My RCA tablet won't turn on and will not charge, what can I do?
If battery is depleted, then no, it will not turn on.
If battery charger is dead, phone won't charge or turn on.
If battery charger cable is broken, tablet won't charge or turn on.
You need to ensure you have a good working charger, and a good cable. Only a known good charger and a known good cable can charge the unit. Borrow or invest in a new charger and cable (they're cheap on eBay).
Only once you know the charger and cable are good can you determine that they are not the problem.
Depending on how old the unit is, it's possible the battery can no longer hold a charge and needs to be replaced. You won't know that though until you first determine the charger and cable you're using are working properly and providing a good charge.
May 07, 2015 | RCA RCT6691W3 9" 8 GB Wi-Fi Black Tablet...
Why can i not charge my cordless phone
Your phones charging port may be broke. Or likewise the charger dock maybe malfunctioning.
Oct 15, 2014 | AT&T ATT EL52510 Cordless Phone
Does wireless chargers lasts for longer time?
It is easy to use wireless charging pad than wireless charger.It provides extra protection to your phone as well while charging the phone middle of nowhere.It turns off automatically once your phone is 100% charged.It is of QI standard and is compatible with nexus 5 as well. You can plug it in when power is off or you are traveling.It is so easy and convenient.And about you asking if you could use it properly it will last for longer term.And here I give you a link of some charging pads and wireless charger.Those are some longer lasting products.
http://www.amazon.com/dp/B00I03LLUM/
Feb 11, 2014 | KONNET Technology KONNET PowerV Duo Wii...
Wont charge
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Sep 09, 2012 | ZTE Avail Bluetooth Music 3G GPS Android...
Wont charge
First Option:
Second Option:
Sep 09, 2012 | AT&T Avail
I have a Nokia 6650. My original cell phone charger was bent. I was still able to charge the phone if I positioned it a certain way for about a week and a half. Then, the phone would not charge at all. ...
Hi, Since you have already tried with new charger the problem is on the phone charging socket..
I believe a soldering action is required on that area..you must visit a repair shop...
Sorry about it..
Hope this helps!
Take care and please
Remember to rate / vote us
to continue f
or Helping out the Community :)
Thanks
Aug 17, 2011 | Nokia 6650 Cellular Phone
Can the phone be left on a charger for longer than necessary without hurting the battery. Will it quit charging?
The phone can be left on longer than necessary and it will stop charging and will not harm the battery. It is recommended that when the phone indicates a full charge, disconnect the charger from the phone, then from the outlet.
Oct 21, 2010 | Nokia 2760 Cellular Phone
Turn it on, the screen says ATT then shuts off
Check the battery if it needs to be replaced. Borrow same phone from a friend and use your battery on the other phone and check if it will turn on or will just do the same thing and shut off after the ATT... if it did the same thing...replace your battery.
May 12, 2010 | Motorola Mobility Z9 Cellular Phone
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
LG Vu CU920 Cellular Phone Logo
12 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
