Question about Home
Toilet system will not completely stop dripping, resulting in constant drip from overflow. How do I stop it?
  • 349 Answers
Check your float for adjustment, water level should be within 5/8 of an inch from top of overflow pipe. Water shouldn't be filling up and running through overflow pipe.
Depending on your fill valve a fluid master has a level adjust on the fill valve to adjust.
A tank with a arm with a float ball on it has a screw on top of fill valve to adjust height.
Also check your flapper out also for sealing correctly.
Posted on May 28, 2010
    Scholar:
  • 102 Answers
Is the drip comming from the small fill tube going into the overflow? If so you may need to raise it a little. The nost common leak is from the flapper or seal. On rare occasioms the flush valve itself has a defect that will cause it to leak. Take a close look at the problem and Im sure you will find it. I hope this helps.
Posted on May 14, 2010
Toilet Problems: One has Noisy flush & two others drip at rate of about two drips per second
Do you have a way to check your water pressure each of these problems could be caused by excessive pressure you may need to install pressure adjustment valve if you can't find another way
Jun 10, 2017 | Toto Home
Refill tube constantly detaches from fill valve
A longer piece of tubing may solve the problem. Put the extra down the overflow tube so it won't pop out. Hope this helps.
Dec 29, 2012 | Toto Carlyle 1-piece Elongated Bowl Toilet
How to fix a dripping toilet
if the fluidmaster,itself is leaking, there is a rubber disk in the base of fluidmaster, replace disk. however, i can almost promise you the dripping you hear is from a bad flapper. replace with KORKY brand flapper. buy the basic black one, with no water saving gadgets on it.you will see cheaper black ones, but get the KORKY
Dec 20, 2012 | Fluidmaster S2DBL Dual Flush Toil System
I have a new Kohler Toilet that has a different flushing system from other Toilets. It's about 1 year old now and I'm noticing a Drip noise on the 1st floor under this Toilet. It looks to me like the water...
Basically, if water is flowing out of the overflow tube, then water must be coming in...I would suggest that you check the intake valve, it is probably not shutting off completely when the float comes up to the prescribed level,and continues to leak some water into the tank. That is what the overflow tube is there for.
Mar 17, 2011 | Kohler Toilet - One Piece with Ingenium...
I have a american standard toilet mode 4112 that keeps running.....any suggestions on how to fix it?
The flapper ball may be contaminated and not sealing or the float level has changed and needs adjustment. You should be able to see if the overflow has water flowing into it continuously.
Mar 07, 2011 | American Standard 4112 Bone Toilet Tank...
The toilet keeps running constantly - the tube in the tank is overflowing and i can not get the dripping sound to stop. Anything i can do?
The noise is because your float in the toilet is set at too high of a level and it is overflowing and making noise.
Reset your float, to adjust the water level just below the overflow pipe...this should stop your noise.
If it does not correct the problem then you will have to replace the water control unit inside of the toilet tank.
Please rate me
Dec 05, 2010 | Toto Washlet Elongated Toilet Seat Bidet
Dripping overflow from toilet cistern.
there is an adjustment screw ontop of the fill valve assembly. Tighten this down and the water level should stop at a lower level unless the internal mechanism has crusted up.
May 15, 2010 | Plumbing
Constantantly dripping after tank is full
WHAT IS DRIPPING,?THE TANK ?OR IS STILL FILLING UP ?IT SOUNDS LIKE YOU NEED TO ADJUST THE WATER LEVEL TO THE PROPER 1.6 GALLONS PER FLUSH,WHICH IS MARKED ON THE INSIDE OF YOUR TANK SOMEWHERE,CAUSE WHAT YOUR HEARING IS THE WATER RUNNING DOWN THE OVERFLOW TUBE
Apr 09, 2010 | Toto Aquia II Dual Flush Toilet
Water drips into overflow valve after flushing
The purpose of the "Overflow" tube is to fill the toilet bowl. It should drip for a while. If it is continuously dripping there could be dirt or deposits on the ball **** valve. Shut off the water and dissasemble to see if there is deposits or perhaps a torn diaphragm.
Oct 15, 2009 | Toto Promenade, 1.6 GPF, Elongated...
My fridge is leaking because the drip pan is overflowing
I had this problem and it turns out that the filter cartridge had a leak and a constant drip into the drip pan. The drip pan is designed to capture the runoff from the self defrost but not a constant drip. The first thing you should do is remove your water filter cartridge - this will stop the drip until you can get a new cartridge. If that doesn't work just turn the water supply to the fridge off. You won't have ice but you won't have a leaky fridge either.
Aug 27, 2009 | Whirlpool ED2FHEXN Side by Side...
Home Logo
551 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
