Question about LG LS-L1210CL Mini Split Air Conditioner
Why is water dripping from the overflow quickly
Why is water dripping from the overflow real quickly when it hasnt done before? has it got a problem or should i assume its just dehumidifying the room more than the last year or so
    Novelist:
    Champion:
  • 246 Answers
Accumulating water is as you assumed - the air conditioner is taking the humidity from the space and the water is nothing other than condensation. I would not worry about it at all.
You need to start worrying if the unit 'doesn't' produce water.
Posted on May 14, 2010
Water is not pumping up to the reservoir. If i manually put water in the reservoir it will make ice.
I just had the same trouble after connecting it to my new filtration system. Yes, if you pour water in with a funnel, it will make ice. You need to be wary of overflowing, as it will drip into the ice reservoir, so close the door quickly so overflow will come out the ice dispenser.
Oct 22, 2015 | ULINE U-Line 2000 Series U-CLR2160S-01
My washer will drip water back in the tub after complete washing is finished Why Help
If the water is dripping in from the area where it normally fills for a wash cycle, then you probably have a problem with the water valve. You can open them up to see if debris has made its way into the valve, but they normally are not real expensive and it may just be easier and less hassle to just replace the entire valve. Hope this helps!
Feb 18, 2015 | Maytag Washing Machines
Excessive water pressure in radiator causing overflow tank to overflow in 1997 7.3 powerstroke
have a compression test done as that will most likely be a blown head gasket or cracked head allowing combustion pressure into the cooling system. A quick check is to remove the radiator cap and fill right to the top . Run the engine and if you see small bubbles in the water or it tends to belch out then it will be the gasket of cracked.
Mar 18, 2014 | 1995 Subaru Legacy
I have a GE refrigerator which leaks water. Point of origin of the leak is unknown but the water drips down the interior and pools at the bottem until it overflows and drips on the floor from the fro
You have a frozen drain in the freezer side of frig....take back panel off in freezer and you'll see your build up of ice take out ice and pour hot hot water down drain....make sure clear and clean then you're done....easy peasy....
Oct 02, 2012 | GE Refrigerators
My Bunn coffee filter overflows during brewing. What a mess! Is there any way to slow down the water flow?
If this is a pour-over coffeemaker, you can't do anything about the flow. It's just gravity pushing the water out of the reservoir. But you can try using a coarser grind of coffee. If the grind is too fine (if you grind whole beans for too long in a blade grinder, for instance, or if you're using espresso grind coffee), the water can't flow through quickly enough and it backs up and overflows. Make sure your coffee is ground for a drip coffeemaker.
Aug 02, 2011 | Bunn Coffee Makers & Espresso Machines
Unit ED5DHEXWQ bought 2 weeks ago Drip pan over flows- water not evaporating quickly. Company tech say I need to modify my frig by placing a heater. 2 The refrig side is not gettinG COLD ENOUGH - MY MILK...
The tech is full of beans. The heat from a normally charged refrigerator is more than enough to evaporate water in drip pan.
The indication of improper charge is that obvious. Fridge warm freezer ok would be a coil blocked with ice, however drip pan overflowing is a charge problem, Ask for a field supervisor.
Dec 24, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
Whirlpool side by side fridge. Water dripping from water dispens
Good day,
If it feeds normally, and then refuses to shut off completely, then the dual water valve in the back bottom of the refrigerator is failing and should be replaced ASAP. It could go wide open and create a real mess.
An option right now, is to shut the water off to the machine, until the valve replacement is complete.
That part is common and available at most appliance parts houses.
Thank you for using FixYa
Jan 08, 2010 | Refrigerators
PUMP WILL NOT STOP WHEN YOU PUT POWER ON . PUMP STARTS AS SOON AS YOU PUT THE POWER ON TO PICK A WASH PROGRAM EVEN BEFORE THE DOOR HAS BEEN CLOSED.
I have seen this on my unit. There was water in the drip pan under the dishwasher. Water in the drip pan comes from a leak. In my case, the water valve was getting so old that it was letting too much water into the unit when it was trying to fill. This cause the filling station to over flow into the drip pan.
A quick fix - I removed the water from the drip pan under the unit and I was able to turn down on the supply valve in the basement to limit how much water could come in. This allowed the unit to run without overflowing. I will replace the water valve soon.
Other possibilities, the float device used to detect too much water in the drip pan or too much water in the unit is stuck in the too full position. Or the pump out pump is stuck and not moving water.
Dec 17, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
My refrigerator is leaking water underneath it. the ice maker is not hooked up
Is it leaking water INSIDE the fridge at the bottom - if so that is an indication of a clogged defrost drain - if you have a drip cup in your refrigerator, that connects to a tube at the back of your fridge, to carry the water from the defrost cycle down the drip pan at the bottom.
If you see water OUTSIDE your unit, the only explanation is an overflowing drip pan ! Water from the defrost cycle drains and drips on a pan that sits on the compressor or besides it - the hot air from the compressor will cause water in the pan to evaporate quickly - either through a fan or when the pan is placed directly above compressor. If your model has a fan at the bottom next to compressor, that blows the hot air on it, check to see if it's working when compressor cycle is on.
There is no reason for that drip pan to overflow otherwise, it is quite big enough, and the water from the defrost cycle is usually around 2 ounces and should evaporate quickly.
Oct 09, 2009 | Whirlpool Refrigerators
Refrigerator water drip pan
thanks for the question no other way to do itthere is no drain hose attached to that tray sorry thanks for the question The appliance doc
Sep 11, 2008 | Refrigerators
LG LS-L1210CL Mini Split Air Conditioner Logo
284 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
