Question about Samsung DVD-VR375 DVD Recorder/VCR
The recorder is not reading any discs
Unable to play anything as it is not reading any discs. It trys reading as you can hear it and the spinning disc is on the screen then nothing.
  • 687 Answers
Check out my Tips for help with this matter, somtimes it can be the model of media that you are using OR the read head
http://www.fixya.com/support/r3644452-problems_dvdr_3380_not_finding_dvd
http://www.fixya.com/support/r3861651-make_dvd_rw_compatible_recording
Hope these help you to solve you problem
Posted on May 14, 2010
I have a tascam 564 i,m unable to eject the disk from the machine it only reads disc loading
I listed a similar answer for a similar qestion. If you have a push in to load mechanism, it is probably worn out. I had similar problems and found they were impossible to correct - think of it is an out of allignment or mechanical problem.
The few places which can fix this problem were charging $60 an hour plus shipping to and from, and may not have the parts to fix it. the cheapest way to go is to eBay for another MD.
If you are buying a used deck check it out like this - Load and record a good disc. Eject it and then replay it. If the reloaded disc plays you have a good MD if not you have a bad MD recorder of some sort.
Bad decks act like they are recording but MDs are not CD recorders they use a laser and a magnetic riding skate on the other side to of the MD write to the disc. If the skate is damaged they will appear to write but when you put the disc in another recorder or reload it to your recorder they will not have anything recorded on them.
I get bothered when I see clueless ads for used MD recorders saying it plays but does not record but it is a simple fix - It is not and the unit although it will probably play well it is not cost effective to fix the record problem I mentioned.
Feb 24, 2014 | Tascam Audio Players & Recorders
Unable to play or down disc from my handycam DVD105?
Are you facing problems with playing only the recorded discs?Or all the discs in your PC.
Nov 29, 2008 | Sony Handycam DCR-DVD105 DVD Camcorder
I have put in a dvd into the slot, it will not play, the message saying self check keeps displaying
Hi
Assuming that the machine accepts the disc in and begins to spin the disc, you will hear a spinning sound, and goes no further than this point, it would suggest the optical pick up is unable to read any data on the disc or the spindle motor is unable to spin the disc to its correct velocity, it is more than likely the laser has failed, either way the machine needs to be serviced.
Regards
TechSupp12
Dec 12, 2010 | Panasonic Televison & Video
System unable to read disc.
Try cleaning the lens with an approved laser lens cleaner.
Check to see if you can hear the disc being spun. If not, the spindle motor is bad.If your discs are spinning but aren't being read, your laser could be damaged. Contact Nintendo for service, unless you're comfortable replacing the laser yourself. Buy one online and get it replaced.
Thank you!
May 13, 2010 | Nintendo Wii Console
My PS3 isn't reading discs!
If it isn't even trying to spin up, than it is probably a failed drive motor, or a driver issue. If it is connected to the net, try to install the latest drivers for the disc drive. If you aren't, or that doesn't fix it, you need to take it in.
Yes, the PS3 can play PS2 games.
Sep 19, 2009 | Sony Playstation 3 (PS3) Console
Unable to read disc error
Laser or motor to the laser is bad
Thanks, Frank Z.
3868607368
http://www.attechcomputers.co.cc
Jun 21, 2009 | Nintendo Wii Console
Sony DVD+/-RW |DW-Q30A will not record cd or dvd & only play dvds
When you get no disk error, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD/DVD will not be read, therefore the error.
Whe this problem is starting you may be able to read only CD, DVD , or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD/DVD cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with q tips and isopropyl alcohol, or to replace the CD/DVD lens, or the whole drive unit.
Mar 28, 2009 | Sony DVD+/-RW |DW-Q30A BG w/o SW %...
Should recorder play cds bought from shop
Yes it should play all cd's - the laser is either dirty or needs replacing assuming it can spin discs ok.
Jun 16, 2008 | Denon CDR-M30 CD Recorder
No disc displayed
The disc won't spin until the unit recognizes that there is actually a disc there. Try cleaning the lens using a cotton swab and alcohol. If that fails, try playing a CD. If the CD plays, the optics are starting to fail as reading a DVD requires higher laser power.
Dan
Mar 19, 2008 | Cyberhome DVR 1600 DVD Recorder
Recording
iam having the same problem anyone know why
Dec 11, 2007 | Samsung SC-DC164 DVD Camcorder
Samsung DVD-VR375 DVD Recorder/VCR Logo
141 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
