Question about KitchenAid KBMC140HSS Convection/Microwave Oven
Kitchenaid KBMC147HSS0 Bulb replacement
Hi Master Tech,
I have a built-in Kitchenaid microwave and need to replace the halogen bulb. Can you provide me with the instructions for disassembling the cabinet to get to the bulb?
Thanks,
Ken
  • Anonymous Aug 23, 2008
    Hi Master Tech,
    I have a built-in Kitchenaid microwave Model KBMC140HSS03 and need to replace the halogen
    Thanks,
    Steve
  • KitchenAid Master
  • 9,174 Answers
If it's the one that lights the cooktop, it's normally beneath the bottom cover.
In some cases, it's located in a compartment behind the grille that goes across the top of the unit.
I have a diagram at my site which helps you find & replace many GE cooktop and cavity light bulbs. It may help. It's at http://207.234.249.73/mwd/ge_lamp_replacement.jpg
Please let me know if that helps or not.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 31, 2008
SOURCE:
Where do I get replacement halogen blub
Hi Sandie
You are asking about a Microwave oven...right?
They usually don't use halogen bulbs. Just a standard incandescent bulb. Don't need super bright in Microwave oven.
Take the bulb out and note the Voltage, Wattage and Shape & Size of the base. Bayonet or Screw etc. some details may be stamped on bulb.
Replacements can be had from many sources. Hardware / Electronics... depends where you are.
If the bulb is halogen for a vehicle headlight for example... take original or photo to an automotive shop.
Good Luck
Apr 07, 2015 | Microwave Ovens
hmmm..ok...let's try the service manual, first, shall we?
Mar 30, 2008 | Microwave Ovens
I need detailed instructions on how to change light bulb on Kitchenaid microwave KBMC147HSS0
Please check the details of how a microwave works which will help you identify before the panel is removed and the lamp replaced.
The top cover of the unit can be removed after the screws can be removed with the power cord removed. The lamp can be seen fitted on the front side with the light to shine into the chamber, you can remove the buld from holder and replace with the same type .
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
Oct 27, 2011 | KitchenAid KBMC140HSS Convection/Microwave...
How do I replace a lightbulb in my Kitchenaid microwave?
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=KEMS307DBS&siteCd=KAD#parts_list HEY ANDYCOOL,GO TO THIS LINK IT'LL SHOW YOU ANYTHING YOUR HEART DESIRES ABOUT THIS UNIT(DRAWINGS,USER MANUAL,PARTS LIST,INSTALLATION GUIDE,ECT.)SORRY BUT FROM THE LOOKS OF IT YOUR GONNA HAVE TO PULL THAT PUPPY.BUT YOU BE THE JUDGE OF THAT.GOOD LUCK,HOPE THIS HELPS!!!!
Nov 08, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
Kitchenaid microwave bulb
You can download the owner's manual and installation instructions here.
You can also download the parts manual here. It has handy exploded views. The bulb is shown on page 5 and is ref # 75.
You will need these instructions, because to replace the bulb, you will need to pull the microwave down from the wall mount and remove its cover.
Always unplug a microwave before removing or installing any bulbs.
And it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
If you don't find a replacement locally, check here.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 05, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
good..just takes some time sometimes to run this obtuse information down.
the question was in two parts, service manual, and also how to open up to get at the bulb..check the links again on the solution
Replacing the lamp in the microwave of a Kitchenaid KEMC378KSS01
Have work on these model, but narmaly they should be easy, to help, unplug it and open the cover to see if you can figure it out better, narmaly it's a clip on stage plastic that hold it in place, The bult could have purchse I think true gooles, with there part # back track it to see if a local shop would have it. $30 was very high.
I hope this help
What About Bob
Jan 29, 2008 | Microwave Ovens
LIght bulb burned out
I a Kitchen Aid Buit-in microwave (KEMC308KSS01) with the same problem - light went out. Can you send me the instructions on how to replace the bulb? Thank you! [email protected]
Jan 23, 2008 | KitchenAid KBMC140HSS Convection/Microwave...
KitchenAid KBMC140HSS Convection/Microwave Oven Logo
703 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Thomas F. Schneider
Jaime Hernandez
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
