I had downloaded a font named "alladin" on my n72. the font was ugly and i could not read any of my messages or contacts or any other thing writtern on my mobile. i tried a lot to remove it but it didnt work. plz help everyday i have to face a lot of broblem.
Shut down all programsand then find your font folder which is usually in C:windows\fonts or you can search your C: for the fonts folder. Once you find the fonts folder delete the malayalam font if it's in there.
Open internet explorer and go to: http://www.deepika.com/font.htm
Click on "Download
font" below
Save font in C:\ --> Windows --> Fonts
(some browsers may save the file name as a .exe extension.
Add .ttf to the end of the file name mlkr0ntt_TTF.
The file name should be mlkr0ntt_TTF.ttf
to work)
Restart your computer
Now open your adobe program and see if you can use that font.
Hope this helps! If not contact me and I can find you another solution.
goto menu --> settings-->display--->font size --->set font size to normal or small.that will do...
plz rate me !! if it helps ,if not feel free to comment
1. Then download the file by clicking miscellaneous link under the file information section on the
opened page.
2. Install the downloaded file in your nokia phone by connecting the phone
with PC using data cabl.
3. Now open the "My Own" folder on your phone, & click on the
ZFontRemover file.
4. Go to Options & then select the "Remove All
Fonts" option.
5. Now Restart your phone.Get ur original fonts now....
install font remover use that apps 1.first install font remover. 2.click on font remover icon and delete the font. 3.restart your mobile. Font will remove.
1) Install in the memory card. 2) Create a folder in memorycard at data en name it fonts (when there is allready one don't bother, there should b a file there called fontrouter ini 3) make fonts (choose a ttf and copy them 3 times so u have 4 fonts. 4) Rename them in2:
nohindisnr60 nohindissb60 nohinditsb60 S60ZDIGI
Now for the hard part...
5) make sure your cell doesn't use the memorycard (otherwise the mass storage won't work).... Think about the message setting and change it in2 phone memory... 6) Connect with mass storage and rop the 4 files in the e:data/fonts 7) Unplug and reboot... 8) That's it....
When U want 2 change it, that's even harder. Because the new fonts R being used by the memorycard, the mass storage won't work anymore. U can't delete the without mass storage....
1) Use the app X-plore and search 4 the frontrouter.ini file in the same folder. 2) Edit the file and change the setting on the 12th row:
enable=1
in2 this:
enable=0
3) save it and exit... 4) Reboot (this will restore your normal font) 5) Now use mass storage (again everything exits on the memorycard) and rename the folder fonts (E:data/fonts) in2 font (so loose the s) 6) Delete the files in there 7) Reboot and that's it.
When u want 2 change them at point 5 U have 2 drop the new ones in there after U deleted the old ones. Then use X-plore again and edit the ini file and change it back 2:
the iphone gives that message because it cannot use or display the font but in order to read the news you of course need the font.. a present there is no solution for the iphone unless at a later date they include the font you require... you have to keep using your pc I'm afraid
