Question about Konica Minolta DiALTA Di200 Copier
Paper will stuck at the heater
When i run a print on my konica 2223 the paper will stuck at the rollers located above the heater(dont know the exact name of that part of the copier).hope that somebody could help me.
  • 59 Answers
HI i think you have a bad upper fuser roller thats why the paper rolled up with it or maybe there are finge clow are not good first of all just remove paper and just clean the upper fuser roller with fuser oil if yours fuser roller and finger clow are not damaged it will work fine enjoy
thanks
Posted on May 14, 2010
Preventive maintenance time konica minolta bizhub 600
Yes every 250,000 prints the following is replaced
Developer, Ensure counter is cleared and Developer Charge is run
Drum
*Corona Wires and Corona Grid
*Transfer / separation wires
*Cleaning systems for above wires (Unless Cleaning system motors are shut down
*Fuser Web roller
also all of the above counters are cleared as the machine use the counters to determine what is new and what is old. And determine what voltages to assign to certain assy. if you lie to it and clear the counter and not replace codes will show up and image issues can happen.
* KIT PARTS
Developer and Drum separate
Should also check the upper and lower fuser roller located I the hot section and the fingers that protect those large rollers from allowing paper the to wrap around them.
Again clear counters!!!!!!!!!!!!!!! and run require developer and drum procedures. Try this as start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Jul 30, 2015 | Konica Minolta Office Equipment & Supplies
Paper jam laser
Could be dirt or a bit of paper stuck to one of the rollers or one of the rollers has jammed. You may have to strip it down a bit to get access to clear foreign objects.
Nov 25, 2013 | Konica Minolta Bizhub C550
Konica Minola 2300DL laser printer. When I try to print, it jams at the printer rollers just before the paper ejects. It fan folds in the top rollers There is no paper stuck anywhere?
I would closely examine the exit roller. When the paper fans; it's sticking on something. Typically, stuff will ":hide" on rollers; or maybe stuck on a sensor. Using a good flashlight will help.
Oct 27, 2010 | Konica Minolta magicolor 2300DL Laser...
How do i set up a konica 2223 copier to print using it as a network printer
the 2223 does not have that feature if you want a copier that is comparable to the same speed and features you would have to buy the konica minolta bizhub 222 new model or there are a lot of low mileage used bizhub 200 machines coming off lease for sale
Sep 28, 2009 | Konica Minolta Office Equipment & Supplies
After printing first page, the second page gets folded as envelope
Hello sir; It seems like registration roller clutch defect, replace it!
May 06, 2009 | Konica Minolta PagePro 1350W Laser Printer
Frequent paper jams with my Konica 2223 photocopier
I wish I could help you, You need to call for service for your copier. An authorized dealer or Konica minolta branch service in your area. You might need a fuser unit that the upper separating claws disloge or broken, exit paper detect actuator is broken or disloged, or you need a new developer.
Feb 05, 2009 | Konica Minolta DiALTA Di200 Copier
On the konica 2223 when printing it leaves a dark thick line down the center of the paper.
Konica 2223 copiers are analog meaning the image that comes out on copies is a direct reflection off of the copy. Dirty mirrors in the optic section can cause a dark band, but it is more of a shading effect. Drum assembly's can be removed.The image drum has a cleaning section that uses a urethane blade to clean excess toner off of the drum after the copy passes through.It is simply called a "Cleaning Blade" these blades can be ordered through most online copier part stores. Last but not least is the "Upper Fuser Roller". this is the hot roller the paper passes through to "set" the toner to the paper. These are coated with teflon to prevent toner from sticking to them. They have "seperator claws" that keep the paper from adhereing to the roller, and they sometimes gouge the teflon. this exposes bare metal, and the toner can come off of the copies and stick to the roller.
Jan 16, 2009 | Office Equipment & Supplies
I have a Konica 2223 copier - wont print on edges
check all edge settings .f28 is code for charger corona just clean corona assembly with cerosene oil and change corona wire with new one.
Dec 16, 2008 | Office Equipment & Supplies
Konica Minolta DiALTA Di200 Copier Logo
171 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
