Question about Music
No sound. loose wire or need new computer chip for it
No sound. is it a wire that came loose, or is it the 2 band eq. computer chip that doesnt work? i just need a web site that has a free esp LTd104 bass wire diagram.
I need the diagram to the power plug
Posted on Jan 31, 2013
  • Music Master
  • 5,603 Answers
Most common problem is depleted battery.
Use only akaline battery as rechargeable ones have lower voltage.
Posted on May 14, 2010
How do i update the firmware and is this may be the cause of the USB b not recognizing any memory sticks that we've tried?
usb b is for streaming digital media,not memory sticks,
  • High-power dual DSP engine with improved digital effects and output processing including Feedback Ferret®, 28-band GEQ/5-band PEQ, delay and limiter
  • USB 2.0 "A" connection to record directly to or playback from memory stick
  • USB 2.0 "B" connection for streaming digital out
  • 3-band EQ with sweepable mid-frequency and variable low cut filters
  • 2 stereo channels with dual mic/line inputs
  • 48 volt phantom power
  • 6 Aux sends
  • 4 subgroups
  • 100mm faders
  • Double the processing power of the original FX Series
  • All new switching power supply design is more efficient than the original
  • Silencer™ mic preamp XLR inputs
  • Weight Packed: 45.00 lb(20.412 kg)
  • Width Packed: 25"(63.5 cm)
  • Height Packed: 36"(91.44 cm)
  • Depth Packed: 11.5"(29.21 cm
May 19, 2015 | Peavey 32fx USB 32 Channel Mixer
Do you run a compressor in the effects loop?
Yes. I run all my modulation pedals into the compressor, then into the MXR Ten Band EQ, then into the effects loop. But it also works in the front of the amp as well to tighten up your distortion. Try it both ways and find the sound you like best.
Oct 13, 2013 | Pedal Mks Patch Pad Stereo Routing Module...
One channel doesnt work
it sounds to me that channel is burn
Sep 11, 2013 | DBX 231 Dual Channel 31-band Graphic EQ...
Could you use the Bose 901 series VI for a pa system?
Actually that's where the bose 800 systems came from.
Old school jazz guys were using their 900 series turned backwards as a pa
Mar 31, 2017 | Music
My pv231 eq just stoped working, the led light is not coming on, what could be the problem? pls help!!
Most common problem is power cord works loose. Beyond that it may be a pwer supply failure.
Apr 13, 2011 | Peavey Pv231eq Dual 31 Band Graphic...
When i turn my 10 band eq I hear a radio station
As cool as that might be for some people I am sure you find it a nuisance.
Check for loose or disconnected ground wires all the way from the instrument to the pedal, and inside the pedal.
It may be a cold solder joint as well (disconnecting something from ground, and letting the radio station sneak onto the signal line)
The EQ and anything connected to it could be the problem, but start with the pedal itself and then the instrument and it's cable.
Mar 09, 2011 | MXR M108 10 Band Graphic Equalizer Pedal
When we are trying to get a reasonable level of sound for vocals before it gets loud enough to be able to hear clearly with the band playing it starts to clip at the speakers now we are only using this set...
Proper level setting of the mixer is important. HOWEVER if the clipping is occuring at the speakers the only possible problem MIGHT be that you have a supersonic feedback that is saturating the speakers above your hearing range, Be sure you don't boost the highs too much with the EQ as this can cause the feedback that you can't hear. Also make sure that you power the speakers from the SAME receptacle as the mixer, even if it means running an extension cord to bring power to the mixer. This is to avoid a low frequency hum and common mode distortion/damage. A low frequency hum could cause the clipping.
It would be a good idea to get a sound meter to check the sound level. You should be able to reach 85 Db from this system without clipping. If you need more than that, you MAY need more speakers if the band instruments are too loud. Also if the band has amps that get into the vocal microphones that adds to the clipping level... make sure the mics don't "hear" the band instruments. Make sure your speakers are toward the audience from the mics to avoid the supersonic feedback problem. If the vocalists can't hear themselves with that configuration you need to set up seperate stage monitors.
There are some pretty good videos on YouTube about proper mixer level setup.
Jan 30, 2011 | Behringer Xenyx X2442USB / Harbinger...
I don't known how to adjust to get the right sound!! please help
Here are some links for you:http://www.looperman.com/tutorials-mixing-1-how_to_use_graphic_eq.html Also:http://www.astralsound.com/graphic_eq.htm Also:http://www.soundonsound.com/sos/1995_articles/mar95/eq.html Try to stay away from the Smiley face curve. You are better served by using your tools properly with expert advice.
Oct 05, 2010 | DBX 231 Dual Channel 31-Band Graphic Eq
I am keyboard player and i want hook up an equalizer to the system where do i hook it up to
If you're only using the keyboard, connect the keyboard output to the EQ input, and EQ output to your amp.
If you have multiple instruments and a mixer, run mixer output to EQ input, EQ output to amp.
More info, let me know.
Charlie
Aug 29, 2009 | DBX 231 Dual Channel 31-Band Graphic Eq
Im not sure what the knobs are i just need to know what they do and which one is which. thank you
The two closest to the neck should be volume controls. The other two are 2-band EQ controls.
Aug 17, 2009 | Schecter Omen-5 5-String Bass Guitar Gloss
Music Logo
103 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
