Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Skywing bluetooth stereo headset
I have paired this device with my moto krazr the phone part works fine but there is no sound coming out when in the play music mode. not sure if I paired it correctly because I did not get a pass code so I just guessed. can you help?
    Brigadier General:
  • 7,752 Answers
Take it to the store where you purchased it from and have them set it up for you.
Posted on Jun 22, 2008
Bluetooth quit connecting with Moto Razr Phone
Go to bluetooth and see what is listed click on it and remove device. Start over.
May 03, 2017 | Motorola Mobility H700 Wireless Headset
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
My backbeat is paired and working with my sprint evo. but the music will not play at all through the headset? calls are fine but no stereo music . it was working fine before i got a jawbone and paired it...
I wonder if Adroid has some issues with its A2DP stack. You see, I have 3 different stereo headsets paired with my WM6.1 phone, and all of them (one at a time, of course) stream music without any flaws.
Anyway, you could try to delete the Backbeat from the list of paired devices on your phone, and, then, pair them again.
Just my 2 cents...
Hope you are able to sort your problems out soon.
Regards, Carlos
Oct 12, 2010 | Plantronics Backbeat 903 Bluetooth...
Unable to pair LG GM200 bluetooth 2.0 A2DP with Plantronics Pulsar 260. Error: "Request Failed" Please help in connecting this two devices
Each pair of BT enabled phone and headset is a particular world. I don't have the Plantronics, but my LG phone pairs fine with my Lubix stereo headsets. I'll tell you how I managed to pair them: I put my headsets in pairing mode. Then, on my phone, I go to 'Connectivity > Bluetooth > Device list > Options > New'. If my bluetooth stack is off I'm prompted to turn it on. It starts to search for devices, and comes up with my BT headsets' name, I press 'Pair', it prompts me for the pairing code. I enter '0000' (the same code for your Plantronics' headsets, by the way) and Ok. Then, back to the Device list, I select the BT headsets and go to 'Options > Connect'. I'm good to go. After listening to music, I use to go again to 'Connectivity > Bluetooth > Device list', select the headsets and press 'Options > Disconnect'.
Hope it works for you.
Cheers! Carlos
Apr 18, 2010 | LG GM200 Cell Phone
Cant hear music through my LG HBS-200 Bluetooth Stereo Headset
I have the same problem with my HBS-250. It was working fine on my iPod Touch. It worked the first couple of weeks on my iPhone 4 then stopped playing music. Phone funtion works. No music or podcasts or streaming from the web
Sep 12, 2009 | LG SGBS0001606 Bluetooth HBS-200 Stereo...
Pairing my bluetooth
the solution was to replace my phone.i found out that it had been damaged by a previous owner.
Mar 21, 2009 | Motorola Mobility H700 Wireless Headset
Bluetooth pairing
Try the following:
a) Options->Bluetooth->Enable Bluetooth
b) switched on the Moto headset (blue light blinking)
c) options->bluetooth->add device
d) searching for devices....---> here it should find the headset and pair....
If it does not work do the following
After doing the above, do the following:
e). Start the headset. Start with the headset powered off, and hold the Call button for 10 seconds or so, until the light stays on. (Initially, the light will flash a few times before getting steady.) If the light is flashing, or if the light starts flashing anytime during steps f) through g), the headset is not in pairing mode, and this step (step e) must be repeated, again starting with headset powered off.
Select the Headset:
f.) Go back to phone, and select "[Look for Devices]." The phone starts searching for Bluetooth devices.
g). Once phone is finished searching, you get a list of one or more devices under the heading "Scan Results." Select the headset.
h). The next screen will read "Bond With ..headset." Select "Yes."
i). The next screen will be "Enter Bluetooth Passkey." Enter 0000 and select "OK." A screen will confirm pairing and connection. When the pairing is complete, the light on the headset will flash.
Sep 13, 2008 | Cell Phones
How to connect motorola skywing
The default passkey is usually 0000 (4 zeros)
Jul 23, 2008 | Motorola Mobility H700 Wireless Headset
Skywing bluetooth
1. Ensure the headset is turned off (indicator light not blinking and headset
boom is closed)
2. Press and hold the Call button. After about 4 or 5 seconds, the indicator
light becomes steadily lit in magenta
3. Release the Call button and immediately open the headset boom. The
indicator light remains lit in magenta.
If the indicator light is flashing in blue or not steadily lit when opening the
headset boom, repeat steps 1 through 3
Then on your phone, search for new bluetooth devices and connect. the defaault code for the HS is 0000
Jul 01, 2008 | Motorola Mobility H700 Wireless Headset
Attn!!! Purple light wont stay on long enough to pair.
DO THIS:press hook button until light remains on solid (mic folded in)fold mic out while light is still solid then pair.
Dec 08, 2007 | Motorola Mobility H700 Wireless Headset
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
161 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
