Manaul for a gasfire gazco exter serial no/15892 i need a manaul booket or website 2 find that i can use 2 have my gas fire serviced by my loacal corgi serciver
Okay google the make and model and see if you can find the makers wed site and look for a manual . Or look for make and model and coal set up . You can also try u tube . Cannot tell you anymore than they have to go back as was . Hope this helps .
you need to up pipe diameter there is not enough volume able to come through shud b 15mm,..to fire and at least 3/4in... 22mm boiler also if u have a gas cooker needs to b all gas rated to obtain right pipe scize as a rule of thumb 3/4..in...22mm shud b ran right through and except boiler b 1/2in 15 mm tube running to every thing but the 1/2in 15mm pipes must not b longer than 6-7ft max
this is cars and trucks ,not gas fires but they sell this stuff in our local DIY shop for BBQs not expensive but i think its expensive but then i would because iam so tight
Hi clean pilot light and change the thermocouple , you will have to remove the gasfire to get to the boiler if unsure best get a gas fitter to do this as this is not easy to explaine , simple job but you have to know what you are doing , it might be you need a service on the bbu and the gasfire then the thermocouple could be done at this time.
