Question about RCA RS2652 Shelf System
I have buyed a Philips mycrosystem(MCD-296/12) in 2008.
When is in stand-buy, sometimes light from the display and volume light up simultaneously and the device hangs (does not responding to commands from remote or manual).
As the ambient temperature (above 22 degrees Celsius) is higher, the more fault occurs frequently.
Unblocking is made, when I swich off.( when the cable is out from the sniff).
I will be grateful for your support.
2 Suggested Answers
CLUEPATEL
  • 138 Answers
SOURCE: Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Posted on Dec 23, 2007
I have a Philips tv model 42FD9954/69c but it doesn't have a remote so I cant turn it on how do you get it to work with a universal remote ?!
Most TVs have controls on the side of the TV to operate power, volume and channels, if the power button puts it to standby then use the Chanel up or down to turn it on! Depending on the universal remote being used just select the code relevant to the make of TV you are connecting to!
Nov 01, 2014 | Televison & Video
When turning up the volume speakers start to humn. Tried on all inputs still humming. Sound comes out but humming is there. Humming only stop when turning the volume all the way down.
You need to add a "ground lift" to the power cord to your system. What you're hearing is a 60 cycle hum (electricity) from house power.
Mar 11, 2011 | Philips MCD-735 System
I need to know where I can buy the base of a 47-inch Philips TV
Tries websites like Amazon.com,Ebay.com to buy a used or new tv base stand.
Feb 17, 2011 | Philips 47PFL6704D LCD TV
Where is the volume control on the BSR MCD-8000? I can't find it on the unit or the remote
There is no volume control. If you look at the MCD 8000's front panel, you'll see there is none there either. The volume is a function of your amplifier or receiver.
Apr 06, 2009 | Audio Players & Recorders
Access the menu options manually
Press the set's Volume (+) and (-) buttons simultaneously to activate the Menu display. Use the Channel Down button to scroll to the desired menu item, then use Volume (+) or (-) to change that item, or to activate a sub-menu if any. (If in a sub-menu, again use Channel Down to reach the desired item, then Volume (+) or (-) to change its setting or value.) When finished, press Volume (+) and (-) simultaneously as needed to "back out" of the menu.
Not all set functions can be reached this way, especially a few involving numeric entry; but this will get you started. Good luck!
Jan 23, 2009 | Philips 55PW9363 55" Rear Projection...
Unlock code for my Philips MCD 177
I need a region unlock code for my Philips Micro Theatre MCD290 DVD
Nov 17, 2008 | Philips MCD288/37 DVD Micro Theater System...
MCD 700
Dear Mr., I have mini center Philips MCD 700 customs 2007. That apparate need repair. I live in Russya service center Philips have problems that apparat have not acreditation becouse not repair. My neccessery electoronic schema or adress were can I repair Philips MCD 700? Can you my send schema? Or Send adress company repair Philips MCD 700? Best regards Kostromitinov Nikolay
Oct 18, 2008 | Philips (MCD700) System
Flashing red light and shutting itself off
try to elevate the projection tv about an inch...
it well most likely work...
it's a ventilation problem.
Feb 09, 2007 | Philips 55PL9223 55" Rear Projection...
RCA RS2652 Shelf System Logo
49 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
