Question about GE Zoneline AZ55H07D Air Conditioner
Zoneline PTAC short circuit
I would appreciate some advice. I just installed a digital thermostat from GE RAK148P1 on an existing Zoneline PTAC. The low voltage line short circuited while installing the thermostat (stupid, I know). Now, the PTAC doesn't work. There is no light in the touch pad controls (with or without the thermostat).
Do I need to replace the PTAC?
Thanks!
  • 30 Answers
Most likely you will need to either replace transformer or there may be a low voltage flat type "car fuse" usually 3 amp or 5 amp for just such an occasion. Good luck!
Posted on Mar 30, 2008
Trips when plugged in
What trips? If you are referring to the circuit breaker then I suspect the breaker is not sufficient for the power the unit draws. Beware installing a higher amperage breaker. First be sure the wiring and all bomponents are adequate.
May 21, 2015 | GE Zoneline In Wall Ptac Unit Air...
The gfci tripswhen i turn my ptac to heat what is my problem?
The gfci is short for the ground fault circuit interrupter. This prevents voltage from the hot side of your AC circuit to feed through to the case. This would mean somewhere within, a wire may be touching the frame. You should not try to live with this situation. One quick check might be to reverse the plug in the receptacle. If this does NOT cause the GFIC to trip, then the short must be found and insulated with electrician's tape.
Oct 04, 2013 | GE Zoneline AZ55H07D Air Conditioner
Stat issues with GE Zoneline
Your coils on the outside unit may need cleaning.When they get dirty, air cannot flow through them to remove heat from the refrigerant. When this happens pressure increases until it trips a safety and shuts the unit down.
It won't run again until the pressure drops to a safe level. Also check your drain line..Make sure it's dripping.If not it's clogged and that will trip the safety switch not allowing water to back up
Sep 17, 2017 | GE Heating & Cooling
Indoor fan barely turning
the three post capacitor has c for line voltage in, the f or fan is for the outdoor motor,and com or comp goes to start winding compressor.youll have to follow wires from indoor motor to find capacitor. to find wires to outdoor motor to capacitor you have line voltage and capacitor wires .look for schematic it would help or send colors of wires from both motors and compressor common,start .run.
Jun 07, 2013 | GE Zoneline AZ55H07D Air Conditioner
Ihave 50 ge zoneline ptac units.only the middle of the evap. is sweating.low pressure is read ing in ******
Check the air filter and coils are cleaned. If it's o.k, then it is due to short of gas. Find out the leak and arrest it, then do vacum and gas charging.
Aug 18, 2012 | GE Zoneline AZ25E12D3B Air Conditioner
Ihave 50 ge ptac units that only the middle of evap.is getting cold
short of gas. Check for leak and arrest it. Then vacum and do gas charging.
Aug 18, 2012 | GE Zoneline In Wall Ptac Unit Air...
GE PTAC AZ38H09DABM2 WENT DEAD..POWER OK
Could be the main control board.
Could be that somebody has been messing with the dipswitches beneath the control board.
Dec 22, 2008 | GE Zoneline Deluxe Series Cooling &...
GE Zoneline AZ55H07D Air Conditioner Logo
349 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
