Question about Dell Vostro 1710 Laptop
I have a Vostro 1710, My problem is either the power pack or the power socket on the laptop, When i turn on my computer it stays on for a max of 1min before switching off again (then have to pull the battery out and put it back in, then plugging in the power for it to work again). But continues to only last 1 min. I pulled out the power once switched on and comes up with low battery warning. The power plug once plugged in seems to have a fair bit of movement (not the connection it self). I know my way around computers quite well and very good with a soldering iron. Im just wondering if there is a guide or diagram that shows the internals of either the power pack or the laptop power socket?
  • kingspeedy May 15, 2010
    Yes, answered all my questions thanks.
  • Dell Master
  • 13,433 Answers
Lets do some troubleshooting first before we start taking it apart, can you get the battery charged on another laptop?
If your battery is charged, plug it in and turn on the laptop, if its fully charged and it still repeatedly turns off after 1 minute, this is not a power socket / jack issue.
As for a diagram of the power jack/socket, it has 2 pins, generally, one on the center and another at the side. then the jack is also held in place on the board with atleast 2 to 4 solder contacts that possibly go through the board and come out the other side, but those are basically just ground, and hold it in place.
Posted on May 14, 2010
  • 6 more comments
  • kingspeedy May 14, 2010
    Hi Ekse thanks for your quick reply,
    Yes the battery will charge on another laptop, but after i replace it, it slowly runs out its definitely not charging.
    With the power jack/socket will i have to get to it from the bottom of the laptop or can i get to it from the keyboard side? Is there a step by step guide for this?
    I also noticed the power cable coming out of the power pack is also loose, is there a special tool i need to open the power pack or does it clip together?
    Thanks again.
  • Ekse May 14, 2010
    So with the battery charged on another laptop, while it has power, does your laptop turn on and work until the battery runs out? about 30 minutes or 1 hour or more.
    if your laptop turns off with a fully charged battery 1 one minute, you have a more serious problem.
    getting to the power plug you need to disassemble the whole laptop, the motherboard will need to be removed from its casing, the whole laptop comes apart into a dozen of parts.
  • Ekse May 14, 2010
    service manual for instructions on how to take apart : http://support.dell.com/support/edocs/sy...
  • Ekse May 14, 2010
    in your case the DC in plug - power plug is a set of wires that go to the board, you can see this on the service manual picture, it is very easily replaced and does not require soldering. But. I suspect this might not be the issue your having.
    Takes an hour or so depending on how much i use it to go flat again after charging it on another laptop.
    If you don't think DC in plug on the board, is it the power pack itself?.
    The reason why i though it was the DC in plug is if i wiggle it there is allot of movement.
  • Ekse May 14, 2010
    Okay, so if your laptop works for a hour with a charged battery the laptop is then fine, use a multimeter to check the voltage on the charger plug, make sure it is + / - 0.25 of the indicated voltage, if it is lower of that, it may be faulty. Another test you can do is to hook it up to a 24volt car light bulb, first you solder two wires to the lamp, and then connect them appropriately to the plug, if the light is not steady, (measure voltage at the same time) or if the voltage drops, the charger is bad, replace it.
    if the charger checks out, the issue might be the plug on the laptops end.
    Ive wired up a test light and the light did not dim, It was consistent. I left my Multimeter at work so i cant check the voltage. So its looking like it might be the plug on the laptop end, would you agree?
  • Ekse May 15, 2010
    Most likely.
How do I unlock my keyboard on my dell Vostro 1710 computer
I'll assume your keyboard was fully functional, then something happened (not involving a liquid spill or other physical damage), and now your keyboard seems to be dead. Please correct me if I am wrong, but I take it that your computer makes it through the bootstrapping process and successfully completes POST before Windows(?) takes over.
Based on those assumptions, I think you tripped a security "feature" by accident, which can be disabled either through a specific combination of keys (e.g. ctrl + alt + del), or by entering BIOS configuration (commonly f12, f2, or del).
Finally, it is possible you will need to drain all power from the machine by unplugging the charger, removing the big laptop battery, and then removing the CMOS battery by taking off the RAM or HDD panel on the underside of the laptop. If this is required, I suggest waiting at least 15 seconds before replacing the batteries.
Mar 08, 2015 | Dell Vostro 1710 Laptop
Vostro 1710 power jack loose power plug can't connect.
Check out utube. Search for your model and then your issue.
Hope that helps.
Nov 30, 2013 | Dell Vostro 1710 Laptop
Does my Dell Vostro 1710 have a webcam?
It is an optional extra on this laptop according to dell link below.
the webacam is located at the top center of the screen if it is installed when you shine a torch in there you should see the lens like a camera on your mobile.
I would also check the device manager and see if anything appears in there. Perhaps drivers need to be installed.
Oct 23, 2012 | Dell Vostro 1710 Laptop
Dell vostro 1710 won't start after bios update
Assuming you did the correct bios update, you may need to remove the CMOS battery for about 30 seconds and then replace it.
Jul 05, 2012 | Dell Vostro 1710 Laptop
My Packard Bell (bought May 2010 new) laptop has a screen flicker problem. For the past week, every now and then the left half of the screen, or sometimes the bottom half of the screen, gets distorted with...
<font size="3"><i><span style="FONT-FAMILY: Arial; COLOR: #cb0101" lang="EN-US">4400mAh, 11.10V</span></i><span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"> Dell Vostro 1710 Battery Replacement<span style="mso-spacerun: yes"> </span></span></font><span class="redfont1"><b><span style="FONT-FAMILY: Verdana; FONT-SIZE: 16.5pt; mso-bidi-font-family: Arial" lang="EN-US"><font color="#cb0101">$ 72.58</font></span></b></span><br /> <span style="FONT-FAMILY: Arial; COLOR: #333333" lang="EN-US"><font size="3">Dell Vostro 1710 Battery</font></span><br /> <span class="htmlval1"><span style="FONT-FAMILY: 'Courier New'" lang="EN-US"><font size="3"><font color="#0000ff">Discount Dell Vostro 1710 Battery 11.1V 4400mAh,fit for Dell Vostro 1710, Dell Vostro 1720 Laptops.Full 1-year warranty and 30-day money back!</font></font></span></span><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">ShippingArea:</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #cc0000; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">We ship all over the world!</span></b><b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US"></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Brand :Dell Vostro 1710</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Type :Li-ion</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Voltage :11.10V</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Capacity : 4400mAh</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Ltem(Cell):6-cell</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Color :Black</span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Dimension :270.90 x 50.00 x <st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="20.2" unitname="mm">20.2mm</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery Weight :<st1:chmetcnv w:st="on" tcsc="0" numbertype="1" negative="False" hasspace="False" sourcevalue="665" unitname="g">665g</st1:chmetcnv></span></b><br /> <b><span style="FONT-FAMILY: Verdana; COLOR: #333333; FONT-SIZE: 8.5pt; mso-font-kerning: 0pt; mso-bidi-font-family: Arial" lang="EN-US">Battery SKU :DE017K</span></b><br /> <span lang="EN-US"><a href="http://www.battery-sale.net/dell-vostro-1710-battery.html">http://www.battery-sale.net/dell-vostro-1710-battery.html</a><span style="mso-spacerun: yes"> </span></span>
Aug 27, 2010 | Computers & Internet
When I try to start my laptop it powers up and shuts off.the screen comes on then shuts off. I have replaced the battery and power cord.
Hi. Try removing the RAMs and turning the computer on as you reinstall each module. If nothing happens then you might need to replace your motherboard.
Hope it helps. ^_^
May 19, 2010 | Dell Vostro 1710 Laptop
I have a dell vostro 1710 i want to restore to
Turn the computer off, and then restart it; immediately hold down the ctrl and f11 keys, and it will restore
Nov 10, 2009 | Dell Vostro 1710 Laptop Computer PC...
Dell Vostro 1710 Laptop Logo
708 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
