Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
I have a problem with a Whirlpool top loading washing machine. Whilst filling with water, the water runs straight out of the drain pipe. Help with this problem will be most sincerely appreciated as I live in a remote rural area where one has to fix ones own appliances.
  • 5,911 Answers
You may be experiencing a condition known as "siphoning". This is caused by the drain hose not being high enough off the floor, or not having a proper air gap at the standpipe in order to drain properly. This creates a suction and the washer will constantly drain (siphon) as it tries to fill. The following link explains:
http://www.fixya.com/support/r3575830-how_to_prevent_washer_siphoning
In the majority of the cases, this problem is attributed to improper installation, rather than an actual problem with the washer. If you have any questions, please post back and let me know. I hope this helps you.
Posted on May 14, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
The wash keeps running water, never fills up
Your drain hose is to far down in the stand pipe or your stand pipe is to low, your stand pipe should be roughly the same height as the top of your washer if it is pull your hose out of the drain pipe it has probably just went down to far, it only need to be about 8 inches in the pipe, it is siphoning the water out, that is what your problem is.
Jan 08, 2011 | Whirlpool LSR5132PQ Top Load Washer
I have a very old (16 yrs +/-) whirlpool washer that tries to fill with water, but seems to drain straight out. Unfortunately, the first time I noticed the problem, I started a load of wash and left...when...
You probably have a floor drain rather than a drain pipe which is higher than the pump. hold the drain hose up while its filling or make it go up (about as high as half the machine height) before it goes back down to the drain. (At least to check it out) The pumps shouldn't siphon out but some do.
Aug 20, 2009 | Whirlpool Washing Machines
Water running out when washing machine is filling?
Hi jojolevaokah
Water siphoning out the drain line
If the water is continues to fill and water is draining while it is filling or agitating, Check the height of the stand pipe. It should be about 36" above the floor. If the height is correct it may need to have an anti-siphoning valve installed into the drain line.
Apr 07, 2009 | Whirlpool LSQ9520L Top Load Washer
Water fill, discharge and noise problems
to reset the water level you have to turn the knob all the way over as far as it will go and then come back to large load.
Feb 18, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Dec 30, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper washer
I have the same damn issue with my Samsung washing machine(Top Loader) Not quite sure why it does it.Help please really annoying.
Jun 05, 2008 | Whirlpool LSB6200KQ Top Load Washer
Calypso - water goes straight to drain hose-not drum
the hose may still be filled from last cycle. try to put machine in final spin mode where all water from previous wash will be spun out the drain hose. once a siphon is started it can only be stopped by introducing air into the drain hose.
Sep 16, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
Sal De
Gerry Harvey
Gerry Harvey
