Question about Air Tools & Compressors
Where can I get a drive belt for my Rockworth Powertask compressor 6Ltr 1.5 HP 115 psi Hope you can help
4 Suggested Answers
rockitman187
  • 2559 Answers
SOURCE: compressor shuts off before reaching max pressure
Yes,but if the max is 125 you don't want to increase it above 110 and set off the pressure relief valve.
Posted on Jul 21, 2009
  • 138 Answers
SOURCE: Craftsman air compressor 1 HP 12 gal 125 psi
this is probably an "oilless" compressor, it has "piston" with a thin ring of leatherlike material acting as a piston ring, the "cylinder" is an aluminum sleeve - what usually happens is the cylinder gets scratched from dirt or just wear or the leather ring deteriorates, that's why it will go only so far - the only fix for this is to replace the cylinder and the piston
Posted on Aug 18, 2009
  • 1388 Answers
SOURCE: what kind of oil do i need for a craftman 1 hp 3
For warm climate, use 30wt non detergent oil (lowest price $3). Med priced oil ($5), use compessor oil sold at Lowes or any major center store including Wal Mart. Compressor oil is special blend for higher temperature range (continuous use). High price oil, synthetic compressor oil works for heavy duty use under severe conditions (also sold at major lumber centers, cost about $8~18).
For lite duty, any oil that you have handy will work fine (check oil before every use). Good luck
Posted on Oct 04, 2011
Rockworth 1.5 hp 6ltr oil free compressor drive belt replacement
You could try this link.
This is for megadyne tb2 310 belt (nlh6ltCOM)
http://www.solenttools.co.uk/performance-power-drive-belts/performance-power-compressor-drive-belt-nlh6ltcom-2051157-331171-.php
Feb 19, 2013 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How do you fit a new drive belt to a rockworth compressor because there doesn't seem to be ant adjustment
if this is a small compressor say 2 hp you leave everything alone make sure you have the right size belt and stretch it on like a rubber band.. The belt will be quite tight but thats the way they come. If you are concerned that the new belt is too tight or too loose mark the position of you motor with a felt pen remove the belt and move the motor forwards or backwards a small amount in line with your marks, then refit the belt. The main thing is that the motor shaft stays parrallel or close to it with the drive shaft of your pump.
Jan 16, 2013 | Air Tools & Compressors
T30 model 242 Safety relief valve pops off at 50-60 lbs pressure. Put on a new one and still the same problem. Don't know what to look for next. Normal cut out is at 150-175. Thanks
From want you are describing sounds like the high pressure valves are leaking in the HP Head. there are 2 safeties on this unit . If the safety that's lifting is between the low and high pressure cylinders it's hp valves leaking. If the tank safety is lifting at 50-60 psi It should be replaced. It is a 200 psi safety.
May 26, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Broken on/ off switch for rockworth ARPD1700 hammer drill
rockworth powertask demo hammer needs new trigger how do i get parts
May 17, 2010 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Rockworth powertask generator no output capacitor on output 12uf 450VAC burnt out Know a supplier Thanks
http://www.ceiling-fans-n-more.com/ceiling-fan-capacitors.php
this is for ceiling fans but I suppose they would have replacement capacitors too.
Oct 26, 2009 | Electrical Supplies
I need the parts for rockworth power task 1700w
Hello I need a new trigger switch for my Rockworth PowerTask
serial no uk004984 ARPD1/OOK. On the switch itself inside it has HY15C. Please put me in touch with your on parts division. Thanks.
Jun 13, 2009 | Hitachi H65XXX 1 - 1/8 " Hex Shank...
Not pumping up to capacity, motor and compressor working fine,
If your pump is shutting off before it reaches it's max psi. then you need to adjust you switch. Under the black case there are two adjustment screws. One is the high\low adjustment, the other is high pressure cut off.
The first will change when the pump turns on and off for your low psi setting and the high setting simultaneously.
The second will allow you to raise or lower just the high setting. There should be a diagram under the black cap to show which is which. Adjust the high side only and just a 1\4 turn then run the compressor and see if that takes care of the high setting.
May 29, 2009 | Northern Industrial 2 Hp Twin Tank...
Rockworth 1700w Breaker - Stoppped working
I have a Rockworth Powertask which appears to have the same problem when exposing the drive gears the spline drive gear had been completely shredded together with a ball bearing race the driver gear was intact & the secondary drive gear would appear to have destroyed the drive gear - suggest repair
Mar 05, 2009 | Dewalt D25900k Heavy Duty Demolition...
Air Tools & Compressors Logo
141 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
