Question about Fellowes DM8C Cross-Cut Shredder
Fellows paper shredder
I have a shredder that will work in reverse but not forward
It does not have a paper feed switch
It has a led receiver in the paper feed slot
Can i replace that or does the whole board need to be replaced
Please help if you can
It has been a good machine but I am comfortable to buy a new one
Thanks again
greg
  • Anonymous Jun 11, 2008
    My fellowes DM8C paper shredder will not except any paper. It will work in reverse only. I have cleaned all paper out of the cutting blades. Please help.
    Harold Alport
    alpo29@sbcglobal.net
  • dave314usa Aug 02, 2008
    Equipment: Fellowes DM8C Shredder.
    Current symptom: Appropriate LEDs on, however, reverse direction only.
    History: Had paper jam, hit reverse and then forward in quick succession. Shredder dead. No lites, no motion. Fuse o.k. Fellowes will not provide "propitiatory" schematic on this discontinued model. Traced relevant PCB circuit. Low voltage DC supply pulled to ground through defective quad Op-Amp (LM324). Replaced Op-amp (also installed a socket). Now LEDs come on and the reverse function works.
    Trouble shooting:
    1) Hmm, if optics were dirty, shredder would always be on.
    2) More circuit tracing reveals that a Triac must turn on for forward operation, but, not for reverse.
    3) Side tracking... The 16uf 250vac cap used for the "second" ac phase on the motor does not give a "kick" on my ohm meter when test leads are alternated between leads of cap (out of circuit). However, motor won't move with out cap in circuit. Note: Cap is in series with 10ohm winding for reverse operation. And in series with 18ohm winding for forward. So, cap is likely o.k.
    4) Flipping the motor windings (two outer leads of motor connector) allows the shredder to run forward while the reverse contacts of the switch are closed.
    Short term "fix": Flip motor coils AND flip DPDT center off switch around in it's socket to allow continuous operation in forward. (The switch has a momentary position labeled "R".
    Comment: How hot the motor might get remains to be seen. But, trying to trace the circuit from optical sensor through the Op-amp and transister string to the Triac is getting old. Will do live testing of circuit another day.
    Questions:
    1) What should my DVM show for resistance on the triac?
    2) How long might I get away with reversing the windings?
    Contact: Dave314usa@yahoo.com
So where do I buy a Fellows DMS8c paper shedder blade? I hate to have to buy a new shredder when this one was a good one, just needs a new blade. Please advise.
mhwego@comcast.net
Posted on Jul 12, 2008
Shreader is stuck in reverse
Posted on Aug 07, 2009
    Scholar:
  • 102 Answers
First try to clean those sensors with a qtip dipped in rubbing alchohol if that does not work call 1-800-945-4545 to check for part availability.
Posted on Apr 07, 2008
Fellowes P35C works in reverse but not forwards
In forward operation, a detector senses the presence of material in the feeder and turns it on. Reverse operation is selected by switch position; no sensor is involved. I would bet that if you remove power and turn the shredder upside down you will find bits of shredded paper clogging your shredder, particularly in the center area where the detector is located. After thorough removal of debris, you should be back to normal operation
Feb 03, 2013 | Fellowes P35C Black Cross Cut Shredder...
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
Fellowes shredder only works in reverse
The unit sits on its own custom waist basket. In the unit is a micro switch that must be clicked by the seating of the unit on top of this waist basket. If the micro switch isn't activated, forward won't work. Check this. Short of this, the microprocessor that runs the diodes might not be working. (The diodes, one transmitter, one receiver, tell the machine the presence of a piece of paper in the slot.)
Nov 26, 2009 | Fellowes Office Equipment & Supplies
Where do does the oil go on a fellowes dm8c shredder
Squirt some down into the paper feed slot.... forward and reverse.
Aug 16, 2009 | Fellowes DM8C Cross-Cut Shredder
Fellowes powershred 320
seems to be an issue with the paper feed sensors i suggest you call Fellowes customer service. 1-800-945-4545
Mar 09, 2008 | Fellowes Powershred 420 Shredder
Shredder Motor goes in reverse, but will not run or shred, or go forward
The first thing you want to check is the mechanical paper feed sensor. It is located in the center of the paper throat. A switch that gets pushed back when paper is inserted. Sometimes paper gets stuck behind it and you can jiggle the switch to work it loose. If that does not work try moving the basket around a little, this unit has a magnetic safety interlock switch located under center of basket. If niether of these help you please contact us at Fellowes Customer Service 800-945-4545.
Mar 01, 2008 | Fellowes 3011001 Shredder
Shredder not working
Though I only work with Fellowes shredders this sounds like a paper feed sensor issue. If your unit has a mechanical paper feed sensor you can try to jiggle it in and out to see if any paper may have become jammed behind switch. If the unit has an electronic sensor it may simply need to be cleaned with a Qtip dipped in rubbing alchohol. Sensor is usually located in the center of the paper feed opening.
If neither of these help your paper feed sensor or your pc1.gif board has gone bad and you will have to contact your manufacturer for further parts availability.
Feb 07, 2008 | Techko SH1524CP Shredder
Fellowes paper shredder
Jan 08, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Fellowes DM8C Cross-Cut Shredder Logo
1,123 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
