Question about ViewSonic VA1912WB 19" WideScreen Monitor
Actron AM24 air cond starts then stops, with run light flashing
Only starts to run for approx 1 minute. Have checked and cleaned all the filters. We have another unit, completely seperate and have no problems.
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
Air conditioner shudders, stops blowing cold, then resets every 5 mins
Cleaned the filter this AM and closed the door but now a red
light keeps flashing.
Jul 19, 2013 | Sharp Cv-p12lx 11500 Btu Portable Air...
I have a 1999 suburban with 5.7 approx 186 k it sat for a year due to selector problem in the column and had it replaced with a used unit. after getting it where it would start, it started running very...
Should have drained the tank. Not only was it old gas but it may have had some condensation in it.
Now that you have a Check Engine light, hook up a code reader and see what code(s) are there. Then you can get back here and I'll see what I can do to lead you in the right direction.
Sep 01, 2011 | 1999 Chevrolet Silverado 1500
How do I fix an e9 error on my am24-1 model actron air conditioner?
That model number is the actual wall controller model number not the air con itself. Go outside get the outdoor unit model number and call actron. Or call an a/c tech to come out.
Feb 05, 2011 | Heating & Cooling
Senville mini split codes
Put gage on low side and check the pressure running. if it is less than 125 you probably have a leak.
Apr 30, 2009 | Heating & Cooling
Samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Feb 11, 2009 | Heating & Cooling
1992 geo convertable bad gas mileage
Sounds Like You May Have A Leaking Head gasket Try Some Fix A Gasket Solution From Your Local Auto Part Store. Also Pick Up Some Fuel Additive For Cleaning Your Injectors You'll See A Total Difference. And You Said Fault Lights Are Flashing Or Arent? In The Case That They Are Try What I Suggested Then Reset The Dash Lights By Unhooking The Battery For A Minute Then Plugging It Back In.
Jan 05, 2009 | 1992 Geo Metro
Air cond will run for 1-1.5 min then stop , will restart after about 2-2.5 min
you have un under charged unit, under charged of freon. add some freon and check for leak of freon.
Jan 19, 2008 | Heating & Cooling
Filter lamp flashing
The condenser has two "channels" one for the moist hot air that are easy to clean and inspect. The other flow is perpendicular where cool air drawn from outside and passes through. These channels, viewed from the side can get blocked over time with dust/fluff. I blasted mine with a pressure washer and it was obvious from the change in light when looking through it that it was clogged before I blasted it.
Sep 18, 2007 | Bosch Axxis WTL 5410 Electric Dryer
Computers & Internet Logo
229 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
