How do i log into router
Need to pass word router and make it private
  • 74 Answers
You need to access to the router page and find the WPA-PSK page. Set the password at this page and it is safe. You need to check back the user manual to access the router because different router have different IP address to access it. Normally is 192.168.1.1 or 192.168.1.254. You can try it
Posted on May 14, 2010
I cant figure what my wifi password is and i need it for my laptop asap
The fastest way is to change the password phrase in the router.
For the existing computers you can change wifi connection easily...
Aug 14, 2011 | Computers & Internet
How do i put a password on my D-Link DIR 600 i want to use it private. pls help me.. tanx
Hello marticarpio
As far as a password i'm going to have to assume you mean to log into the router, past that security goes by pass phrase.
to log into your router open up a web browser(Internet explorer) type 192.168.0.1 At the log on screen type Username: admin Password:(default is blank) if a password other then the default is on the router, and you do not have it. use a paper clip to press in the reset button on the back of the router for 15 seconds. repeat the log in instructions using the default password. Immediately change the default password.
If you wanted to have a secure wireless network, click the wireless settings section. Name your router, and select a type of security. Depending on the type of security you choose follow the onscreen directions(wps may be easier)
How to make my wireless go from public to private.
Use your browser and go at the address http://192.168.1.1. Log in using user: admin and pass: admin (or whatever you use to log in at your router's settings page). Locate the Wireless section - security tab. Here set the security mode to WPA2 (better safety than WPA) and type anything you like at passphrase field. This passphrase is the one that someone has to apply in order to connect with your Wi-Fi.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Sep 24, 2010 | Linksys WRT54G2 Wireless Router
Pass pharse
Log on to the router, go to wireless security.
I would choose WPA ( you choose the password)
WEP is much weaker, try not to use WEP ( It gives you a pass phrase/key)
Jul 22, 2010 | Linksys WRT160N Wireless Router
Router needs to be reconfigured
Log-on to your router at either:
192.168.1.1
192.160.0.1 (some routers use this address)
Enter your admin and password names. If these were never set, chances are good you can just press enter to pass right through. You can't change router settings unless you log in.
Once you've logged in, you can then update the router's firmware and configure it to your uses.
Hope that helps!
Jun 05, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How to lock router and make it private some one is using our net work router and i would like to know how to pass word it
If it is wireless router, you need to access to the router page, find the WPA-PSK page and set the password. So any PC or notebook want to access the network from your wireless router.
May 14, 2010 | Computers & Internet
How can I make my router private so no one else can connect to it?
to make your router private u will have to get acces to ur router firs if u cant just reset the router from the back the log to the internet and if u cant conect type this192.168.1.101 the brand name of the router appear then enter the user name and pasword if u cant type ADMIN in the user then press enter then go to settings and chose WEP share key and type your password recomment to use a strong password ok then click save. also create a user name while u in thre ok. that will reset the router after that go to my network conection right click on ur wireless router name and go to propertis then chose the WEP share key and type the password then ok. that will set ur router privated ok. good luck
Feb 07, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Problem with DIR 655
On the laptops, check that your Internet is set to use "Private" networks as opposed to "Public". Private networks allow others to see you and you to see others on the network, once you've entered the proper pass phrase as set up in the router's software. Your Manual for the router has the instructions you need to complete this process.
Dec 15, 2009 | D-Link Xtreme N DIR-655 Wireless Router
Did a factory restore, set up wireless, can browse internet via a neighbours unsecured network, but cant on mine. can log in to router wirelessly but thats it no internet
Dide you set up the wireless on your router? If you have done this and you have it set for None for security, you will also be "unsecured", BUT you still have a name (SSID) to identify your network. Check that your internet is set for "Private" access, if you are presented the option between Private and Public.
Nov 16, 2009 | NetGear WGR614 Wireless Router
I am unable to secure my ususl network
Your unable to secure your wireless home network? The user manual of the router has step by step instructions if you just bother to read it.
I can help you but first lets make sure that I understood correctly.
Can you clarify, what is ususl network? is that the name of your network or?
what is the brand and model of the wireless network router?
Does your computer have XP? Or vista? or??
I assume you mean a wireless network, is this a wireless network or with a wire? and how are you connecting to it?
Sep 29, 2009 | Computers & Internet
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
