Question about Directv Plus DVR DTV Receiver / 100-Hours Video Recorder
My dvr won't let me record more than one show at a time
Why dose recording in dvr goes on default date when light goes
Well, I'm trying to decipher this. Why does the recording in DVR revert to the default (date/time???) when the light goes off and comes back on.
I'm guessing you are trying to say time, not date, maybe day?
The DVR is trying to remember when a show comes on and record it, based on your settings. Usually shows come on at a specific time. DVRs usually update their scheduled recordings based on updated programming guide information. If you are constantly unplugging or causing your receiver to otherwise restart, most receivers will download an updated guide upon getting power back or restarting (DVRs themselves not having any idea how long they've been without power, download a new guide just in case after you unplugged them you moved to Arizona). During this time, the recording you set is showing the original time you set it up, because until the guide is downloaded, it has no idea that its wrong.
My best advice, even if I'm wrong about our language barrier here, stop unplugging your receiver. Leave it plugged in and powered at all times.
All times.
For ever.
Dec 18, 2016 | Televison & Video
I had a new dvr added to my TWC cable services,but installer did not totally explain how to record or find recordings after taping. Can anybody tell me how to remedy this problem?
http://www.timewarnercable.com/en/support/faqs/faqs-tv/on-screeng/iguide/how-do-i-record-a-show-using-m.html
How do I record a show using my DVR and i-Guide?
There are multiple ways to do this:
  1. Press the RECORD button on your remote control while watching a program to begin recording. An overlay will appear on your screen to let you know you have started recording.
  2. From the TV listings grid, highlight the show you want to record and press the Record button.
  3. From any program information screen, highlight the Record icon and press the OK/Select button on your remote to schedule a recording. Follow the on-screen prompts for additional recording options.
Manually schedule a recording for a specific time or channel:
  1. Press the MENU button on your remote control then select the DVR icon.
  2. Or, if available, press the My DVR button on your remote control.
  3. Select the start time, end time and day that you want to record.
  4. Press Confirm.
  5. In the channel list that appears, select the channel to record from.
  6. Select Record to confirm your settings or select Recording Options for additional options.
and:
Video:
How to video DVR
Jul 12, 2016 | Televison & Video
When I record programme from the tv it always cuts of at least one or two minutes before the end of the programme is there any way to fix this
Try setting the time of your DVR to be precise. If the recording starts 2 minutes before the show starts it will cut off 2 minutes before the show ends! My DVR has functions that allow me to add a minute or two before or after the times set to record, but that can cause other problems like if you are recording 2 shows and you try to record a new show after a show that was being recorded, it won't allow you to, because it can only record 2 shows at a time! Best bet is tro synchronize your watch to the Internet time and use that to sync your DVR time.
Dec 03, 2015 | Televison & Video
How i can see dvr hd716 in ipad
so far, you cannot view the Panasonic WJ-Series Recorder using other browser than Microsoft Internet Explorer. because it use ActiveX Component to view the Video.
you can acess the Web Base interface of the DVR, just input the IP Address of the DVR, set disable pop up blocker for your browser, then it will show.
in some case, other browser than Internet explorer won't show the web correctly.
Sep 15, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
How do i connect to Panasonic Wj-hd716 from my iphone?
Sep 07, 2011 | Panasonic Wj-hd716/4000 16-ch Real-time...
My dish network DVR says it is recording a show in the guide but doesn't show up in my list of recordings. I have two tvs. I watch on tv 2. Why can't I watch my programs. I was told what ever...
Hi my nameis Mike Houston of DISH Network and I see you can not watch recordings on TV2and you can't watch and record at the same time. The first thing you will wantto do is make sure the receiver is in Dual mode, I will send a link to helpwith these steps and if the problem still persist please e-mail me at michael.houston@dishnetwork.com. http://www.dishnetwork.com/SupportSection/same-video-2-tvs
Aug 04, 2011 | DISH Network DVR-625 DTV Receiver /...
We cannot watch a show on another channel on other
Hello! Dan Busa here with DISH Network customer service. This is actually how your DVR is supposed to function. A 622 is a dual tuner reciever meaning it's capable of watching or recording two live shows at a time. When you record a show you tie up one tuner, there are two work arounds. You can get an additional dvr receiver or you can set up record preferences and have everything automatically record to tv2.
Jul 20, 2010 | DISH Network ViP622 DVR DTV Receiver /...
DVR-625 deleted almost all timers, stopped recording shows
Unfortunately the hard drive is failing and you will need a new one.
Thanks for using Fix Ya.
Jan 16, 2010 | DISH Network DVR-625 DTV Receiver /...
Dvr is programmed but at times "chooses" not to record show and other times it does record
Be sure that a DVR timer is set to fire, instead of an auto tune. Also if it is a series then make sure you select new episodes, your dvr will not recor a program if it has already recorded the same program once, ( re run) you can also check your scehdule in your dvr to check if timer has been deleted or modified.
Nov 13, 2009 | DISH Network DVR 510 DTV Receiver /...
Unable to record show on the DVR
Try a hard reboot. Hold the power button on the box till it turns itself off. It will turn itself back on. After restarting try to record live tv. If you can't watch recorded shows either your harddrive may be fried. After thought, a $20 tv tuner card from e-bay for your computer, you could record them to your desktop.
Mar 11, 2009 | Televison & Video
Directv Plus DVR DTV Receiver / 100-Hours Video Recorder Logo
235 people viewed this question
Top Directv Televison & Video Experts
john milligan
rundiggity
Are you a Directv Televison and Video Expert? Answer questions, earn points and help others
