Question about Honeywell Programmable Thermostat Heater
CM67ng will not turn heating off
Hi, even though I have turned the switch on my Honeywell cm67ng to 'off' the heating continues coming on and the boiler is consequently firing up loudly at random times throughout the day. A plumber indicated to us that this was excess energy from using the hot water needing an exit route, however, the heating's sometimes coming on at 11pm, 3am...hours after we've used the hot water. How can I turn it off properly;
Holly
  • 1,711 Answers
Are you running some type of program on the tstat??
Posted on Jul 06, 2017
4 Suggested Answers
johnsonr1
  • 91 Answers
SOURCE: CM67NG Programmable Thermostat-
Here is a link to the manual for your thermostat:
http://www.bvt.org.uk/shropshire/pdf/usermanuals/HoneywellCM67.pdf
Posted on Nov 04, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: I have a Honeywell Thermostat CM67NG The flame
You may have a broken thermostat wire. Disconnect the wires from the thermostat and please note what colors are hooked to which terminals. Cross the R and W wires and see if your heating system turns on. If it does not, you have a broken wire or bad connection at the heating system. If it does start, you have a bad thermostat or bad connection at the thermostat.
Posted on Nov 30, 2009
duane_wong
  • 6826 Answers
SOURCE: We would like our CM67NG to come on at the time to
I think that after reading about this product, that it adjusts itself to try to get heat to the comfortable level, before the user expects it to be that temperature. In your case, you do not like it when the thermostat behaves in this way.
I would try another model of thermostat from Honeywell, as Honeywell has a wide variety of thermostats that will work with your furnace or boiler application.
Good luck on getting a better digital thermostat, or else, get a more manual one.
Forum HONEYWELL CM67NG
Date: 2009-12-30 at 13:37
Reply to author
Report this message
New post HONEYWELL CM67NG
CORRECT OPERATION OF CONTROLLER IN AUTO MODE
I HAVE A HONEYWELL CM67NG CONTROLLER WHICH I AM HAVING TO USE IN MANUAL MODE ALL THE TIME BECAUSE WHEN I PUT IT INTO AUTO MODE IT SEEMS TO STILL TURN THE BOILER ON WHEN IT IS OUTSIDE THE PRESET TIMES. I BELIEVE IT HAS BEEN LIKE THIS SINCE INSTALLATION SO I AM TRYING TO TRACK DOWN INFO OR WIRING DIAGRAMS ON HOW IT SHOULD BE CONNECTED IN ORDER TO ELIMATE THAT AS THE PROBLEM REGARDSADAM
Someone else had a problem similar to yours, apparently.
Manual abstract:... When the LED is OFF the boiler is OFF.Display shows flashing `battery' symbolImproper battery compartment insertion Batteries need replacingDisplay shows `flame' symbol but heating does not switch onThe heating is not required at this momentWhat is an RF Programmable Thermostat?A Honeywell Radio Frequency (RF) programmable thermostat is a thermostat that controls your heating system so that you can have comfortable temperatures when you are at home and energy savings when you are out. With RF communication there is no need to provide a wired connection between thermostat and boiler. The CM67NG can therefore be installed without disrupting your room decor. These instructions explain how to program and operate your CM67NG to get the most comfort at the least cost.When do I need to use the push button?You should use the push button to control your boiler only when the RF communication is lost (see the CM67NG Trouble-Shooting Guide).What other accessories can I buy for the CM67NG?Automatic Time Setting (ATS) "Add-On" Module * (Part No. Q6667B1015)Display works but heating does not switch on (HC60NG LEDs are off or green one is on)Boiler switched off Wrong electrical connectionHC60NG red LED is constantly on or flashingRF communication lost due to the wrong location of the room unit RF communication faultWhat will the CM67NG Programmable Thermostat do for me?· · · · · · · ·Wireless connection to the boiler allows you to mount the CM67NG in your room without disrupting the decor Armchair programming lets you set up your resting comfortably in your armchair CM67NG whileThe ATS module picks up a daily time signal from a transmitter in the UK and corrects the time on the CM67NG display. So:Call installerOptimum Start means that the CM67NG will switch on your heating system so that your desired comfort temperature is reached by the start of the program period and thus avoid unnecessary boiler firing Attractive slim styling compatible with any room decor 7 day program lets you set the lifestyle CM67NG to match your weekly· · ·You never need to set or adjust the time There is no need to adjust the unit by -/+ 1 hour in summer / winter since the unit does this automatically Your CM67NG is the most accurate clock in your home so you can use this information to set-up all your other clocks.Remove the battery compartment and re-insert it. If the `spanner' symbol does not clear itself in a few minutes call the installer* Not available in all Geographic Regions depending on transmitter range and home location Table stand for the room unit (Part No. F42010248-002) If you do not want to mount the room unit on the wall you can use optional table stand, ask you installer for details6 daily independent temperature levels let you set any 6 temperatures from 5 to 30°C at any time each day, to match your daily lifestyle Party button lets you temporarily maintain (or adjust) the current temperature for 1 - 23 hours. Useful when you have friends round or go out of the house for a short while Day Off button copies Sunday's program into tomorrow so that you can make the CM67NG follow the Sunday program if you have a ...
Posted on Oct 13, 2010
The wifi connection from worcester boiler to room thermastat Honeywell Cm921 , boiler not receiving signal
Can't help you directly, but Honeywell will have user instructions on their website.
It's something like holding the 'stat within a metre of the boiler when the batteries are inserted. Best to RTFI.
Jan 27, 2013 | Heating & Cooling
Hi any ideas on why this happens, I have a a honeywell CM67NG wireless thermostat and it fires up the bolier(Alpha CD50) even when I have set the programmer for times and days. example I have set it to...
One possibilty is the therm has a antisipator setting, meaning Ex; at 7:00 you want 72*f,but the house is 62*f at 6:15 the therm will bring on the heat early so the house will be at 72*f@7:00.There should be a short lag if it is comming on at 4:00 it is something else.
Dec 08, 2010 | Honeywell Programmable Thermostat Heater
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
My honeywell timer for the back boiler heating is blank
need to contact the people who worked on it yesterday to come back and look at it again because it sounds like you have no power to now.
Jan 29, 2010 | Honeywell CT3600 7 Day Electronic...
I have a Honeywell Thermostat CM67NG The flame symbol is showing on the thermostat, but there is no heat from radiators. The status code on boiler says there is ' no heat demand'. Boiler shows radiator...
Nov 30, 2009 | Honeywell Programmable Thermostat Heater
Oil fired boiler
Check how all three "on/off" sequences are programmed firsrt, then all other programmable options. Make sure sliders are in the sliders are in the correct possition. If it becomes more complicated than launching a space shuttle, reset it. Unless your house is a mansion keep it simple with just day and night modes. the money you save wont even cover the cost to fix the hole you punch in the wall trying to do fancy programming ;-D
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Honeywell ST6400C programmer
Hi yes sound like it not working on hot water only it would check ou the wiring on this side
Jul 25, 2008 | Honeywell Programmable Thermostat Heater
Gas Boiler will supply /fire up to supply Central heating When Room thermastat turned up and switched to Heating and Hot water. When on Hot water Only will not fire up even though thermostat on hot water...
most likly or a shorted wire unhook the wire from the boiler see if it stops then if it's still is on it's in the boiler if off try unhooking it at the t-stat on the heater this should narrow it down for you dan
Jul 19, 2008 | Heating & Cooling
My boiler keeps firing up even when the Honey well programmer is in the off position. The programmer is about 7 years old.Do I need a new one, a new battery for it or is it to do with the boiler (oil)...
I had the same problem. I traced it to the micro switch in the water/central heating motorised valve having shorted out.
I replaced the (Honeywell) motorised valve and it is now only running when it should.
Jo
May 01, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
173 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
