Pyle pt4001x right channel out. there is a breaker button that did not click. But the fuses blew out and new ones blow instantly.
  • Audio Player... Master
  • 5,391 Answers
In your case I suggest you check the main semi-conductors in the that faulty right channel. Fuses only blow like that when something like that is acting like a piece of wire. If they are transistors an Ohm Meter will show it up quick, for on the 1K setting (for example) it will be just like you had touched the test probes together! On either B to C, or E to C, or B to E.
You might not need to take them out to test them!
Posted on May 14, 2010
I blew a fuse and now my dishwasher and oven will not come on. Is there a reset button for these appliances?
Some makes do, but normally you get something on the display. Did one of these appliances blow the fuse? In which case you need to find out what made the fuse blow. Do you have house fuses as opposed to breakers? Disconnect both appliances. Check the fuse or breaker, plug one item at a time. The one that is likely to blow the fuse is the dishwasher because of the water.
Mar 23, 2018 | Microwave Ovens
I have a Sony Dolby Digital receiver str-db940 fuse blew so I put in new one and it blew also right away, not sure what to do next
It's time to take it to an electronics tech. Something inside it has died, blowing the fuse. This isn't a do-it-yourself project.
Mar 09, 2016 | Sony Audio Players & Recorders
My maytag stopped working after we blew a main breaker and reset it. We discovered a blown fuse between the water level switch and water valve. Every time i replace the fuse it blows instantly
there,s a water leak which its causung your problem
take a look inside electrical compartment water cause more problems that the electricity and comment
Sep 15, 2015 | Maytag Washing Machines
Fuse Type ?? Had a Speaker Cord Short out and Took out the Fuse....Can't Read the Little Glass Fuse
I am having the same problem but mine did not come with a fuse and I can't get a hold of Pyle.
Apr 10, 2014 | Pyle PRO PMX602M 6-Channel 600 Watts...
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
Im looking for the reset button on my pyle chopper series pla2200 amplifier...i was requested to look on the back of the amp or by the 'plug in fuse' near the input sockets and i still cant find it, what...
Dude, there is no breaker button, there are two 15amp fuses on the speaker connect end of the unit. Here is the link to Pyle: http://www.pyleaudio.com/manuals/PLA2200-2210-2220-4200.pdf
If it's not a blown fuse then you will need service.
Jul 05, 2009 | Pyle PLA2200 Car Audio Amplifier
Sony str-de845 Powers up, relay clicks, fuses BLOW!
This condition, may be produced by defective components (Q506, Q507). you can remove those transistor, replace the fuses, power-on and wait for relays click. if the fuses not blown again, them replace both transistor.
Mar 05, 2009 | Sony STR-DE845 Receiver
Igniton fuse continuously blows on my 1995-96 dodge neon
Do you have an aftermarket stereo installed? Well, try this. Remove the ground cable from the battery. Install a new fuse. if it continues, Remove the center console. and check the reverse wire connected to the shifter. It did the same thing to me and all it was, was that wire was touching other wires
Jan 11, 2009 | 1995 Dodge Neon
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
23 people viewed this question
 Grubhead
Grubhead
