Question about MTX Thunder 895 Car Audio Amplifier
I need help hooking this up
Ok i just went to hhgregg today and bought a mtx 300dx mono block car amplifier and the way they have the amplifier hooked up is normal but one thing is the got two wires in the ground and remote turn on wie ........is that how im suppose to hook it up or wat............my amplifier is not getting power at all........the power light flashes green and red very fast matching the beat and its not suppose to be like that............can someone help me please ......................p.s.
sorry the product is an mtx thunder 300xd car amplifier
  • j-dope Mar 29, 2008
    help help help.................please
  • 31 Answers
"is the got two wires in the ground and remote turn on wie"
Can you be more specific about the wiring...where the two wires are connected to and where they come from, and I'll try to help you.
Posted on Mar 30, 2008
Just hooked up mtx 500d mono amp and 12 inch sub worked for a 1/2 hour then sub quite and led on top of amp just flashes.
either ur ohm load is way off ur pos n neg might be touchin or more than likely u blew u sub is it scratchy when u push in the middle of the cone ? does it push in at all?
May 14, 2010 | Car Audio & Video
Your amp went in to power protect. You must adjust the settings on amp. This is usually very time consuming to get it right. Good Luck
Mar 24, 2010 | Car Audio & Video
MTX Thunder 81001 wont push subs
first of all you should check the minimal impedance your amp handles , if is class d it should handle between 1-2 ohms total impedance in a mono conection , meaning whatever quantity of subs you have hooked to your amplifier,their total impedance should the minimum the amp handles that way all the power from your amplifier will be used.
Jan 23, 2010 | MTX Thunder 81000D Car Audio Amplifier
I have a TN250/1 MTX class D, mono-block amp, protection light comes on and thats it. Whats the problem?
Two things, a problem with the speakers, or the amp is toast. If there is a short is the speaker, wire touching, bad voice coil, the amp will go into protect. I have also seen many, many MTX amps that go bad, and just stay in protect. the easiest way to check, is to unhook the speaker wire from the amp, then power it up, if it still goes into protect without a speaker hooked to it, you have a bad amp. Hope this helps.
Aug 17, 2009 | Car Audio & Video
I have a mtx 421d. can I over heat if I connect only one channel.
Hello jaimemm_77,
The MTX 421d is a mono amp. It only has one output channel.
If you are asking about hooking up only one channel to the input, then no, the amp will not overheat. But the output will be significantly reduced. It would be best to use a "Y" adapter with a single female and two male connectors to split the channel into both inputs.
Hope this helps.
Jun 16, 2009 | MTX Thunder 421D Car Audio Amplifier
Amp is a mtx 801d not sure
no you will not blow it out by hooking up both voice coils. But First before you do, what oms are they. and is your amp one oms stable? There a lot of ways you can wire double voice coil. But if you can get me that info i can send you some digrams to help you out and tell you whats best.
Oct 05, 2008 | MTX Thunder TA7801 Car Audio Amplifier
Thunder 5604
okay u will have to troubleshoo the amp.....dose the amp light up?...when u have the radio on? also check your sub wires.going to the amp....make sure the rca'sare hooked up to the radio rear out puts are the radio sub out puts...and then test your amp gain adjustment...let me know if that work's
Jun 23, 2008 | MTX Thunder5601 300W x 1 Car Amp Mono...
Help putting code in
hello i have 2 audiofinics adf-272 i dont know what kind of amp to hook up with it which one do u think is best for them a mtx 4051 500 watt class d mono block or a mtx 801d 800 watts
Jan 27, 2008 | Car Audio & Video
Amp works fine i think??? but Prsim efx not working at all
You need to contact MTX tech support before the warranty runs out. You'll probably have to get an RA number to send it back.
http://www.mtx.com/caraudio/contactMTX.cfm
Oct 18, 2007 | MTX TA4501 Thunder 4501 MonoBlock Car...
MTX Thunder 895 Car Audio Amplifier Logo
108 people viewed this question
Top MTX Car Audio & Video Experts
hoyzee1
Mark Skinner
Are you a MTX Car Audio and Video Expert? Answer questions, earn points and help others
