Question about Vizio VL320M 32 in. HDTV LCD TV
VL320m will not connect with my computer via HDMI after power outage?!?!? Can anyone help me please. Tryed unplugging for 5 min that didnt work. updated Bios that didnt work. What could have happened?
  • Vizio Master
  • 12,061 Answers
Well, it could be one of a few thing, first, maybe you have simply "Lost" your Video Drivers, install your Video and HDMI drivers again, ensure you set it all up correctly, and have the PC configured for Multiple desktop, and the screen resolution and Format are correct. Also the correct External input is selected (HDMI). Now On the TV, you should also unplug the set to "Rest" anything that may have gone awry, now re-set up the TV again, after you are sure all is working, then with everything OFF, plug it all up, and in. Turn ON the TV, and select the HDMI input, Now startup the PC, it should detect the TV and you should display a picture. If you don't get a picture power off tv and try again, check all once more,if you are still no go then I suspect the the TMDS transmitter has had an overcurrent situation,often caused by a power outage and or spike, surge, if left plugged in when power was reconnected. In this case, you will need to get it repaired, or get a service manual, and maybe have a go yourself, hopefully it will not come to that.
Posted on May 14, 2010
Testimonial: "Thank u 4 ur help!! I lost my video driver chipset family; but will not allow drivers to install. tried a restore point before power failure and will not work as well. going to borrow a hdmi external hard drive to check the tmds. will keep u updated on what solves the problem. "
Cannot get the hdmi to work
My Tv won't recognize my computer when connected via HDMI [Solved ...
www.tomsguide.com/.../57797-4-recognize-computer-connected-hdmi
4 days ago - 43 posts - ‎36 authors
I too was able to get the HDMI output to work and then later on stop working. ... I'm also experiencing this issue, but still can't make the TV ... Audio over TV problem using HDMI cable
Jun 30, 2015
When I connect my Laptop to my TV thru HDMI cable I ...
Feb 22, 2015
No picture on LCD TV with HDMI cable plugged into ...
Aug 4, 2014
My TV doesn't accept PC HDMI [Solved]
Dec 7, 2012
More results from www.tomsguide.com
TV won't recognize laptop when connected via HDMI ...
Dec 26, 2015 | Televison & Video
JVC SP55M HDMI sound quit after power outage
Unplug unit, wait 10 mins then plug back in. If still does not work, check for breaker trip. Be sure outlet still has power.
Nov 27, 2013 | JVC Audio Players & Recorders
My e machine computer will just shut off after 5 or 10 min.,
I had an Emachines W3609 that did the same thing, I changed the 350-watt power supply with a 550-watt and it still shut off, even using the newer one. I thought just the first one was bad but I guess not. It had more than enough power to power it up but nothing. And it used to randomly restart at times and then just shut off. Try and get a new hard drive maybe that will help. Good luck!
Jan 03, 2013 | E-Machines Computers & Internet
"out of range" when connecting ps3 -> benq t221w
It display out off range because the PS3 is feeding the monitor with higher resolution that the monitor cannot suppoert, try setting the PS3 to the lowest resolution first and go up from there.
http://s807.photobucket.com/home/budm/allalbums
May 18, 2010 | BenQ T221W Monitor
I have a samsung tv and samsung blu ray i have my dvr in hdmi 1 and my blu ray in hdmi 2. when i first turn on my tv and blu ray it works fine but if i switch to cable the back to blu ray it says no...
First, HDMI is not a perfect hook-up solution. Cable box connections via HDMI are notorious for being problematic. The best thing you can do is contact Samsung and get the latest firmware for your TV.
Samsung Customer Care: 1-800-Samsung (1-800-726-7864). If this does not resolve the issue, connect the cable box using Component cables instead of the HDMI. Component cables are HD also. I hope this was of some assistance.
Apr 07, 2010 | Samsung LN55B640 LCD TV
My wii console wont turn on, its plugged and everything, we had a power outage earlier but now no red light comes on. Please help!
Unplug the wii power cord from the wall and the wii for 5 mins. to reset the brick on the power cord.
Nov 22, 2009 | Nintendo Wii Console
NEtgear RP614 cannot connect after a electricity shortage in our home :(
Reset the router to factory default. Usually done by unplugging the router hold in the reset button and plug in the router wait 30 sec. release reset button Wait 30 more sec. and unplug router again. Then reset your computer to obtain ip address automatically in network properties. Next shut down your computer, router and modem. First re-power the modem, give it time to boot (about 2 to 3 Min. for Cable and dsl or 7 to 10 min for satellite), next re-power the router, again give it time to acquire it's info (about 2 min.) then start your computer and try to access the Internet, all should be well...
Good luck, and have a great day...
Tim
Mar 23, 2009 | NetGear WNR834B RangeMax NEXT Wireless-N...
Dvi connection to ps3
try to hold the power button for like 6 seconds until u hear a beep...
it will reset the display and adjust it to ur monitor...
hope this helps
Sep 20, 2008 | Samsung SyncMaster 940MW 19" LCD Monitor
Missing Power Cord for Vivitar DVR 550
For
The power outage is 5 volts @ 0.75 amps DC
try connecting the camcorder to a PC (turned ON) via the USB lead and see if it will take power from the computer
Aug 05, 2008 | Video Cameras
Vizio VL320M 32 in. HDTV LCD TV Logo
295 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
