Question about Epson Perfection™ V500 Flatbed Scanner
I can't get the system to recognise the light lid - can't get it to scan slides - just takes a scan of the slides inside the holder
  • 344 Answers
Have you removed the slide out cover sheet from the underside of the lid, is the slide adapter located correctly? Are you using the Epson Scan software that the scanner came with, if so have you set the Mode to Full Auto Mode, use this mode for 35mm colour negative strips or colour positive slides. You could also try setting it to Film by using the Customize option but in full auto mode the scanner should detect the slides. The most common problem is the adapter no located correctly
http://files.support.epson.com/pdf/prv5ph/prv5phbb.pdf
Posted on May 14, 2010
  • 5 more comments
  • churley May 14, 2010
    I have removed the white sheet that slides out when are going to scan slides and film.
    I have disconnected all the cords, uninstalled the software and then reinstalled.
    It just appears that the light lid isnt being read by the scanner and software - when you go to scan and go into home mode or professional mode the "film" is in grey colour and you can't click onto it.
    does this make sense
  • Tony Groves
    Tony Groves May 14, 2010
    You have to be in Full Auto Mode not home or professional.
    Nope tried this also it just scans it like a photo. Any more ideas
  • Tony Groves
    Is the 'Film' option greyed out in full auto mode, if not try this setting
  • Tony Groves
    Follow instructions here:
    http://files.support.epson.com/htmldocs/...
    Is the lid cable plugged in base?
  • churley May 15, 2010
    The film option is greyed out in all modes and nothing registers that I can do films or slides.
    Yes the cable is plugged in - have taken it out and redone it a number of times.
    I done everything that the manual says.
    Think it may be a dud lid???
  • Tony Groves
    Tony Groves May 15, 2010
    If you have followed explicitly the instructions given in my previous comment (the link to epson support) then I can only assume it's faulty.
Scanner doesn't recognise their is a slide loaded in the slide holder
The first thing I'd try is to run the scanner with the Nikon software. When you power on the scanner it goes through a variety of checks, and finally you should have a silent scanner with a solid green light at the front. Start the Nikon software and wait until it finds the scanner, if it doesn't you have a hardware problem with the scanner.
If it goes well to this point insert a card or plastic mounted slide and hit Preview. The scanner should then create and image you see on screen. Next step would be to make a scan. If the slide you're trying to scan isn't card or plastic mounted you'll need the Nikon made carrier.
Hope this helps.
Mar 22, 2014 | Nikon CoolScan V ED Film Scanner
I need an all in one printer that also has a negative scan facility. Any suggestions, I have 2000 slides to scan .
Do you want a recomendation?do you want new or used? Typically all in one users don't scan slides or film, but flat prints, so they don't have the lighted back lid needed to scan film.I know that the Epson Stylus PHOTO RX-620 & 700 had a holder for 4 slides or 1 strip of film about 8 inches long
Sep 01, 2012 | Epson Office Equipment & Supplies
Epson stylus sx200 refuses to acknowledge black ink bought direct from epson
I believe the DX series and the SX use the same system
# Determine which ink cartridges are not recognised.
# With the ink cartridge holder in the ink cartridge replacement position, lift up the ink cartridge holder lid and take the cartridge or cartridges out.
# Check that the cartridge is a genuine Epson ink cartridge - look for the EPSON branding and T0xxx codes on the cartridge labels.
# Check that the cartridges are correct for your Epson product.
# Wipe the green Intellidge Chip on the cartridge that is not recognised.
# Check the chip contacts within the ink cartridge holder for any debris or dried ink and wipe with a lint-free cloth if necessary.
# Check that the plastic at the bottom of the cartridge has been pierced.
# Check that the cartridges are in the correct slots.
# Reinstall the cartridges into the ink cartridge holder in the correct order.
# Push the ink cartridge down firmly. It should click into place.
# Repeat this for any ink cartridges that were removed.
# Push the ink cartridge holder lid down. It should clip into place and be secure.
# Press the Stop button, this will return the ink cartridge holder to the right hand side of the unit.
# If the error light flashes after the print head returns to the home position, the ink cartridge may not be installed properly.
# If the red light is no longer displayed, but Status Monitor still reports a Non-Genuine Ink warning.
# If the red light is still on the printer, and Status Monitor indicates that an ink cartridge is not recognised, follow the steps below.
# If the problem remains, there may be a fault with the ink cartridge.
Dec 30, 2010 | Epson Office Equipment & Supplies
Scanning in Epson 4180 perfection - trying to scan slide in home mode - positive film - when it scans the slide in its holder it scans the holder & the slide. What do I need to change?
Make sure the white document matt has been removed from underneath the lid. Then make sure that the document type has been changed from reflective to Film etc. If film is greyed out then check the cable is connected properly from the lid to the base of the scanner.
Jan 21, 2010 | Epson Office Equipment & Supplies
Epson 4490 scans with colour streaks/ digital interference
did you properly close the scanner lid? these type of errors do usually occur when you unproperly close the lid wherein light passes inside causing it to reflect on the document that you are trying to scan
Sep 13, 2009 | Epson Perfection 4490 Film / Flatbed...
Scanning slides produces black images. Slide
Make sure the white document matt from uner the lid has been removed. Also in Epson scan make sure you have changed the document type from reflective to Film and Colour positive.
Jul 03, 2009 | Epson Perfection V350 Flatbed Scanner
First time i have scanned slides. not sure how to load them. do you slip them in from top, then cover with the vertical slide? i have put in a slide but can't read it--it comes out black when i try to scan...
double click the HP solution center open the scanner lid remove the TMA cover (transparent material adapter) by pulling the cover up place the slides onto the slide holder insert the slides w the top of the slides pointing up and the front of the slide facing you close the lid press the scan film in the HP dialog box select picture select scan positive, and select TMA click scan
goodluck
cheers
Dec 22, 2008 | HP Scanjet 4850
How to scan negatives & slides with the epson RX620
There are holders for the slides and negatives inside the top cover. Remove the white part and take out the holders. Place the slides or negatives in the holders and place on the glass plate. Then you choose the proper menu for copy or scan and follow the directions on the screen. I scanned quite a few slides and had no problem.
Sep 27, 2008 | Epson RX620 All-In-One InkJet Photo...
CanoScan 4400f
Keep the protective cover on except when scanning slides or film.
Jan 27, 2008 | Canon CanoScan 4400f MultiFunction Color...
Epson Perfection™ V500 Flatbed Scanner Logo
97 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
