Question about LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP
My phone dropped onto the ground from the couch. But normally this happens a lot as the couch sinks down when sitting on it, and it has never been a problem but my KS360 turned off, I tried turning it back on, but it just wouldn't turn on, and I figured because the battery came out that it would just think that my phone is flat. So I plugged it in, and wiggled the charger around like normal to get it sitting work. Now, all that happens is it flicks onto the KS360 logo for about 5 seconds, which it normally does when it's about to start up, and then flicks back off again. What could be the problem? I recently had the screen cable replaced because that was faulty. I don't know what to do?
  • 269 Answers
It could be software problem. Go to LG Showroom and get your phone checked. Update the software if required.
Posted on May 14, 2010
Testimonial: "Thanks, I will try that!"
How do I take motor off boat? there is no lifting eye or bracket.
normally a job for 2 or more people
one way is to remove the retainer bolts and undo the clamps on the transom
have a mate lift the front of the trailer so that the leg sits on the ground and the transom moves below the clamp plate while you steady the motor
lean the motor back slightly while he lowers the trailer down then he can come around and help you lay the motor down onto the ground
to move the motor around use something like a fridge removal trolley where the clamp plate can hook over a bar with the leg sitting on the bottom of the trolley
Oct 09, 2015 | Boating
Screen display on iPad 2 changed to blue background with slight flickering. This happened while using - it did not drop. Reset has not solved problem.
Turn it over on your lap or on something soft like couch or carpet. Karate it chop it on the apple logo. Start softly and keep using more force. Folks have even used a hammer to do this but I don't advise it. You can also drop it face down on carpeted floor. Your ipad is likely stunned and needs to be stunned again to return to normal.
Mar 19, 2014 | Apple iPad (16 GB) WiFi Tablet PC
My phone fell.in the sink
It might work again if you're able to open up anything that you can open up... and allow to sit in a warm, dry place for a few hours. If you're able, it might help in drying to remove the battery. As you're trying to dry it out, you might want to turn it so that the keys are down. Maybe some moisture will drop out of it. It's an "iffy" deal. Might work... or might not...
Dec 03, 2013 | Sanyo 2700 JUNO
I have a Franke double bowl deep drop-in sink that I have already replaced once. The problem is that the bowls do not stay in the frame. One rise us up out of the frame with a sharp edge. What is going...
Assuming your table is level and even, is the bowl itself even also. Check it for even thickness throughout the whole edge that sits on the table top. If that is even also, then you may have to cut part of the table that the bowl sits in so that it will allow the entire sink to sit flat.
Feb 22, 2013 | Franke Drop-On Single Bowl Kitchen Sink ...
My TV turns off automatically
Does it only happen when you sit down? Ive sat on my remote before in the couch and didnt know it.
Dec 20, 2012 | Televison & Video
A bad odour smell after each wash
check that the gray flexible waste oulet goes as high as it can b4 dropping back down onto waste connection. if the flex comes off your sink trap and drops straight down, food waste from your sink can back up into machine causing smell.
Nov 21, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Washing machine is really loud when spinning (sounds like a plane taking off)and if you are sitting on couch one floor down you can feel the couch vibrate and the floor its on shakes like crazy. I was told...
no it is not normal and there so be no reasonable excuse for bad vibrations and shaking on a new machine ,if the setting up instructions and leveling procedures were carried out.
at six months it should be still under warranty so have it fixed under the warranty
Apr 23, 2017 | Maytag MHWZ400T Front Load Washer
Touch screen has stopped working and phone sometimes locks up :(
That happened to me and my htc touch hd the other day. I tuned it off, pulled the battery out and let it dry out completely. The touch screen didn't work until a few hours later. However when water happens to an electronic device it usually will need to be replaced. Just cross your fingers and hope for the best.
Mar 28, 2010 | Samsung Tocco F480 - Pay Monthly Cellular...
I dropped my camera (while it was off and in case) from the couch to the ground. Now it is completely dead. Recharged batteries, removed memory card, etc. No visible damage anywhere. Please help! Is there...
Your lens may need adjusting. This info may help . Other People solved problem. Lots of Info on this link.
http://www.fixya.com/support/t102982-e_18_problem
Mar 22, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Bleach is spilling directly on to clothes
I have the same problem and here is the reason and the solution. When you add bleach it sits in the dispenser until the rinse cycle. During the rinse cycle the machine pours a lot of water through the dispenser. The bleach is diluted and washed out with all this water into the tumbler and you clothes are rinsed with bleach. Sometimes when this rinse happens, the water does not completely drain from the bleach dispense. It sits in there. If this happens, the next time you add bleach, there is too much liquid in the dispenser and it leaks out onto your clothes.
Solution: Before you add bleach, take the whole dispenser out and see if there is a lot of water still standing in the bleach dispenser section. If there is a lot of water, spill it out into a sink. Then fill the dispenser with your bleach and it will all work out the way it should. I was having your same problem until I discovered this. I have never had the problem since.
Let's give a toast to Bright Whites!!
Nov 07, 2007 | Washing Machines
LG KS360 QWERTY Keyboard Phone BRAND FREE10 TOP UP Logo
95 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
