Question about Frigidaire FRS26R4A Side by Side Refrigerator
Parts diagram of Icemaker SI-26
Parts diagram of Frigidaire FRS26ZXHWO refrigerator, Icemaker SI-26 blades for crushed ice, They keep jamming up in the chute, having to open the freezer and removed the ice cubes that are stuck.
dididsaythat
  • 291 Answers
SOURCE: whirlpool icemaker not giving cubes, only crushed ice
If less than a year old should still be under warranty
Posted on Sep 17, 2007
SOURCE: icemaker only dispenses crushed ice, not cubes
yea! I have been without cubes for 2 years. I slid out the tray, found the lever in the back where the rod went in, pulled it down, reinserted the ice tray, and IT WORKED! At first I thought I broke the lever, because I had to hold it down with a knife while I was inserting the tray, but it just must have been stuck. I am soooo happy!
Posted on Aug 10, 2008
  • 409 Answers
SOURCE: Frigidaire Gallery Series Side by Side doesn't crush ice
hi there,
could be that the ice maker arm is getting stuck or may have some frost on it. can you supply the complete model # please?
Posted on Sep 25, 2008
SOURCE: Frigidaire plhs267zab5 ice maker won't switch crush to cube
Pull out the whole ice machine part. At the back of the fridge you will see a small rectangle hole with a white plastic part inside the whole. Loosen the pastic part by applying a little pressure with your fingers it should move, it's probably just sticking.
Posted on Jun 19, 2009
woodchuck789
  • 4059 Answers
SOURCE: Ice Maker GSI-26 dispenses crushed ice and will not dispense cube
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Posted on Aug 17, 2009
The icemaker keeps jamming up with a piece of ice either in the far left or second from the left slot.
It would be far cheaper to just replace the icemaker then to repair. It would actually be uneconomical for you to fix the ice maker by buying parts
Apr 28, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Frigidaire Model GLHS68EGSB2, ice maker will only dispense crush ice even if you press the ice cube dispenser
You need to take out the ice bucket, empty it, let the bucket sit in the sink for a few hours. Ice builds up in the crushing blades and jams them, let all the ice melt out of it and it will be fine
Oct 27, 2009 | Frigidaire Refrigerators
Ice maker dispenses cruched ice in cube ice mode
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid.
With your model number I can find a diagram which may help.
Oct 05, 2009 | Refrigerators
Dispenses crushed ice and will not dispense ice cubes
Aug 17, 2009 | Frigidaire FRS23H7CS Side by Side...
My ice-maker keeps switching to crush on it's own.
There is a long rod on the right side of the ice dispensing bucket.
This rod goes through a hole in the back wall of the freezer where a solenoid should pull up on the rod allowing the ice cubes to dispense without being crushed.
If this solenoid goes bad or ice forms around the plunger, it cannot pull up on the rod.
Check out that solenoid and the rod assembly.
https://www.repairclinic.com/Frigidaire-Refrigerator-Parts
appliance parts, help & more
Apr 13, 2009 | Frigidaire FRS26H5AS Side by Side...
Ice dispensor is stuck on crushed ice, and will not go back to cubed ice.
Pull out the ice bucket and remove every piece of ice.Place the whole pieces back in and re try.If it still is not making cubes come through than you have a blade jam. Please rate this !
Sep 08, 2008 | Frigidaire FRS23H7C Side by Side...
GHE monogram ice maker.
pull the icemaker out, say be one inch, shack it a bit, and jam it back in. We've done that each time we had that problem, before it started to work. The icemaker is designed poorly, my openion, and gets jammed easily each time you use the crushed ice. crushed ice jams the ice crusher, and cloggs the pathway resulting a no ice dispensing situation. Also try using only whole ice cubes, instead of the crushed ice. the less you use the crusher the less you'll have to problem. one last thing. if the ice is sitting in the basket for a while, due to poor ice despensor opening door design, the ice in the basket cloggs together causing the probelm.
May 19, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Frigidaire Side by Side Icemaker
The icemaker evaporator system that releases the cubes is faulty , and must be replaced.
Apr 02, 2008 | Frigidaire FRS-26DR7D Side by Side...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
230 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
