Question about Fisher Paykel EcoSmart GWL15
Fisher-parker wash mashene not work
Washing machene not work normal the wash machene start nornal but when the time is to turn to wash the cloths small noise you hiring and don?t turne the spin shaft
  • Fisher Master
  • 12,061 Answers
Www.fisherpaykelparts.net/partmanuals/GWL15US.pdf - United States -
http://www.fisherpaykelparts.net/115-46/GWL15-WA37T-Service-Manual.php
http://www.fisherpaykelparts.net/partmanuals/GWL15US.pdf
http://www.washerhelp.co.uk/washing-machine-repairs.html
Ok please find above, service manuals and repair help DIY sites, use these and you will soon sort out your problem.
Posted on May 14, 2010
What does it mean when my fisher and paykel washing machine stops mid wash cycle and starts beeping the lights that show up are 2 and 7 it's a gw611 model
I would normally say a clothes balance issue but if its happening all the time. u may have an issue with the counter balance weights or rods depending on ur type of appliance. If they go bad they tend to shut down applaince mid cycle after some amount of movement or shaking. and what happen is it contantly throw machine into unbalance position
Nov 07, 2014 | Fisher and Paykel Washing Machines
My old Fisher and Paykel GW711 washing machine worked fine until I moved house. It worked fine a few times here, too. But now it fills, but then doesn't start the wash cycle, then after about an hour, it...
sounds like an electronic problem. motor controller most likely. I am unsure off hand what this fault (7) means, but the number is very low, which normally indicates motor control board
Sep 12, 2013 | Fisher and Paykel Washing Machines
Water sensing level not working on Fisher & Paykel Eco Intuitive washing machine . The water just keeps filling up until I stop it manually . We can't use the machine to wash clothes as the Service...
Your pressure value switch is malfunction. First thing you can try that is cheap to fix is to try clean the hose that connects to the outer tub. A lot of times there is algae develops after years of washing.
May 07, 2011 | Fisher and Paykel Fisher Paykel Intuitive...
Dismantle washing machine fisher and paykel - unit smells -need to remove bowl to clean out
b4 u remove bowl try this 1/ buy 2 pkts bicarb of soda. 2/pour into empty bowl of unit. 3/select high water level 4/ select hot fill. 5/ start cycle 6/ let it wash for 5 to 10 mins then turn it off, do not let it get to rinse and drain the water away. leave it over nite with water still in it, in the morning restart program and let it do a normal cycle with no clothes in it. it will not refill as it already fill of water.please reply to see how u went or 4 more help
Mar 16, 2010 | Fisher and Paykel Washing Machines
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
Mar 13, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel Ecosmart will Wash but not Rinse/Spin
You have too many clothes in the washer. Take some out and try again
Sep 09, 2009 | Fisher Paykel EcoSmart GWL15
How do i put intuitive eco on to just spin clothes not a whole wash cycle
press power button press up button 2 times on option button to "wash advance" press adjust button to which ever rinse cycle youd like to use. press start.
Jun 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel washing machine not working properly
It's most likely the Lid switch (reed switch). Does it come up with a fault code or beep at all? if so there are eight LEDs reply with the lights eg 00100010 1=on 0=off cheers
Mar 24, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel EcoSmart GWL15 Logo
397 people viewed this question
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
