Question about Kodak EasyShare Z650 Digital Camera
After inserting the new SanDisk, SDHC Card, 8GB the camera prompts "Memory card requires formatting", press continue; warms that formatting will delete everything on memory card; pres continue; "Formatting"; then prompts that it requires formattig again & again
    Problem Solver:
  • 12 Answers
First thing; check owner's manual and USA distributor, make absolutely sure that this camera is able to read/write to a 8GB card!
If so, put that card into your computer, directly into appropriate slot or through a "reader" and the USB port. If computer runs Windows, access My Computer, click on external memory device, and RIGHT CLICK. You will get a box which offers to format the card. You can rename the card at the same time. The computer's format routine is stronger that the one in the camera. If problem still happens, consult distributor. May be fixable with a cable from camera to USB port, you download new software from distributor. Follow their instructions EXACTLY.
Posted on May 14, 2010
New camera, Canon PowerShot A2300, I have not used it, yet. Just placed the new battery in after I charged it, and I put in the San Disk 8GB SDHC Card, and the camera says "memory card error". I ca
Normally, you can only insert an SD card one way. Try a different SD card or check to see if the SD card you're using has the "write protect" switch on. If that's not the issue try formatting the card in your PC and then format it in the camera.
Mar 05, 2013 | Canon PowerShot A2300 16 Megapixel Digital...
My Samsung Digimax A7 camera will not load memory cards. I insert a card and then turn on the device, which prompts a format for the card then I hit yes, the camera thinks for awhile then just turns off. ...
The Digimax A7 may not be compatible with "High Capacity" SD Cards (SDHC). If this is the case you will need to locate an SD card that is 2GB or less in size as anything larger than this is a high capacity card.
SD card wikipedia page
Mar 01, 2011 | Samsung Digimax A7 Digital Camera
New sandisk 8 gb sd card reports memory error when inserted in camera. other cards work in camera. card is recognized by laptop. tried reformatting by Vista
There are no 8GB SD cards. Cards this size are SDHC (High Capacity). SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC cards. SDHC is not backwards compatible.
Dec 01, 2010 | SanDisk Cameras
I just inserted a 8 MB card in and the camera says "Memory card needs formatting" I click continue, then it says "Formatting will delete everything on the memory card", no problem, it's a new card so I...
8MB or 8GB? If it's actually an 8MB card, you'll be able to put maybe two or three pictures on it, so I'll assume it's an 8GB card.
The DX4530 is designed to work with SD cards. Your 8GB card is actually an SDHC card. While SDHC cards will fit into SD devices, there are electronic difference that prevent them from working there. SD cards will work in SDHC devices but not the other way around.
You need to use SD cards, 2GB and smaller.
Sep 30, 2010 | Kodak EasyShare DX4530 Digital Camera
Just purchased new Toshiba SDHC 8 GB memory card to use in Kodak Easy Share C743 digital camera. Put disk in camera prompt says "Memory Card requires formatting"...press continue, and go to formatting and...
No. Can you get into the camera menu when you turn the camera on? If so, go to "format" by way of the menu rather than clicking on continue. Also, be sure the slide switch on the side of the card is in the unlocked position.
Sep 01, 2010 | Kodak EasyShare V550 Digital Camera
I just purchased a sandisk sdhc card 8gb memory card.how do i my camera says it is the wrong format.press ok and it will format it....i pressed the ok button and it says unable to format.can you help.
The problem is that you're using an incompatible memory card.
Your camera is designed to use SD memory cards up to a maximum 2GB capacity. Click on this link for the user manual and look at the specification on page 43 under the heading "storage".
You're trying to use an 8GB SDHC: not only is the capacity far too large for your camera to handle, but it's a later technical standard which your camera does not have the hardware for. SD and SDHC cards may look the same, but are very different "under the skin". SDHC compliant devices are backwards compatible with earlier SD cards, but SD devices like your camera cannot be updated to use SDHC cards.
Your only fix is to replace the SDHC card with an SD card of no greater than 2GB capacity.
Please take a moment to rate my answer.
Jul 30, 2010 | HP Photosmart M525 Digital Camera
I purchased a new memory card (sandisk sdhc ) it will not format?
Get a new camera :-)
Seriously, the Z740 is designed to work with SD cards, not SDHC cards. While SDHC cards will fit into the camera, they will not work. You need to buy SD cards 2GB and smaller.
Jul 26, 2010 | Kodak EasyShare Z740 Digital Camera
I just received a SanDisk, ElitePro, 32GB memory chip for my Kodak C875 camera. Upon chip insertion LCD says, "disc requires formatting", "continue", "formatting will delete everything on memory card",...
This camera's software will accomidate up to 2 GB SD card, or up to 8 GB SDHC card. Check your camera manufacturer's Help Page to learn the card capacity of your camera
Dec 25, 2009 | Kodak Cameras
Formatting troubles for a 8gb Sandisk Micro SDHC
Hi Tony,
Have your My Computer window open and re-insert the card into the reader. If it doesn't show immediately, then right click and choose refresh. It should show up then.
Rob
Feb 27, 2009 | SanDisk 8GB microSDHC Memory Card with...
Kodak EasyShare Z650 Digital Camera Logo
335 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
