Question about Singer 1120 Mechanical Sewing Machine
Machine has seized. Wheel will only turn a 1/4
My sewing machine has seized. The wheel will not turn. Only goes back & forth about a 1/4 of a turn. The bobbin area won't move anymore & I can't get the bobbin in. Which doesn't matter cause the machine won't work! I have taken it apart and cleaned it but did not find anything wrong with it. No lint or even string. I am a beginner sewer so I'm not sure what else to do. Please help!
Thanks for any advice! Al
  • 2 more comments
  • Margie Campbell May 14, 2010
    Is there thread caught in the feed dogs? Something is caught somewhere in the bed of the machine. Is the bobbin case in properly? Do you have your manual? What were you doing when this first happened? Is the needle stuck in the down position? If so, loosen the screw holding the needle & pull the needle up and out. A bit more info & I may be able to help.
  • akazmer May 16, 2010
    I have seen no thread or lint any where in the bottom or the top of the machine. I have blown it out with air and I can now move it manually but not when I plug it in. When I turn it on all I can hear is the motor humming & no movement. I'm starting to wonder if its the top where I can't get at it. I do have my manual but it doesn't really tell me anything. I have taken it apart according to it. When this 1st happened all I did was plug the machine in and it wouldn't work. I didn't even get a chance to start anything. But If I do remember correctly that last time I used this the machine was sluggish & seemed to be catching on everything. Like have the wrong needle for heavy fabrics. There was resistance but I never saw anything wrong and it was working-ish. The needle is out and I can move it manually now but it still is tough. Thanks!
    How would I fix it if it is out of time? I did take the back off of the machine today to see if I could get at the top. Blew it out again with air and just generally looked around. Everything seemed fine. No lint or thread that I could see. Unless the belt is in the back of the machine.... I never noticed any belts off in the front. Thanks for your help. Your suggestions are getting me to look at it from different angles!
    Its not computerized. No fancy stuff here. Did I mention that it is a Singer with Model # 1120? Wonder if that little tid bit would help.....
  • 29 Answers
It's probably out of time, or a belt inside has slipped. If it's computerized..could be a card burnt out. Wish I could help more, but I don't have this machine.
Posted on May 16, 2010
  • Margie Campbell May 16, 2010
    Any belt would be at the back inside the machine, near the hand wheel. Some newer machines have gears instead. Usually, this happens because there is hidden thread blocking something...
    I'm not sure , but by looking at the picture of your machine..it has 2 knobs near the top center...are those for choosing stitches? If so, your machine probably does not have a belt, it probably is gear driven.
    Do your feed dogs move at all when you turn the wheel? Do you have a way to drop and raise the feed dogs? (the teeth that pull the fabric through the machine)...try dropping them Turn the hand wheel back and forth a few times, just about 1/4 of the way around in each direction... see if the wheel frees up any. If it does, then raise the feed dogs (push/flip the switch that lowers/raises them). Now, you may have to turn the hand wheel towards you a full turn (it may be hard to turn) as that's how my singer needs to do in order for the feed dogs to pop back up. You could even put a drop or two of oil on the feed dogs themselves...if there is an invisible (really that thread & lint can hide well) thread or lint..this should help get it out. Once the feed dogs come back up...rock the wheel several times, checking with each rocking motion to see if you can see any thread/lint.
    If that does not help...you probably will have to have it cleaned and serviced. Here in Lubbock, TX it's 30.00 to have it done. Some larger cities charge a lot more...so ask first.
White Sewing machine won't start. Makes the whirring noise but will not advance fabric. I've tried moving the bobbin spool back and forth but it still won't start.
If your machine is not broken, it most likely is seized due to old oil that has hardened. How long since its last service? Refrain from trying to run the machine until the issue is resolved as it could damage the motor. or more...
Wheel on right side that controls the needle up and down is very tight...
Aug 29, 2017 | White Sewing Sewing Machines
Hand wheel seems sluggish. Why doesn't it turn freely?
Is it a mechanical machine (not computerized)? If so, very likely needs a good cleaning and oiling. Old oil solidifies and seizes machine parts. Frequent oiling with fresh, good quality sewing machine oil (only 1-2 drops each spot where metal rubs on metal) will help keep your sewing machine healthy & happy. NO oil on cams, belts, plastic parts.
Apr 19, 2016 | Sewing Machines
Hand wheel won't move.Scissorbutton wont work.
Repairing a Janome or New Home Sewing Machine ...
www.thriftyfun.com/Repairing-a-Janome-or-New-Home-Sewing-Machin...
Question: Memory Craft Machine Won't Run ... I'm a computer repair technician and good with tools, is this something I could fix or should we .... machine which will zig zag fine if i turn the wheel by hand or sew very slowly; as soon as I speed ...
Janome won t turn Sewing Machines Questions & Answers ...
www.fixya.com > Forum > Tags > won t turn > Sewing Machines
Janome sewing machines won t turn related questions and answers. ... Ad. Question about Memorycraft 6500P Computerized Sewing Machine ... it could be a part has worn or broken, esecially when the hand wheel won't turn,, it needs to be.
Janome wheel not turning Sewing Machines Questions ...
www.fixya.com > Forum > Tags > wheel not turning > Sewing Machines
Janome sewing machines wheel not turning related questions and answers. ... 10000 janome jamming fly wheel won't turn fly wheel won't turn warning for too thick ...the hand wheel is not moving the needle at all Hi I was unable to move the needle at all ... Janome Memory Craft 9000 Computerized Sewing Machine.
Jan 25, 2016 | Janome Memorycraft 6500P Computerized...
Scissor button stick hand wheel won't turn
Sewing Machine Measuring Tape Scissors Iron Button ...
www.amazon.com/Sewing-Machine...Scissors.../B00K...
28 Sewing Hacks That Will Change Your Life
www.seamsandscissors.com/28-sewing-hacks-that-will-change-your-life/
Nov 1, 2014 - We here at Seams and Scissors have compiled 28 Sewing Hacks That Will Change ... Use a hair straightener to press fabric between buttons or embellishments. 17. ... Have a spool that is too big for your sewing machine? ..... My hint: I like to sew with the serger cones, so I just stick a drinking straw over the ...
Amazon.com, Inc.
Rating: 5 - ‎2 reviews
Quantity: 1 bead at listing price. Bracelet is not included. Last image shown as example; Compatible with all major brands charm bracelets, such as Pandora, ...
Search Results
    the handwheel on my sewing machine is stuck solid and won't turn ...
    https://answers.yahoo.com/question/index?qid...
    Feb 27, 2009 - Update: hi all, thanks for all your advice but it is the actual handwheelthat has seized up completly, i have no needle, thread or fabric in the ... Turned sewing machine hand wheel backwards, now it will not sew ...
    Nov 2, 2011
    Sewing machine: needle won't move up or down, even with ...
    Feb 23, 2010
    Sewing machine needle won't move up or down?
    Feb 1, 2009
    Sewing machine wheel jammed!?
    Sep 21, 2008
    More results from answers.yahoo.com
    Help me diagnose and fix a problem with my sewing machine - Sewing ...
    artisanssquare.com > ... > Sewing Machines
    Jul 31, 2012 - 14 posts - ‎6 authors
    The foot pedal doesn't make the needle go up and down, either. I unthreaded the ... I'm traipsing in the dark here, I'm assuming the power turns on ? ... There could be a bunch of thread inside the balancing/hand wheel.I found ...
Jan 25, 2016 | Sewing Machines
Thehook assembly will not move when you turn wheel
Could be a multitude of issues depending on your machine make & model. If it is an older mechanical machine, it most likely seized due to lack of regular cleaning and oiling. Consult the owner's manual for maintenance instructions and use ONLY fresh good quality sewing machine oil & applying only 1-2 drops of oil each spot.
You can take it for the standard sewing machine checkup service.
If you have the patience and time, you can try fixing it yourself:
http://www.fixya.com/support/t25934410-wheel_right_side_controls_needle_up_down
In the future, be sure to clean and oil regularly (every 40 hours of sewing, every 6 months if not in use). Use ONLY fresh good quality sewing machine oil, applying 1-2 drops of oil each spot. Consult the owner's manual for instructions.
Dec 24, 2015 | Sewing Machines
The hand wheel is stuck and won't move. machine makes a vibration noise
try working it back and forth it might jst be stuck a little but vibrating might mean you are putting it out of time too.
Jan 19, 2015 | Brother XR9000 Sewing Machine
HI problem with Consew 199R-1A. Machine locked up. I just started sewing and it locked up. Needle is fine, fly wheel won't turn more then 1/4 back and forth
Good day!
that problem is usually happen when your machine have clog or no lubrication please try to use oil to lubricate your machine at all moving parts inside.
Thank you and good luck.
Jun 10, 2011 | Consew 199R-1A Sewing Machine
Sewing machine motor seized up and broken parts near bobbin
Without actually seeing the problem myself I would only be guessing. I would recommend taking it to a Sew & Vac shot and get their opinion and a repair quote.
Nov 22, 2017 | Kenmore Drop-In Bobbin 16231 Mechanical...
Singer 1120 Mechanical Sewing Machine Logo
798 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
