Question about Garmin nuvi 350 GPS Receiver
After I enter my pin number, the receiver appears to freeze.
  • 1,284 Answers
Hi, you'll have to do a complete reset:
turn off the GPS, and as it turns on
hold down the lower right corner of the screen.
Take care
Posted on May 14, 2010
  • rruder May 14, 2010
    I don't know what to press on the right lower side of the screen. I did find out that the receiver functioned when I UNPLUGGED the cable from the car cigarette lighter. The receiver only froze when I used a newly purchased cable. Perhaps there is a short in this "counterfeit" cable.
    Where can I purchase a new cable for my car for this Garmin nuvi 350 GPS.
  • Shehu Pro
    Shehu Pro May 14, 2010
    Hi, you can get the accessories on this link below..
    https://buy.garmin.com/shop/shop.do?pID=...
    Take care
How do you access trouble codes on 2003 harley davidson deuce?
With the newer HD Security Systems using proximity FOBs where the key FOB needs to be close to the bike to start, this is now more important then ever. If the battery in your FOB dies and you have not set your Harley Alram Override PIN Code, you will not be starting your bike. It is just as important for those with oler Harley Davidsons with the push button alarm FOB. It you set your alarm and the battery dies before you return to your bike, again you will not be starting the bike.
If you haven't set the PIN over ride for your HD security alarm system...do it now! Here's how you do it...
(To view how to deactivate the security system with the manual PIN code, see below.
Setting or Changing Your Security System Alarm Override PIN
Button less fobs (Smart FOB)
1. Select 5 digit code ( each digit being a 1 thru 9) and record it on the wallet card in the owners manual.
2. With an assigned FOB present, turn IGN key ON - OFF - ON - OFF - ON
3. Press Left turn signal switch 3 times.
4. Press Right turn signal switch one time and release.
*Turn signals will flash 3 times. Current PIN will appear in the odometer. The first digit will be flashing.
5. Enter first digit (a) of the new PIN by pressing left turn signal (a) times.
6. Press right turn signal 1 time and release.
*The new digit (a) will replace the current in the odometer window.
7. Enter second digit (b) of the new PIN by pressing left turn signal switch (b) times.
8. Press right turn signal 1 time and release.
*The new digit will replace the current in odometer window.
9. Enter the third digit (c) of the new PIN by pressing left turn signal (c) times.
10. Press the right turn switch 1 time and release.
*The new digit (c) will replace the current in the odometer window.
11. Enter forth digit (d) of the new PIN by pressing left turn signal switch (d) times.
12. Press the right turn switch 1 time and release.
13. Enter the fifth digit (e) of the new PIN by pressing left turn signal (e) times.
*The new digit (e) will replace the current in the odometer window.
14. Press the right turn switch 1 time and release.
15. Before the module rearms, turn ignition key to OFF.
* The odometer will return to mileage display.
**Turning the ignition to OFF stores the new pin in the module.
Push Button fobs
4. Press button on fob twice
5. Enter first digit of the new PIN by pressing left turn signal until the desired number appears.
Press button on fob twice to enter number.
6. Enter second digit of the new PIN by pressing left turn signal until the desired number appears.
7. Enter third digit of the new PIN by pressing left turn signal until the desired number appears.
8. Enter forth digit of the new PIN by pressing left turn signal until the desired number appears.
9. Enter fifth digit of the new PIN by pressing left turn signal until the desired number appears.
Turning the ignition to OFF stores the new security PIN.
Using the Security Alarm PIN Override to Start Your Harley Davidson
1. Turn the IGN key to IGNITION and immediately hold both turn signal switches until 5 dashes appear in the odometer window.
2. Enter the first digit of your PIN (a) by pressing the left turn signal switch (a) times.
3. Press the right turn signal switch 1 time to move to the next digit.
4. Enter the second digit of your PIN (b) by pressing the left turn signal switch (b) times.
5. Press the right turn signal switch 1 time to move to the next digit.
6. Enter the third digit of your PIN (c) by pressing the left turn signal switch (c) times.
7. Press the right turn signal switch 1 time to move to the next digit.
8. Enter the forth digit of your PIN (d) by pressing the left turn signal switch (d) times.
9. Press the right turn signal switch 1 time to move to the next digit.
10. Enter the fifth digit of your PIN (e) by pressing the left turn signal switch (e) times.
11. Press the right turn signal switch 1 time to move to the next digit.
12. Press the right turn signal switch one time and the security system alarm is turned off.
May 20, 2014 | 2003 Harley Davidson FXSTDI Softail Deuce
How to reset security code
  • Select a five-digit number and record it in the manual or some place else easily accessible in case you forget it.
  • With an assigned fob present, turn the "IGN" key in this pattern:
    Ignition-Off-Ignition-Off-Ignition.
  • Press the left turn signal three times.
  • Press the right turn signal one time and release. The turn signal should flash three times. The current PIN number should appear in the odometer. The first digit will be flashing.
  • Enter the first number by pressing the left turn signal the same number of times as the digit. So if the first number is 5, press the left turn signal five times.
  • Press the right turn signal one time and release. The new number will replace the old number in the odometer.
  • Repeat steps 5 and 6 until all numbers have been reset.
  • Turn the ignition key to "Off."
DISARMING WITH YOUR PIN
  • Turn the key to "Ignition."
  • Hold both turn signal switches until you receive confirmation.
  • Press the right turn signal once.
  • Repeat steps 3 and 4 until you have entered your PIN.
Oct 11, 2013 | 2007 Harley Davidson XL 883 Sportster
Forgot my pin number and want to reset the pin number on my garmin c550
There are three options to unlock a PIN locked Garmin. 1 - Enter the correct PIN number. 2 - Take the unit to the location at which the PIN was entered. The unit will automatically unlock. 3 - Send the unit back to Garmin,
Nov 28, 2009 | Garmin StreetPilot c550 GPS Receiver
Keeps saying phone freezed then enter password \
password is usually the same as your PIN number, if you haven't changed your PIN number the factory set one is either 0000 or 1111
Mar 06, 2009 | Samsung SGH-E370 Cellular Phone
Sim lock
Complete information :
The SIM card protects your subscription and not the phone from unauthorised users. If you change SIM cards you can still use your phone with a new SIM card. Most SIM cards are blocked at the time of purchase. If your SIM card lock is on you have to enter your PIN (Personal Identity Card) every time you turn on the phone.
If you enter the wrong password three times in a row the SIM card gets blocked. This is indicated by the message PIN Blocked To unblock this you need to enter your PUK
Note:
card (Personal Unblocking Key). Your PIN and PUK is supplied by your service provider. You can edit your PIN and select a new four to eight digit number
  • If the Message Codes do not match appears when you edit your PIN you entered the new PIN incorrectly.
  • If the message Wrong PIN followed by Old PIN appears then it means that you have entered the old PIN incorrectly.
To unblock your SIM card:
  1. When PIN Blocked appears enter your PUK > OK
  2. Enter a new four to eight PIN > OK
  3. Re-enter the new PIN to confirm > OK
To edit your PIN:
  1. > Settings > the General tab > Security > Locks > SIM Protection > Change PIN
  2. Enter your PIN > OK
  3. Enter a new four to eight digit PIN to confirm > OK
To turn the SIM card On /Off
  1. > Settings > the General tab > Security > Locks > SIM Protection > Protection and select On or Off
May 11, 2008 | Nokia N73 Cellular Phone
Puk number
puk number is given by the network provider ....
i think you blocked the pin code by entering the wrong pin code for 3 times so it is asking for the puk code ..
to get puk code you must follow these steps :
1. call to your network provider customer care
2. tell them that your pin code got blocked you want puk code
3. if they ask any details about the sim card owner you answer that one ...
4. then make a note of the puk code and enter in to your cell
note :
if you enter the wrong puk code for more than 3 or 10 times your sim will get fully blocked you must purchase the duplicate sim card or you must contact the network provider shoppe ...
Mar 31, 2008 | Nokia N73 Cellular Phone
I need my 4 digit id code b 4 i can get my puk number but i forgot it
you have to phone 07973100450 from a land line. it will ask you for your phone number a few times then it will pass you to  a REAL person who will ask you ask you a few security questions like what are the last four numbers of your top-up card and vol lia that is how you get your four digit id code!!!!!!!
Feb 22, 2008 | Nokia N73 Cellular Phone
Text freezing motorola v550
motorola phone freez in txt massages
press menu
select setting
go to initial set-up
MASTER CLEAR your phone
your phone ask for your security code
the deafault of security code of motorola is (000000)
but some people change it.
enter your security code. and select ok/yes.
take note: your phone file will be lost'
such as pics., tones, and videos.
after master clear done..
do the same procedure
and select the MASTER RESET.
Jan 08, 2008 | Motorola Mobility RAZR V3
Puk code
please help my sim card is puk lock i nedd a code to unlock it
Dec 13, 2007 | Nokia 6600
Freezes at pin request
Can you enter the PIN number? Is the touch screen working? Many times a unit will appear to freeze when the problem is the touch scfreen. You need the PIN number and a working touch screen in order to get back into the Garmin and restore to default.
Nov 20, 2007 | Garmin StreetPilot c510 Deluxe GPS...
Garmin nuvi 350 GPS Receiver Logo
18 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
