Question about Mitsubishi VS-5043 50" Rear Projection Television
Mitsubishi cs 35203
My tv only gets a blue line thats all
I think that problem on IC vertical output, so you can replace IC ( LA7838 ). Good luck.
Posted on Apr 06, 2008
  • Mitsubishi Master
  • 8,617 Answers
That sounds like vertical failure. Does the blue line run across the screen from side to side? Try resoldering the vertical output IC and see if that straightens it out. This is sometimes been a problem with that chassis. Let me know how you make out or if you need additional help.
Posted on Mar 29, 2008
Owners manual Mitsubishi Cs 35203
You can visit the Mitsubishi site but as this is a old set----Also try to Google that model number with "manual" to see if you can locate one.
Jun 11, 2012 | Mitsubishi Televison & Video
Tv mitsubishi
Older 35" and 40" Mits have RGB driver IC's on signal board that go bad...in line 13 pin part # AN5862.....replace both...test with
heat & cold technique........... OR CRT is bad..................T.
Jan 15, 2008 | Mitsubishi CS-40707 40" TV
Tip
Mitsubishi parental lock removal/v-lock redo
Models:
Color Televisions
CS-20EX1, CS-20301, CS-26EX1, CS-26201, CS-26301, CS-2725R, CS-27EX1,
CS-27MX1, CS-27TX1, CS-27200, CS-27201, CS-27301, CK-27304, CK-27306,
CS-27401, CS-27403, CS-3135R, CK-3136R, CS-31AX1, CS-31FX1, CS-31MX1,
CK-31MX2, CS-31301, CK-31302, CS-3525R, CK-3526R, CK-3527R, CS-3535R,
CK-3536R, CS-35X7, CS-35AX1, CS-35FX1, CK-35FX2, CS-35MX1, CK-35MX2,
CK-35MX3, CS-35201, CS-35201A, CS-35203, CS-35205A, CS-35301, CS-35401,
CK-35402, CS-40FX1
Projection Televisions
VS-40VA2, VS-4517S, VS-45VA1, VS-45VA2, VS-4561, VS-4562, VS-5016R,
VS-5017S, VS-50VA1, VS-50VA2, VS-50VF1, VS-50VF2, VS-50VX2, VS-50VX3,
VS-5061, VS-5062, VS-6017R, VS-6026R, VS-60VA2, VS-60VF1, VS-60VF2,
VS-60VX2, VS-60VX3, VS-6061, VS-7017R
This system locks only the entire TV. The TV will display a screen that
will indicate "Parental Lock ... Now the lock is on" and request the
personal four digit code when the TV is powered on.
IMPORTANT> You must use the original remote control that came with the
TV to release the Parental Lock, you cannot use a remote
that came with a VCR, Audio System or from any other
manufacturer.
1. Depending on which remote came with your TV, press the button at
the top labeled TV,OR set the TV/VCR switch in the upper left
corner of the remote to the TV position. .
2. Press the button on the remote labeled POWER.
The TV will turn on and display an information
screen that indicates "Parental Lock ... Now the
lock is on" and ask for the four digit personal code.
3. Press the #9 and the QV buttons at the same time.
The TV will turn on.
4. Press the button labeled MENU.
The "TV Main Menu" will be displayed.
5. Press the ADJUST UP or DOWN button to move the arrow next to the
"Advanced Features" selection and then press ENTER.
The "Advanced Features" menu will appear and
indicate that the lock is ON.
6. Press the ADJUST button to move the arrow next to the "Parental
Lock" option, and then press ENTER.
The screen will change to indicate "Parental Lock
... Now the lock is on" and ask for the four digit
personal code.
7. Press the #9 and QV buttons at the same time.
The screen will return to the "Advanced Features"
menu and indicate that the lock is off.
8. Press the MENU button twice to return to normal viewing.
The original lock code has now been erased and the lock canceled.
on May 16, 2010 | Audio Players & Recorders
I have an old mitsubishi TV model cs 35203 serial 515512, and all that shows up on the screen is a thin horizontal line through the middle.
You either have a cold solder connection on the vertical output IC401 or a failure of the Vertical output IC altogether. The part number should be labeled clearly on the front of the chip and is likely LA7836 or LA7837. It's difficult to reference parts on a set this old. Remove the chassis and visibly inspect the solder connections. If they look good, replace the chip. Good luck
Bill W
integrityhomeworx.com
Mar 12, 2011 | Mitsubishi VS-5043 50" Rear Projection...
Parental lock on mitsubishi cs-35203 tv--have sony commander
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
Mar 28, 2017 | Televison & Video
Narrow blue horizontal line across screen on intial power up
You have trouble with the vertical deflection circuitry. Probably something in the driver circuit or power supply to the driver. Maybe even a cold solder joint since it comes up after a little warmup.
Jan 17, 2009 | Mitsubishi CS-40503 TV
Mitsubishi vs5003r troubleshoot
I found this in another website... i hope this can help you. I'll try too...
Found this on the web, hope it helps.
Thank you for contacting Mitsubishi Digital Electronics America, Inc. We
are pleased to be able to assist our customers via our website. Here is the
information that you have requested:
TV Lock #8
Models:
Color Televisions
CK-35402, CS-40FX1
manufacturer.
personal code.
Oct 26, 2008 | Televison & Video
Mitsubishi CS-27205 shrunken picture
Good set...worth repairing vertical circuit.....in shop...
about 100.00........................T.
Nov 15, 2007 | Mitsubishi CS-27205 TV
Mitsubishi 36" model cs-35607 lost BLUE
All the IC's have a location number printed on the pc board, look for an IC with IC6F01 next to it.
Sep 06, 2007 | Mitsubishi CS-35607 TV
Televison & Video Logo
304 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
