Question about Acer X193W LCD Monitor
Can`t install a O S on a new hard disk
I bought a used HD, maxtor 3.5 series 40gb, and want to install in my power mac g3 350, i installed the hd correctly, pinned it correctly, started up with osx install disk 1 which is the last install on my old hd. opened disk utility, have the disk image in top left of disk available, highlighted the maxtor , and started the install. however, when i get to "choose the disk to install on, the computer doesn`t give any disk image to choose from, then stops the install, gives error message 9997,NO VALAD PACKAGES, what did i do wrong, or what have i missed?, also can`t get disk utility to erase the files on the HD. Any help is highly appreciated, as i know very little about computers.
  • 2 more comments
  • jimandmonika May 14, 2010
    Thank you,revancha, for your assistance. I however am 70 years old and have no idea what fdisk is, do i get from the internet download, and install before i take my old hd out?,also please tell me how i format the drive "c", is this done with disk utility or some other program?
    Thanks again
  • jimandmonika May 15, 2010
    great advice, however, if you note, i have a MAC, and this tool is for WINDOWS, or so it says, so is there something for mac osx??
  • jimandmonika May 16, 2010
    i am on a mac, not windows and this program they say is for windows systems
  • jimandmonika May 17, 2010
    I sure do thank you for your assistance. I downloaded what you suggested, installed it as per instructions, now i don`t know how i can use it. you see, it is installed on my old hard disk, whick must be removed before i can install the baxter hd, then to install the baxter, i have to start up from some kind of operating system, i chose to use OSX install disk 1 to start up, however when the computer is started, it will give me back my start up cd, so if you can`t get it out how can you insert another cd with a disk utility on it? and how can you use it when it`s not installed on a HD?
  • 190 Answers
You will need to run fdisk. to create a partition on the HD .
then format the drive c:
you can use any partition creator software
Posted on May 14, 2010
Cannot get external hard drive to work
- Make sure that the hard drive (HD) is properly connected to the computer.
- Try connecting it to a different computer to make sure that the HD is the problem.
- Check the Disk Management in your computer to see if the HD could still be detected. Once detected, reformat the HD and it should work again.
To check the Disk Management:
NOTE: Make sure that the external HD is connected and turned ON.
1. Right-click "My Computer" (XP) or "Computer" icon (Vista)
2. Select Manage and click on "Disk Management".
3. From the Disk Management, you will see a drive letters
4. Write down all the drive letters and then disconnect the Maxtor HD from the computer.
5. If there's a drive letter that disappears, then that is your Maxtor HD.
6. Reconnect the Maxtor HD and reformat it. You may right-click the drive letter and there's an option to format the HD.
If you're hearing a clicking sound while the HD is turned on, mostly, it's already defective.
Have a great day!
Oct 17, 2009 | Maxtor Hard Drive
Freezes up During Backups
I suggest an application called "Disk Warrior" it has always maintained high ratings among us Mac enthusiasts it has a hardware test function built into it and seems to be a little better at verify and repair functions than Disk Utilities which you can try also if you haven't yet. You may also consider trying a different firewire cable if you have one handy. Other than that a reformat should have put the disk back into an original state however the disk could have been damaged by not un-mounting it in rare mac cases. If you have the time you can also reformat the disk again although I would try the first two options first.
Apr 23, 2009 | Computers & Internet
When I purchased the Maxtor oneTouch 4 Plus for my Mac, they sent it to me without disk and manual. It does work, but I have some questions. What is that light on the side of the unit... when I press on...
the light is an instant backup button, you need to have the maxtor softwre installed, but when set up correctly the hard drive will create an updated backup of your mac's hd whenever the button is pressed.
Hope this helped.
Mar 04, 2009 | Maxtor OneTouch 4 Plus 750GB External USB...
I have tried to reformat my Maxtor Basics External Hard Drive with Apple Disk Utility but nothing happens. I click on the hard drive and First Aid goes blue and that is as far as I get. When I try to put a...
I am not familiar with external hd, but with macs.  It will not let you reformat a disk if that is the starup disk.  Instead of disk utility, you need to PROBABLY reinstall the os using a universal full install disk.  That´ll let you reformat the hd.
Dec 12, 2008 | Computers & Internet
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Installing new system software on G4 imac where system removed
Well the flashing question mark means its not finding a bootable device meaning the hard drive has no OS on it. You should be able to put jaguar on it if its a retail version and not one from another mac product. Let me know how this works for you
Nov 16, 2008 | Apple Power Mac G5 Desktop
Just bought a new 120gb Maxtor HD ATA/133 to replace my old 40gb HD which burned out. The new one has 5v and 12v both at 590 ma each.The old one has written on it, 5v at 559 ma and 12v at 601 ma. Will the...
differences of amperage this minor will not make any difference. As long as the System Setup (BIOS) identifies the drive, you should have no problem.
May 13, 2008 | Computers & Internet
How to install seagate ata IV hardrive
The easiest way to upgrade from your old HD to the new 40Gb HD is to clone the old to the new. Do a google for "hard disk clone" freewares. Personally I use Partition Magic and have had very good results.
Hardware wise, you need to install the 40Gb as a slave to the old HD by connecting the same IDE cable as that of the old HD (you may have to remove your CD/DVD temporarily). You also have to temporarily remove the single jumper of the 40Gb to allocate it as a slave to the primary master (old HD). Plug in likewise the 4 wire power connector. On power up go to your CMOS/BIOS setup to verify that your PC autodetect the 40GB (you may have to do a manual detection). Boot your PC and go through the normal boot sequence. Thereafter download your clone software choice, install and run. Follow on screen instructions. You may need to reboot. After completion, use Windows Explorer to verify that everything has been copied. Power down, remove the old HD, relocate IDE cable connector of the old HD to the 40Gb, reconnect your CD/DVD, and place back the jumper of the 40Gb. On popwer up go again to your CMOS/BIOS to verify that the 40Gb & the CD are detected. Save & exit, reboot.
Hope this be of help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jan 18, 2008 | Seagate Barracuda 7200.7 40 GB Hard Drive
Re-partition external HD for windows and mac
Back up all the data on the disk to your Mac. Plug the disk into your Windows computer and format it with a FAT32 filesystem. Both Mac and Windows can use FAT32. Do not format as NTFS.
Jan 18, 2008 | Computers & Internet
Maxtor 40gb hard drive as master
Hi, Below is an image of a Maxtor 3.5 HD settings as shown on the actual HD. If you are connecting 2 of them in a single IDE flat cable/strip, one must be master and the other must be slave. Jumper settings on the left is for master, the second is for slave. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 15, 2007 | HP/Maxtor 40GB 3.5 IDE/ATA Hard Drive...
Acer X193W LCD Monitor Logo
93 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
