I have a 4 month old haier, esa 3125-l window unit air conditioner it has never really blown cold since new, now it will not blow cold at all, i have had it apart to make sure all the wiring was hooked up and as far as i can tell it is, the temp sensor seems to work good as far as kicking the compressor on and off but it blows hot and the compresser is getting really hot,,, please help , its really hot,,,
SOURCE: Haier ESA 3185 AC won't cool; makes escalating loud vibrating noise near front panel/ filter
Have someone check the run capacitor of this unit. If the run capacitor is bad over shorted it can cause the unit to run and short cycle on a current overdraw. This makes for an electrical imbalance in the compressor motor. Next step is the compressor is faulty.
SOURCE: Window Air conditioner pulls too many amps
Friend,
ngfam1 At your service!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
We sell appliances for 65 years in a family business!
My customers Tell me every week about the Whirlpool and or Maytag Air-conditioners that they bought for the cheapest price at Lowes,home,depot or a number of the big stores , knocked tapped did not work or had some problem form day one !
We can not shop price now a days cause people will sell ANYTHING IN A BOX! It is not made by that big manufacture!
But the rights to the name have been bought !And used on the box!
First, Next time buy GE PANASONIC OR FRIGIDAIRE!
THE ROLLS ROYCE IS FRIEDRICH which can run for 20 to 30 years!! YES IN YOUR WINDOW!
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
SOURCE: my furnace is blowing cold air
Is the a/c a heatpump also? Is the furnace gas, electric? Thanks
Probably Seems Replace Running Capacitor Located in Component Box or Nearby Compressor
SOURCE: NO COLD AIR
If the fan and compressor are both running and no cold air then you’re low on refrigerant,
Thermostatic expansion valve closed or bad , dirty condenser or the valves are bad in the
compressor.
