Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Did you fix the lamb issue?
I am having the exact same problem. I have changed the lamp and still no tv. The lamp indicator light is solid red and I have a 34 code. How do i know if I pushed the ballast plug out the tv housing. I just got this lamp and am wondering if i need to have it replaced. Please let me how you solved your issue. Thank you.
  • macman4226 Apr 04, 2008
    Thank you for the response. I am not familiar with the terminology here, ballast plugs. I am assuming you mean the connectors that the housing unit plugs into? If not, I do not see any other type of connector inside the housing frame after I pull the housing unit out. Also, I was told this problem could be caused by a bad ballast on the circuit board. Does this sound like something that could have happened? I have never had any issues with this TV until now. I would greatly appreciate any input you provide because I am unable to use the TV at all. It will not power on. The lamp indicator light stays red. The only way to change it to green is to unplug. However, the lamp turns red after 30 secs when re-plugged.
    Champion:
  • 206 Answers
These ballast plugs are fairly fragile and bend out of the way all the time, remove the lamp and see if this has happened. Other problems that cause this is capacitors in the power supply for the five volt line but check the connector first
Posted on Apr 02, 2008
No sound or picture. red timer light on. wd60735
This model as 3 LED indicator lights:
1) Power/Timer 2) Status 3) Lamp
If "STATUS" LED is blinking RED:
1) Internal Fan has stopped. These tv's require fans, to prevent overheating and causing damage.
If "STATUS" LED is solid RED:
1) Circuit failure (short)
2) Disconnected DVI cable, chassis to engine
3) No LAMP-EN signal from Engine to turn the lamp On.
4) Ballast UART communication problem.
If "LAMP" LED is solid RED:
1) Lamp Failure - Lamp failed to turn On.
2) Lamp is broken (e.g. burst or blown)
3) Lamp turns Off during P-ON
There is no data relating to TIMER LED being solid RED.
Hope this helps.
Cheers,
Scott
Feb 01, 2013 | Mitsubishi Televison & Video
What is the red light on my wd-60737 mean?
You can Google the brand and model number for a free owner manual but on the set indicated it means usually the lamp is the issue.
Mar 27, 2012 | Mitsubishi WD-60737 60 in. HDTV
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
My Mitsu 52525 lamp indicator went solid red. I
sounds like the caps on the power board have failed. You can get the V26 DM/Power repair kit from www.tvrepairworld.com which also contains the instructions.
May 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Thats usually caused by failed capacitors on the power board. The V26 power repair kit from www.tvrepairworld.com should repair that issue. The kit comes with the instructions on Cd.
Mar 20, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Overheat issue on kdf-50we655 sony tv
http://www.techlore.com/article/15444/Understanding-Sony-Television-Blinking-Codes/
this link tells about the blinking and how it's an self-diagnostic system that the tvs are programmed with. the number of blinks indicates the problem.
Jul 27, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Need verification of potential ballast issue and to be directed to step by step fix it directions
After lamp replacement, TV worked 4 days and now TV gives 3 blinks error. right?
If yes, please recheck lamp door / cover and fix it properly.
May 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
