I have a 3M 45CG thermofax and everything seems to work, but, it won't produce a stencil. Light comes on and appears orange in color, which is different from my Vista-fax. Do you think it is the bulb? It's a $70 approach to fix. I would appreciate any help.
    New Friend:
  • 3 Answers
It's most likely the bulb. If the bulb has any dark spots it needs to be replaced.even though it lights up its not bright enough. I had the same issue.
Posted on Apr 28, 2016
Did you get an answer to this? I have the same issue and can not find anything online.
Posted on Jul 24, 2010
    Problem Solver:
  • 5 Answers
Call me 614-580-9676. I repair this machines.
Posted on Apr 17, 2011
I have a 45 EGA 3m Thermofax machine that will not shut off. How do I fix this problem Please and THANKS?
that model needs a conversion kit it was common for that model to do that and once u convert it 8it will no longer be a fire hazard
Mar 12, 2011 | Office Equipment & Supplies
Scanning is not producing accurate colors for all colors. For example, Halloween shade of orange scans as pure yellow and brown comes out quite pink. Tried shutting the machine down and restarting much...
You'll need to calibrate your printer in order for the prints to come out with the correct color. In addition to this, if you're printing from .pdfs, you can set Acrobat to "print as image", this also helps in correcting the colors as they appear on your monitor, although this is NOT as accurate in correcting color as the "calibration" part.
Hope this helps. :)
Oct 06, 2010 | Canon PIXMA MP520 InkJet Printer
I have 2 -4550 and 2- 9750 3m thermofax machines. I need part that makes the machine shut off. the contacts i believe, where can i purchase these parts.
Hello, I rebuild these machines. I dont think you need any parts to fix your machines. I find the reason for machines not shutting off is the machine needs the drive clutch and transmision needs cleaned. If you want to talk call 614-580-9676. Im eastern time zone.
Dave
Aug 26, 2010 | Office Equipment & Supplies
Orange images!!1
Try setting the white balance. This problem my be as simple as the coloring being off a little bit. Try setting the white balance on one push to a bright color and see if that helps at all.
May 12, 2009 | Sony Handycam DCR-HC42 Mini DV Digital...
3M model 45CG Thermofax Machine how to change bulb?
On either side of the drive table are single wires that go to each end of the lamp. Remove one screw on each side of the snap-in levers. Turn red handle on left side of unit as you are looking at it. Lift up each lever (screws you just removed) carefully. You can slide the entire unit out from under the clear plastic, then you will be able to see the lamp. It is a long halogen lamp. Do not touch the lamp with your fingers!! The oil on your skin will cause that area to overheat, boil, and blow. Disconnect wires on each side. Loosen bracket screws (2 on each side). Lift lamp out of heatsink tray by porcelain ends and slide out. Replace in reverse order. REMEMBER: DON'T TOUCH LAMP WITH FINGERS. USE GLOVES OR HANDLE BY PORCELAIN ENDS. GOOD LUCK!!
Apr 05, 2009 | Office Equipment & Supplies
Thermofax machine repair
Not really sure what you are asking? Is it a thermofax that is making noise that you use to make transparency with. Or is it transparency making? I never worked on a transparency maker in 20 years of office machine repair... What is it? Is a old machine? If it is that old it may be time to replace it....
Mar 30, 2009 | Office Equipment & Supplies
I have a 3m thermofax 45cg every paper run through is completely
I am a major seller of these machines in ebay. The machine may need a new potentiometer. Build a carrier. Put two pieces of transparency plastic sheets together with a piece of tape and use this to carry your stencils. This will reduce the heat of the lamp. Rouben (rouben@ektalc.com).
Mar 23, 2009 | Office Equipment & Supplies
3m projector color issue!
the light polarizer on the blue lcd panel is fried due to excessive dust and heat. unfortunately, you'll need to replace the whole optical engine.
Dec 15, 2008 | Office Equipment & Supplies
633 people viewed this question
k24674
jasbo
jasbo
